Question about Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
Im loking for dust filter at the model bosh nexxt 100series wfmmc1001uc front load washer
  • 11,896 Answers
Turn the machine over remove the black hose. Take the main hose off the bottom of the pump feel up the hose and pull out all the rubbish put your finger in the pump body pull out all the rubbish and the drain plug should unscrew. Clean it out properly put it back together
Some units have a bottom plate with screws you can remove to access the filter.
Posted on Sep 01, 2010
How do i drain the water from my bosch nexxt front loading washing machine to remove the pump filter
I believe if you can get to it, put the hose end lower than your tub and it should drain. My front loader quit pumping and it was two quarters stuck in the pump.
Jan 02, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
How I can clean fliter for washer machine bosch nexxt 100 series
just unscrew the filter plug located usually front bottom of machine.
Dec 13, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosh neither spin nor drain
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 18, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
My bosh frontload washer wont spin or drain
If it does not drain, then it will not spin.
Locate and clean pump filter.
Aug 06, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Noisy pump in bosch nexxt 500 washer
no its usually not that loud at all contact bosh direct to have them send you a new one or call them if its still warrantied
May 01, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
I put a load of clothes in my bosh nexxt 300 washer, went out to the store and such come home to put the clothes in the dryer, the door is locked, no lights on the washer. The washer is plugged in and plug...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is for the WFMC6400, but it could help.
To manually unlock the door lock system, perform the following steps:
1. Unplug the power cord from the outlet.
2. Remove the lower toe panel.
3. Reach up along the inside of the front panel and
locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch
assembly is a teardrop shaped tab.
Gently pull the tab down approximately 1/4 inch,
or until a click is heard.
5. The door may now be manually opened.
Pl give me a ‘very helpful’ rating for the free help, thanks!
Apr 24, 2010 | Bosch Nexxt 300 Series WFMC2201UC
Bosch 100 series will not drain
You need to check and clean the pump filter if you have not already done so.
This is located at the bottom front right of washer.
Unscrew anti-clockwise to remove and clean.
Mar 15, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Jan 11, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosh error code E02
Hi. I had the same problem with my Bosch washing machine and called Bosch...was told the same thing...$99.00 for service call. I managed to fix my problem by doing the following:
  • Removed hot & cold water supply hoses.
  • Took filter screens out of both hoses.
  • Removed filter from cold inlet on back of washing machine. I noticed some oily buildup on both of the cold screens so opted to not put any of them back in.
  • Then I put hot & cold water supplies back on the wall hookup, but crossed the lines where they came into the back of the machine intentionally so that the hot water line fed into the cold side of the washing machine and vice versa.
  • Then I ran a couple loads on "cold" which was actually hot water coming in to the machine.
The reason I did this was that I figured there must be some more waxy buildup inside the machine in the cold lines and hoped the hot water would melt it like when you rinse a greasy pan under hot water. IT WORKED!!! I hope this helps you.
Sep 29, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
