Toshiba Sony ICFCD855V Clock Radio
Problem for Toshiba Sony ICFCD855V Clock Radio
No power for Sony ICFCD855V Dream Machine.
By HowieG on May 10, 2008
My power supply for my Sony ICFCD855V Dream Machine went south. Do I just replace it with another 110 VAC to 9 VDC power converter?
Comments:
May 14, 2008
- I was able to get the clock to. radio work by replacing the broken power converter with a multivoltage setting 1200 mA DC converter. It seemed that the clock radio requires 7.5 VDC, since that is the setting that worked. The originaaly power converter probably could supply more current since its wires are thicker.
Same Problem
Apr 28, 2009
-   I DONT KNOW HOW TO SET THE ALARM CLOCK. = (
-   Guest
Dec 29, 2008
-   Have no power but wires appear to be good. Does anyone know what the supply output is suppose to be? -   Guest
Aug 24, 2008
-   measured the power converter and it read 4 volts. Unit doesn't work - radio, cd, clock-nothing. It's 1.5 years old. prior to going out the power converter was making noises-   saint pete
Best Solution
posted on Nov 24, 2008
Very Helpful)
kalvinb
Rank: Apprentice
Rating: 100%, 2 votes
Power supply seems to be 12 volts. I have ICFCD855V's and the power cords on both broke just past the strain relief on the power supply. That shorted the supply and blew the fuse (1.6 amp). I soldered in a new fuse and the supply (with no load) puts out 12VDC. Since it happened to 2 in my house I can't believe Sony doesn't have a recall on these things
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Dec 09, 2009
Not Rated)
ph55645
Rank: Apprentice
Rating: 0%, 0 votes
Yup, another SONY POS. Had the same problem the transformer is way too large and heavy so the power cord broke right at the strain relief, got twisted and shorted. Of course SONY used these propritary trangular screws so you can't salvage the power supply. Had a Sony camcorder which went bad you would not believe the nonsense I went through to tey to get it fixed. Forget SONY. Just have to train my family members to avoid their products. If I have the time I would try Kalvinb's method
Was this helpful?
Yes
No
Popular Solutions for Toshiba Sony ICFCD855V Clock
Questions and Unsolved Problems for Toshiba Sony ICFCD855V Clock
Do you recommend Toshiba Sony ICFCD855V Clock Radio?
Answer
Answer
GPX clock radio / docking station for iPod - the blue time display is too bright. Even the dimmest... (More)
Answer
We are having trouble getting the clock temp. set. I lost the intire instructions on how to set my... (More)
Answer
The light on my iHome clock radio has quit working. The time is there-I just can't see it in the... (More)
Answer
why does my acu-rite weather forecaster blink at times
Answer
what is the dc input for the unit? 9 volts? The power pack ac is 120v 60hz 10w I have a number of... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Clock Radio Experts
Top Audio & Video Equipment Repairmen
in , OH
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
