Question about Bosch Nexxt WTMC 3300 Electric Dryer
The dryer E01 code comes on and the dryer stops. Sometimes it thinks the lint filter needs to be cleaned. Other times it just goes off. The dryer is newly installed.
  • 3 Answers
Reset the computer.
Unplug for 10 Seconds
Plug back in for 2-3 seconds
Unplug for 10 SecondsPlug in and you should be set!
Just paid to have mine fixed, Cheers!
Posted on Feb 10, 2012
  • Bosch Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
Ultrasense dryer sending lint filter red light, E01 message and it is beeping after starting to dry.
Try unplugging for a _full_ 24 hours. If problem still exists, bad computer board.
(I feel like I should copy this answer to a notepad and paste it every time I see these questions. This is why I avoid computerized appliances like the plague. Owning such appliances is _truly_ worth having extended warranties).
May 18, 2015 | Dryers
My bosch gas dryer has a E01 code,would like to known what that is.
It could be a venting problem. Check the lint filter and the vent pipe to make sure they are not clogged with lint. I have heard that greased lighting works well for cleaning the fine lint filter. Also check where the pipe vents and make sure it is clear. Sometimes vent caps have the mesh screens left on them. When cap vents are used the small mesh screen should be removed so any lint that blows through can clear the venting system. I hope this helps. Link for cleaner: http://www.greased-lightning.com/
Apr 21, 2011 | Bosch Dryers
I have a siemens ultra sense dryer and has started to show a code E01 I have checked the hose and cleaned the lint out I always clean the lint filter what next. It automatically shuts off and sends that...
This means there is an air flow issue most likely. Try running the dryer without the vent connected. If the dryer runs, the vent needs to be cleaned in the wall. If the dryer still does not, the thermistor on the front bulkhead will probably need to be cleaned or replaced.
Apr 13, 2011 | Dryers
Hi Our Bosch dishwasher (sms63e09uk) has E:01 displayed on the digital control panel. What does this mean and how do we rectifiy the problem
It means the machine is not getting enough water you need to replace the water inlet valve, that is very possible try cleaning it and see if that helps.If it does not then the problem is the water valve.Which is a very common problem.
This air flow error code refers to the dryer vent. This can refer to the dryer's lint screen, the thermistor behind the filter, or the vent itself could be clogged.
In order to determine which one is the problem we will need to gather some information.
1. Will water pour through lint filter's mess?
2. Outside where the unit vents on the side of the house can you feel air coming out?
3. Is the vent hose on the backside kinked or clogged?
4. Obstruction on vent housing outside (if screen is present on outside remove right away this is a fire hazard.)
Water should pour through the lint filter easily. Fabric sheets will put a layer of wax on the lint screen causing the dryer air circulation to be cut off. We should be able to feel warm, moist air at the vent outside. If air is not present you are in need of a dryer vent cleaning. A kinked or clogged vent hose can also cause the E01 error code. Ensure the vent hose is clear and placed in position with as few bends as necessary. When the vent is clear the E01 error should clear itself upon start up.
Hope helps.
Apr 02, 2011 | Bosch Dishwashers
Warning signal "linter filter" comes on and dryer
You don't have very much information here to give you a better diagnosis, like the model or the error code, but I'll take a shot at it. If you're thinking that the flashing list filter light is the error code you can relax. The lint filter light ALWAYS flashes at the end of a cycle or before you hit the start button to begin a cycle. This is just a reminder to check the filter.
If your dyer is displaying an E:01 code this indicates blockage in the venting system. Do the simple thing 1st. wash your lint filter with some dish soap and running water, lightly scrubbing it with your finger tips. After rinsing clean pat the filter dry and re install it in the dryer. While you have the filter out look down in the filter holder area and see if you have lint built up there. They make brushes for cleaning this area or you can use a vacuum cleaner attachment to reach in there and **** out the lint.
If you still have an E:01 error after doing all this you may need to have your house vent pipe cleaned. But before you do this check your vent hood where the dyer vent exhausts out of the house. If it's obstructed you found your problem
Nov 27, 2010 | Bosch Nexxt 500 Dryer
Get E01 lint filter beeps every 2 mins
this code is an air flow restriction problem make sure that the dryer filter and duct work is clean and not obstructed.once every thin has been cleared this should solve your problem,good luck let me know how thing sworked for you
Jan 22, 2010 | Bosch Nexxt WTMC 6500 Gas Dryer
Bosch Nexxt 800 series dryer E01 error
My wife has a Bosch Premium dryer that had drying problems. The lint filter would get cleaned but the machine still did not operate correctly, as you explained above. Her machine was made in 2005 and the lint screen, the plastic slotted unit in front of the lint filter was the problem. It gets clogged up with hair/lint that never makes it to the filter. I tried a shop vac to vacuum it but the problem was still there. Get a pistol cleaning kit for a 22 cal gun. Pull the lint filter out & then take the pistol rod and insert it from the drum side into each slot and pull out the tons of lint. Pull the lint off the rod when done and take a flame to burn the rest off as the rod is a brass brush with small wires on it.
Jun 14, 2009 | Bosch Nexxt 500 Plus Dryer
Bosch Nexxt 500 Plus Elect Dryer Error E01
Absolutely those dryer sheets are the root of all evil....I would also recommend a good vent brush to clean your dryer vent.
Follow these steps, it worked for me:
1. use a shop vacuum to clean out the dry vent or a vent brush.
2. Clean your lint filter with windex, hot water and and soft bristle brush.
If this doesnt work try running the until disconnected from the vent for a cycle to isolate the vent as your issue.
Cheers!
Oct 28, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
E-01 error code
hi there,
i understand your frustration here.
the E01 code means there is reduced airflow through your dryer and therefore before it overheats and starts a fire, it shuts down.
replacing boards and sensors will not fix this problem as it has nothing to do with the electronics or electrical side.
here is what you can do yourself:
check the venting on the dryer.
the vent hose runs from the back or side to the wall of your house.
it may be clogged or kinked
if everything is fine, i would contact Bosch directly and see if they have a recall or any service reports on this problem and if there are any solutions.
let me know if i can be of more assistance.
thanks.
Mar 02, 2008 | Bosch Nexxt WTMC 6300 Electric Dryer
Bosch Dryer lint filer warning
The Bosch Dryer has a temperature probe in the heater exit and in the exhaust area visible when you open the door. If the temperature difference between the two gets to high, the lint filter is assumed to be plugged and the alarm goes off.
It seems that the temperature probe at the heater, can end up with a faulty connection to the control panel over time due to corroded contacts or lint build up. When this happens the control panel thinks the filter is clogged and it may also not turn on the heating elements properly. Remove the back cover over the heating element (12 screws) and then remove the one screw holding the red wiring connection to the dryer body. You can then wiggle out the wiring connection and clean / unplug and replug in the connector for the sensor. (plug with two small wires only). A little hard feeding the connector back through the hole so take your time and don't damage the wires). Should all work again. May want to inspect inside the heater at same time and make sure the overheating switch is not tripped. ( press in the red button).
May 21, 2007 | Bosch WTMC3510UC Gas Dryer
Bosch Nexxt WTMC 3300 Electric Dryer Logo
193 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
