Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Sears Craftsman Garage Door Opener Wireless Keypad Model and a LiftMaster Chamberlain Professional Garage Door
Gentlemen:
I have a dilemma with a Sears Craftsman Garage Door Opener Wireless Keypad Model 139.53754-01 (dated 10/06; and has the # 315 MHz), and a LiftMaster Chamberlain Professional Garage Door 1/2 hp opener (model #: 2220, dated 12/02, manufacture date 01/03). The LiftMaster has Reddish or Orange colored Smart Button on the Back of the motor unit. The remote control opener that I keep in my car has these numbers: Canada 102 619, Date 01/03, model 971LM, ID HBW1241.
I cannot figure out how to get the Sears Craftsman Wireless Keypad to work with the LiftMaster Chamberlain Garage Door Motor.
I went to LiftMaster Website and it shows eight or 9 steps to get them working. Well I spent a couple of days and several hours on hold trying to get help from them. I gave up and thought you might be able to help me with your expert advice.
TY in advance for considering my question.
AWF
  • 3 more comments
  • Anonymous Sep 27, 2008
    I have the exact problem with my Craftsman GDO wireless keypad. I have tried using the motor unit "learn" button to re-program the keypad, to no avail. I have erased all codes and started over, only to experience the same results. The GDO works from the wireless remotes (car) and from the "deluxe" wall mounted control center.
    Any assistance would be helpful and most appreciated.
    wemac2@bellsouth.net
  • eskjlk Dec 19, 2008
    I followed all of the suggestions. I even put a long wire on the antenna. the openers only work if you are nest to the antenna and will not work away fron the wire. The outside opener will not work and I followed the instructions. It seems I cannot pick up a strong enough signal to the receiver to activate the door opener.Thsi is the second sears unit that we have tried with the 315. Help
  • pmajkowski Jan 09, 2009
    Hello. I have the same problem. I installed the unit about a month ago. Things worked fine. But last week, the outside touch key pad stopped working. The car push buttons still worked. I reset the unit. I tried 10 time or more to hit the learn button and enter the code and wait for the lights to blink ... nothing! It's not a dead battery. Aarrrrggghh!
  • Anonymous Feb 04, 2009
    Can you reset a pass code if you forgot the old code ?? on a keyless pad
  • Anonymous Mar 15, 2014
    Driveway sensor is keeping gate open
  • 11 Answers
I had the same frustrating dilemma with my Craftsman LiftMaster garage door and Keypad, Model 139.53754-01 (dated 10/06; and has the # 315 MHz).
To resolve “the dilemma”, grab your keypad, climb up on a ladder to access the garage door opener’s motor unit. On the right side of the motor unit, remove the white plastic casing by pressing buttons on each side and pulling down. This will expose the programming area, and for our purposes, the “Learn” button.
1. On the motor unit, press and release the “Learn” button. The Learn indicator light will glow steadily for 30 seconds.
2. Within 30 seconds, enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
3. Release the ENTER button when the motor unit lights blink. The code has been “learned”/stored/activated.
Good Luck, and I Hope this Helps!
Gail
For possible future reference:
How to change an existing, known PIN
(Changing an existing PIN can be done with the wireless remote keypad, and does not require access of the motor unit.)
From the keypad:
1. Enter the four digits of the present PIN, then press and hold the # button. The opener light will blink twice. Release the # button.
2. Enter your new 4-digit PIN and press Enter. The motor unit lights will blink once when the PIN has been “learned”/stored/activated. Test by entering the new PIN, and pressing Enter.
Posted on Jun 24, 2008
  • gail lamarra Oct 25, 2008
    What is the make/model number of your Craftsman garage door opener?
    Are you trying to program the wireless keypad (usually) affixed to the outside of the garage door, or a wireless remote control you have/leave in your car?
    If it's a remote control unit you're struggling with, what is its make/model?
My new 315 MHz keypad will not communicate with my older 390 MHz opener?
That is correct the units are two different frequencies and will not communicate. Kind of like trying to listen to an FM station on an AM radio. Sorry to be the bearer of bad news. Dean
May 05, 2011 | Sears Craftsman LiftMaster Chamberlain...
Ladies / Gentlemen: I have a Craftsman 139.53975SRT1 Garage Door Opener. What is the correct keyless entry pad for this opener? Will a 139.53876 keyless entry pad work with this opener? Thank You! ...
The correct keypad for your opener is 139.53684. The 53876 keypad is an older technology and will not work correctly. If you program it you will find your remotes no longer work and if you reprogram your remotes the keypad will not work.
Sep 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
I'm looking to download a manual for my Craftsman garage door opener. I'm not sure I have the right numbers but I have the following two 41DB101-1C and 41A5685 the date says 5/06
The model number you are looking for is on the end of the opener closest to the door and starts with 139. You can then go to Sears parts and download a manual.
Apr 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
Can a craftsman 953876 keyless entry pad garage door opener work on a liftmaster garage door opener
If both units were manufactured before April 2005 or both were manufactured after that date they should work. If one is older and the other newer than that date they will not work with each other.
Jan 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman new 315MHz Garage door remote programming with old openers
The radio frequency has been changed so the two are not compatible.
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Programming kepad for Sears Craftsman Garagedoor opener 1/2 hp
The only procedure I have ever followed is to press the learn button and then enter the code, and not do anything else. I think your last step of holding the button until the light goes out is clearing codes as fast as you enter them. Just stop after you enter your code and let the learn mode time out on its own. That should do it.
And don't put your head through the wall. It just causes more headaches.
Feb 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
I can't get my old remote to work with my new garage door opener
buy new remotes. New opener is 315 mhz, old are 390 and not compatible,
Jan 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
7,311 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
