Question about Acer Aspire 3680 Notebook
The Yellow Port That's In The Inside Where You Plug The Charger in has Broken And Is Very loose And I can reattach It. When I Plug The Charger In The Battery Wont Charge The Whole Thing Wont Come on Completely Is Their A way that i can fix it?
  • 2,567 Answers
The DC jack, where you plug the power adapter cable, might be loose or defective, & needs to be either re-soldered or replaced.
In order to do this, the laptop needs to be disassembled & the motherboard taken out. Also, the motherboard needs to be checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 08, 2010
  • hilliard5276 Sep 08, 2010
    Thanks Man And Can I Do This Or Go To A PC Repair Store
Male power port is loose hard to chasrge unit
The port is female with a center pin, the male portion is on the charger.
If you damaged this pin and it is loose you will need to replace the plug on the charger. Since these are very similar to some laptop charging ports, having a broken laptop around with same size charging port would be a bonus, or a friend with one too, but they are relatively cheap, I fix broken ones on laptops several times a year and can find a pair of them shipped for under $10 typically.
Sometimes you need to solder them on, sometimes they connect with a dongle, should be easy enough to take apart and peek inside.
Other wise, if that is beyond your expertise, does the charger have a cigarette lighter, you could likely charge it through that port, or with a trickle charger directly on the battery cables on the unit if need be.
Oct 01, 2015 | 900 Amp Jumpstarter - PKC0AZ/PKC0AZ-0
Tablet will not charge
then you may need to have the charging port looked at it may be broken or loose on te inside and try another charger first just to be sure it's not the charger
Nov 11, 2013 | Tablets & eReaders
Garmin nuvi 2555lm battery want charge
A common problem with these units are loose/broken connections on the rear USB port. There are 5 pins on this port. If the power pins are loose/broken, the unit will not be able to charge the battery. The unit will not turn on because the battery is dead. Even if you plug in the charger, there battery will not charge.
The unit will not charge the battery if it won't turn on.
While you could have a bad battery, the Nuvi 25xx series is not that old and the date code on the battery is probably from 2010 or later.
If you plug in the charger, the green battery status indicator should go away or you should see a lightning bolt appear over the battery status indicator . If you don't see a change to the battery status indicator when you plug in the charger, then this confirms that the rear USB port is broken and not applying a charge to the battery.
More information can be found here:
http://www.sharc.net/gps_battery_repair.htm
http://www.sharc.net/gps_charger_repair.htm
Mar 25, 2013 | Garmin nuvi GPS
How to charge the batterry
the charger port is located under the front of the joystick. with the charger off plug the 3 pin connector into the charger port then turn the chrger on or plug it into the wall. You should see a red and a yellow light when the yellow light turns green the batteries are charged turn off the charger and remove the plug from the joystick See my tip on charging Hope this helps you
Jun 05, 2011 | NRS Hoveround MPV 4 - Hovaround Used...
Port for car charger broken
the following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
bill
Jul 05, 2010 | Magellan Maestro 4040 GPS Receiver
My blackberry bold wont charge no light comes on just completely dead could it be a faulty battery
Does the red light come one when you plug it into a charger? if not, and your charger works on other phones, than you probably have a broken usb port. (check if it is loose). You're gonna have to disassemble the phone and repair the USB port : Blackberry Repair Guide.
Jun 29, 2010 | RIM BlackBerry Pearl 8100
My digital camera's screen isn't working
Doesn't sound like toast, but need to know was unit dropped? Did you find the connector pushed in? Do you still have pieces? Try detaching the lcd screen and reattaching and see what happens, if you would like to send in let us know
Dec 03, 2009 | GPS
Something is either work my my charger or the phone for the lg vu. a few days ago, the charger worked fine but for some reason its ot working but the red dot on the charger is on; when i plug it to my...
It is loose now the charging port may have gotten broken. It happens with the LG VU's.
If this is the case, you have 3 options.
1. repair -warranty preferably
2. new phone
3 or external battery charger. cheapest option
Check out the following link for more information
How to Charge LG Vu with Broken Charge Port
Mar 07, 2009 | LG Vu CU920 Cellular Phone
Acer Aspire 3680 Notebook Logo
142 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
