Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Krystal clear generator red service light comes on. unit only several months old
  • 59 Answers
If its in warrenty call them they will send you a new one, if its out of warrenty check your circuit board for corrision. to do this UNPLUG the system, take the 4 screws out of the peice with the display on it and pick it up there you will find a circuit board. Mine had a corroded resistor. i went to radio shack found a new one (a two pack for $1.50) soldered it on good to go works great. This seems to be a common problem i have read online.
Posted on May 19, 2013
3 Suggested Answers
SOURCE: problem with system
I had the same problem with mine. It kept shutting off and we would have to unplug and plug it back in just to get it to run for not even a full cycle every day. I thought it would be a nightmare because I'm in Canada but I called Intex and within a week I received my new salt water chlorinator that works great!
Posted on Jun 18, 2010
SOURCE: need impeller for 635 Krystal Clear pump
You can't. This exact thing happened to me at the end of last year. All the fins are broke. We ended up upgrading to the pump, and now this one overheats after 30 minutes and shuts off!
Posted on Jun 30, 2009
Unit not generating heat -
More in likely heating element has failed and needs to be replaced...
Mar 04, 2015 | Heating & Cooling
What does the service light on the intex salt generator mean ? and what do i do?
if salt is ok check sensor clean with 4 to 1 muriatic acid 1 part 4 parts water
Sep 06, 2014 | Intex Krystal Clear Model 635 Pool Filter...
Only during cold weather will these 3 lights come on "Trac Off" "Anti Lock" "Service Vehicle Soon". Have had several mechanics check the codes and nothing show up. Help?
How old is your battery,belt tensioner and belt?
A battery service life is able 48 to 58 months. A weak battery will cause electrical item to malfunction. (check for 12.6 to 13.4V with engine off)
A old belt will not allow the alternator to generate enought voltage to charge the electrical system. Check for 13.3 to 13.6V with engine running.
Jan 17, 2014 | Buick Century Cars & Trucks
Car won't start. it tries to turn over, but just doesn't .battery replaced several months ago so it's not that. The red "GEN" light pops up. Is that the generator signal? Manual doesn&
Interesting. They haven't used generators in over 50 yrs.
But yes that was the warning light for the generator.
If you have a volt meter that would tell you what the system is doing.
If the engine will not crank, and the battery is fully charged, you would need to check the connections at the starter for voltage and ground.
And the red warning lights would normally come on until the engine starts.
Jan 13, 2013 | 1996 Jeep Cherokee Sport
Free Chlorine won't register in pool?? I have done everything the manual suggests and cannot get a reading on chlorine from my pool. If you check the water coming directly out of the generator it...
if getting reading from unit and losing by the time it gets to pool water chlorine is locked need to add non chlorine shock to oxidize and super shock pool
Sep 02, 2017 | Intex Automatic Salt Water System for ...
Intex Krystal Clear Saltwater System Model CS8110 service light is on. I have cleaned the unit inside and out, reset all power connections, and no luck. It runs about and hour and then the service light...
i need a part it is the electroytic cell .it got broken when we were winterising the pool last fall. we are both handicapped and on ss and use the pool to help with the arthris and soreness in our backs .if there is any way you can help we would greatly appericate it .
thank you elbert boswell and wife judy boswell
Jun 25, 2011 | Intex Automatic Salt Water System for ...
Need impeller for 635 Krystal Clear pump
Jun 28, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
710 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
