Question about Samsung Washing Machines
What is E no 1 on washing machine wa13G7Q1 - Samsung Washing Machines
  • 4,323 Answers
Hi
Error code 1E means WATER PRESSURE SWITCH ERROR. This error occurs when the Generated Frequency Signal of water level is low or high.
WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the Water level is detected as low or high for more than 5 seconds, then it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 minutes after which you would get this error. To resolve this issue you can try and clean the filter screens inside the water lines. To check this disconnect lines where they go into washer use needle nose pliers to pull out screens clean with water and put them back. This will resolve the issue.
Daniel
Posted on Sep 01, 2010
I have a samsung toploader wa13g7q1... it uses approximately 420 litres of water per wash.. full load... is this normal?
Do something good for all your skin. Use natural natual skin care products. These do not contain harmful chemicals, unlike synthetic ones that damage your skin over
http://www.toptryloburn.com/vita-luminance/
Mar 29, 2016 | Samsung Washing Machines
How can i remove drum over for samsung toploader washing machine. Clicking noise when drum is turning. Model nr wa13g7q1
bra braces or something between wash drum and heater element .unit.? remove the drum or
Set the machine on its side ?
Dec 16, 2015 | Samsung Washing Machines
WA13G7Q1
Check Belt tension. The belt may be slipping
May 06, 2014 | Samsung Washing Machines
Samsung wa13g7q1 top loader
UNPLUG and lean forwards. sounds like a blocked pump. look underneath for the pump and remove it, check out inside and remove any blockages.
Nov 18, 2013 | Samsung WE356A5W Washer/Dryer Laundry...
I have a samsung washing machine WA13G7Q1. There is alwasys black flacky debris on my washing after every wash. I clean the filter in the drum before every wash. Is there another filter i dont know about?...
I do not knnow either, but what I know is that after having washed black socks in my machine, there will be black particles floating around and sticking to the next washload. Sowhat I dois to doas you do clean before washing, then I put some rags old towels or pillowcases and wash on 40 degrees Centigrade. Then I clean the machine again and am especially careful to clean the rubber rings around the door and the doore specially the lower part.
good luck
Kolbrun
Feb 24, 2012 | Washing Machines
Looking for a Samsung WA13G7Q1 washing machine user manual
u can get that manual from below given link
http://www.manualsmania.com/download.php?link=9bf2da2386f59b40b986333f91ad7463356fd759
Dec 14, 2011 | Samsung Washing Machines
Wa13g7q1 washes but doesn't want to spin; code de appears with an alarm, pls help
Replace the pressure switch, and run a cup of white vinegar thru a cycle with no laundry in the unit.
Sep 22, 2010 | Samsung WE356A5W Washer/Dryer Laundry...
I have a Samsung WA13G7Q1 washing machice The
the quection is not complete, when the cold water inlet and hot water inlet both work then what is the problem....
Apr 27, 2010 | Samsung Washing Machines
Samsung wa13g7q1 gives se error
Please check the following :
  • Inspect the drain hose for kinks
  • Test the timer control
  • Test the lid switch
  • Inspect the water pump
  • Inspect the drive belt (belt drive only)
  • Inspect the motor coupler
Jan 20, 2010 | Samsung WE356A5W Washer/Dryer Laundry...
Washing Machines Logo
422 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
