Question about Minolta bizhub 200 Copier
Need to reset a BizHub 200 to factory condition
  • Norman  J Weimar Jr
    Norman J Weimar Jr Nov 21, 2015
    Hi arnoldh, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What do you mean? selling it?
Bizhub 200 erro code c3452
Its related to Fuser Unit,
Try to reset by Switch On Main Power switch by holding Utility Button for 10-15 second.
Troublereset Option will appear
touch it
switch off again and on in normal way.
Dec 29, 2016 | Konica Minolta bizhub 200 Printer
Bizhub 164 service call no c3451 please help me
Fusing warm up problem.To reset press Utility Stop00Stop01 ,enter in the service mode select Trouble reset.If do not work you have need to remove and repair the fusing unit.
Jul 13, 2014 | Konica Minolta bizhub 200 Printer
How to reset bizhub 350 to factory settings
why to factory setting? problem with memory? code or certain problem?????
Jun 02, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub 350 manual de servicio codigo de error el c0500
In correct code for a Bizhub 350. What is the model # Bizhub Fuser errors start with 34, 37 ,38 for the Bizhub 200/350
May 11, 2013 | Minolta bizhub 200 Copier
Konica Bizhub 200 touch screen doesn't get past the Konica logo screen.
power off the machine and take toner bottle out. Then turn the machine without the toner bottle. let it run it should ask for the toner bottle to be replaced. Please wait is the machine is conducting house chores prior to READY TO COPY. one is to ensure toner in the developer unit is properly mixed. Also might check. Power on the machine while depressing the utiltiy/counter button hold down until you see trouble reset touch ok power off then wait 10 seconds and power on. if neither works get a tech out to look at iti
Mar 30, 2017 | Konica Minolta bizhub 200 Printer
Bizhub 200 error 107
Could not find that code on the Bizhub 200 service manual< normally a C will be the start of the code.
Feb 11, 2013 | Minolta bizhub 200 All-In-One Printer
Bizhub c451 ERROR CODE C-1183
Elevation drive assy. for the output trays. did some one leave some boxes under the trays or a trash can.? Need to remove the reset the output trays to the correct location. Recommend a qualified KMBS tech do it
Sep 18, 2012 | Minolta bizhub 200 All-In-One Printer
Konica minolta bizhub 200 c2557. Help please!
c-2557= ATDC Sensor abnormality to reset go to service mode, to enter service mode perform these steps, 1-press utility/counter button from the panel, 2-press check details, and press "STOP" 0,0, STOP 0,1 3-now you are in service mode, 4-click on tech rep mode,or Adjustment 5-now click on "Printer" 6-here increase the value, suppose you have 150, make it 170, press the clear button to clear it and enter new value which should be more than the previous one. press enter and exit from the service mode.
Jan 14, 2010 | Konica Minolta Bizhub-200 Minolta Printer
How do you do a hard reset on a Bizhub c350? Thanks.
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
2. Insert a suitable object into the hole to actuate the reset switch .
3. The code should clear and a message to close the front door should appear.
So all settings are RESET.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub 200 blank pages no error messages
problem in hv unit ( ch corona ) in drum unit replace if necessary
Jul 10, 2009 | Minolta bizhub 200 Copier
Minolta bizhub 200 Copier Logo
542 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
