Question about Dell Inspiron 1525 Notebook
I have a Dell Inspiron 1525. I bought it in August, 2008. It has been working fine until recently. Now the problem is that it only charges upto 32%. and then it says "Plugged in, charging" but it does not charge. i drained my battery to end and again tried to recharge but it always gets stuck at 32%. Dell battery indicator says that my battery is working fine. What may be the problem here? I'd be grateful.
  • 3,940 Answers
The problem is batteries wear out. You will most likely need to replace it
http://www.fixya.com/support/r3743571-long_will_battery_in_portable_computer
Posted on Sep 02, 2010
MY DELL LAPTOP SAY 0 % NOT CHARGING
Take it back to where you bought it from for testing.
Try putting charger in a different power point.
Dec 12, 2012 | Dell Inspiron 1525 Laptop
I've recently bought a new charger for my dell inspiron 1525. The green light still shines when its plugged in, but it doesnt appear to be charging the laptop itself. Before, i would have put it down...
enter the bios with F12 and battery status somewhere, you have to see if the battery is charging.
1 - if you do not recharge the battery, you can try a new battery if the battery schimnabata no (new) option 2 then it does not load.
2 - is necessary to change the motherboard, because the battery charging mode does not function normally.
warranty if you go to them to do.
Feb 12, 2011 | Dell Inspiron 1525 Notebook
Dell inspiron 1545 freezes when charger is plugger in.it works fine with no charger.also sletimes doesn't charge it used to work fine only recently started having this problem
check that ur charger if fine,it is giving correct power , then check for system errors, run reginout registry cleaner may fix it
Sep 24, 2010 | Dell Inspiron 1525 Laptop
I have a Dell Inspiron 1525. I bought it in August, 2008. It has been working fine until recently. Now the problem is that it only charges upto 32%. and then it says "Plugged in, charging" but it does not...
How long does the battery last, when you use your computer WITHOUT the AC adapter connected?
Did you purchase a 1-year, 2-year, or 3-year warranty?
If the latter, you could exercise the warranty, and get the battery replaced.
Do you have any friends with a compatible laptop?
Does their battery charge to 100% in your computer?
Does your battery charge to 100% in their computer?
Have you looked on eBay to purchase a replacement battery?
Or, there is a company in Seattle that takes your battery,
opens it up, replaces the cells, closes it, and ships it back to you.
This could be less expensive than buying a new genuine-DELL battery.
Sep 01, 2010 | Dell Tablets & eReaders
I bought a DELL INSPIRON 1525 in august 2008. it worked fine until recently. now the issue is, the battery is not charging. when i plug in, it says "plugged in, charging"...but my battery is stuck at 32%...
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Aug 29, 2010 | Dell Inspiron 1525 Notebook
I have a dell inspiron 1525 the battery light was blinking orange and wouldnt come on so listening to an expert i bought a new battery when you first plug it in should the light still be orange??
Hi. Blinking orange light on battery indicator means it's charging. To make sure, point your mouse to the battery icon on the Taskbar located on the lower right-hand corner of your screen...near the system time and speaker icons. It should say plugged in, charging. If you see "plugged in, not charging, then you need to call Dell Phone Support for additional help.
^_^
^_^
May 10, 2010 | Computers & Internet
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
http://cgi.ebay.com/DeLL-Inspiron-1525-1526-Power-Jack-Board-48-4W006-011_W0QQitemZ380212346664QQcmdZViewItemQQptZMotherboards?hash=item58866bff28#ht_953wt_1165
if that fails to resolve next is the motherboard
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1525+motherboard&_sacat=0&_dmpt=Laptop_Adapters_Chargers&_odkw=dell+inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1311
Mar 14, 2010 | Dell Inspiron 1525 Notebook
Computer Freezes
I recommend downloading a registry repiar program and system optimzer like glary utilities from glaryutilites.org It is free and help out tremendously.
Make sure you avast antivirus or whatever you use is up to date. Run a scan for all viruses.
Lastly, if needed, format HD and reinstall windows
Sep 03, 2009 | Dell Inspiron 1525 Laptop Jet Black
Dell inspiron 1525 w/ Vista 32 will not hibernate
Hibernate issues are generally an issue with the Video driver. Try the following: Update to the latest list of drivers from support.dell.com BIOS Video Driver see if the issue is resolved. If not, then try editing the startup group of MSCONFIG and see if an item running at startup is causing the issue. (Start, RUN, MSCONFIG, OK to open MSCONFIG)
Jun 09, 2009 | Dell Inspiron 1525 Laptop
Inspiron laptop Battery won't charge
Hi
Update laptop bios go dell.com check for update of your laptop model....
Thanks
Jul 10, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 1525 Notebook Logo
177 people viewed this question
Alun Cox
