Question about Toshiba Satellite A15-S129 Notebook
Toshiba Laptop Tecra8000 PentiumII 266MHz,can you put a wireless card in this?
  • 4,102 Answers
Hi you can but they are expensive to buy and not that reliable if you want it to pick up your wireless signal the best option would be to buy one of those usb wireless dongles these have a lot more range on them and gives you better speed. these dongles can be bought for next to nothing for the well known auction site or you can get one from your local computer store, they are cheap to buy and as soon as you plug them in you can pick up all wireless signals.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Sep 01, 2010
Wireless card Not found
Where is you get that message or indication from?
Is the wireless listed as a device in the device manager?
Did you turn the wireless switch on?
Download and reinstall your wireless drivers.
Get online and got to www.google.com In the google search box type: "Toshiba Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Network drivers.
Make sure the wireless switch is turned on.
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
Still not working?
If you still have problems then turn the laptop off, remove the power cord, remove the battery, then remove the cover that houses the wireless card on the bottom of the laptop. Remove the antennas (2 cables) from the wireless card (remember how they go so you can put them back later), then remove the wireless card from the slot ( it might be secured by one or two screws you have to remove). After about 30 seconds put it all back together and reboot. Sometimes reseating the wireless card will make it work.
Jun 05, 2012 | Toshiba Computers & Internet
I have toshiba satellite a105 i wanted to know if it have wireless internert or do i need a verizon wireless chip
The Toshiba A105 comes with a wireless card. On the bottom of the laptop there is a door toward the front middle and behind that door you can see a wireless card that has the black and white wires going to it.
There is also a on/off switch that enables the wireless card as well, its either on the left or right hand side of the laptop.
Just make sure the switch is turned on and go into the device manager and underneath where it says network adapters, you should see the wireless card listed in there.
Nov 30, 2009 | Toshiba Satellite A105 Notebook
Is there a wireless card in the toshiba satellite 1415-s173?
Go to Control Panel > System > Device Manager
Under Network Adapters you would be able to locate wireless card if its there in your system.
Sep 19, 2009 | Toshiba Satellite 15" Flat Panel LCD...
Wireless lan networking for toshiba satellite 1900
Not enough info per problem description. Not all 1900 series laptops have wireless cards installed, and not all 1900 series laptops are ready to handle wireless cards, either. Need to know what model your computer is, what wireless card you're using, ... C'mon. Let's have it...
Mar 19, 2009 | Intel Toshiba Satellite Mini-PCI Laptop...
TOSHIBA TECRA8000 MANUAL
Hey,
its available at toshiba downloads - user guide
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
  1. select your laptop from the listings - portable - toshiba. tecra .8000
Let me know if you need anything else.
Thanks,
Ekse
Feb 21, 2009 | Toshiba Computers & Internet
Wireless setup
Hi, tried to check the specs of your laptop P4/P111 anyway there was no mention of a wireless built into your laptop so if you want to use it wirelessly then purchase a wireless pc card if your laptop has a pcmcia port in it .If not then buy a usb wireless adapter,either one will work.Hope you have a wireless router installed in your house.
Dec 15, 2008 | Toshiba Satellite 1905-S277 Notebook
Toshiba satellite 2805-S301 laptop wireless card
Not wireless ready - as none of the 2805's were ever pre-wired with wireless card antennas. You can install a PCMCIA wireless card, or use a USB wireless adapter. Either one will work - the PCMCIA cards will be faster.
Dec 08, 2008 | Toshiba Satellite 2805-S301 Notebook
Has it got wireless function
I have one of these.
There's an on/off switch on the right hand edge of the laptop, with an orange light, between the dvd and the floppy drive.
The wireless card itself is a mini-PCI affair which can be fitted under one of the smaller panels underneath (you'll have to unscrew the cover, but it just slots in). There's a yellow label about interference on the panel.
As far as I know, you can only get "wireless b", or IEE 802.11b standard mini-PCI cards for this laptop. I say "only" because I wasn't able to get a connection on mine unless I stood with the laptop in view of the base station, and it's very slow compared to "wireless g" (802.11g).
Good luck.
I'd really like to know how to boot up my toshiba with the recovery dvd, by the way.
I think my drive might be physically broken.. I've set it to boot from dvd first, but when i put a blank formatted hard drive in it, it still says NTLDR is missing press ctrl+alt+del whether i put the cd in or not. Also, the dvd light is on all the time, but it flashes when its thinking about reading the cd.
any ideas ? please write to chinchilla_g03@yahoo.co.uk
thank youuu
Sep 06, 2008 | Toshiba Computers & Internet
Wireless access
my wireless card was working great, then stopped all of a sudden. If I connect to the Modem directly it works, do I need a new wireless card?
Jul 02, 2008 | Toshiba (PA3212U) Wireless Adapter
Pcmcia dont work
Unplug the card from the slot and reboot your laptop without it in there. After your computer boots back up, plug your card back in and it should recognize it again.
Jan 21, 2008 | Zyxel ZyAIR B-5000 802.11b (zyairb5000)...
Toshiba Satellite A15-S129 Notebook Logo
26 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
