Question about Hotpoint Washing Machines
What does f-03 mean? - Hotpoint Washing Machines
  • 4,323 Answers
Hi
Error F03 in Hotpoint washer means that the thermistor is open. When thermistor turns bad it will not let the water to heat or in some cases will boil the water to extreme temperatures. You’ll need to replace the thermistor to resolve this issue. The thermistor is located in the motor control unit. Inspect the element if its open circuit, it should read 1500-1800 ohms on Rx1 on the multimeter, if not then element is bad. To check/replace the element remove the lower rear panel. Hope this helps...
Daniel
Posted on Sep 01, 2010
If disconnect my battery of my toyota sequoia will it disprogram my engine of a 03
What do you mean disprogram your engine of a 03? If you mean will the engine still operate the same, yes it will. If anything, you may need to reset the radio clock (if you have one), maybe reset the radio station presets, and on some vehicles, may need a car code to allow the radio to turn on.
Mar 25, 2015 | Toyota Sequoia Cars & Trucks
What does this message mean: 231 Fatal error 03
During a 3 minute unplug, carefully check ALL sensors, latches and doors for misalignment or damage. Replug.
Call service.
Feb 03, 2015 | Oki Electric Industry C8600n Led Printer
Oki
231 means RFID reader I/F error. 03 means Communication error
between the RFID reader and the tag chip. The remedial measure is to check for normal connection of the antenna cable.
May 06, 2014 | Oki Electric Industry C830DTN Laser...
Hotpoint acquarius wf640 what does error f-03 mean?
F-03 means that there is a drain problem. Check the drain filter and the drain hose. The drain filter must be cleaned and the drain hose must be set according to the specifications on the appliance's manual.
The drain filter access is located in the front lower side of the washer. The drain hose at the back of the appliance. See also: http://www.fixya.com/support/r4949772-washing_machine_not_drain
Jun 23, 2012 | Hotpoint Washing Machines
Al encender mi ACER Aspire 5100 suenan 2 pitidos y en la pantalla me pone: Sistem BIOS Version:V3.13 Bus:06, Device:01, Function:00 ERROR Resource Conflict - PCI in slot 03 Bus 06, Device:04, Function...
You have a n IRQ conflict meaning you have a device that is trying to use an IRQ slot that its not meant to talk on. From the looks of it you have been in the bios already so go back in and set it to factory default.
Aug 16, 2010 | Computers & Internet
''Call Service :03'' message on Muratec F-560
IF MACHINE IS SAYING "PLEASE CALL SERVICE" 03 then it is indicating you have a fuser problem.(thats the part that warms up to melt the powder onto the paper.) Until the problem with the fuser is repaired this error code will not go away.
Jun 10, 2010 | Muratec Office Equipment & Supplies
03 dodge durango trouble code "p done" appeared where the milage is displayed, what does it mean?
"P done" means there are no codes stored. If there were codes you would see P and 4 numbers.
May 27, 2009 | 2003 Dodge Durango
Error code F-03 Indesit wixe127
Hi.
The code F03 means the wash thermistor is open circuit.
Unfortunately, you will have to call an engineer.
Cheers.
Nov 18, 2008 | Washing Machines
Put motor from 04 spectra into a 03
hi how much time have you got i presume you mean by motor you mean the whole car if so its just acase of work alot of it and it will need pressurising lot of work just for a/c but can be done good luck yates210456
Jul 03, 2008 | 2004 Kia Spectra
Amp reading E-03
the manual say it means that the speaker cord is shorted, or when the speaker output is in contact with the vehicle ground, i hope you can solve the problem with the info i just gave. good luck
Oct 04, 2006 | Kenwood Excelon KAC-X811D Car Audio...
Washing Machines Logo
243 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
