Question about Kyocera FS-3900DN Laser Printer
We have a kyocera fs-c5100dn. When printing credit card reciepts it takes around 1.5 minutes. Is there some way to speed this up?
    Brigadier General:
  • 10,406 Answers
The printer probably is going into "power-saving" mode after several minutes of non-usage. Then, it must "warm-up" for 90 seconds, in order to print the page. Reconfigure the printer to stay "active" for a longer time, like 30 minutes, before entering "power-save" mode.
Posted on Sep 01, 2010
Kyocera FS-C5100DN shows Error message "close front cover" what to do??
it is in the left front of the machine the cover you open to change toner should have a actuator that pushes the switch that could be broken off or 1 of your toner cartidges may not be set correctly remove all of them and close the cover if it says install toners do that 1 at a time see if it keeps saying install cartriges until all are installed or you see close cover message after 1 is installed that would be the 1 not installed correctly causing your close cover message
Mar 29, 2017 | Kyocera FS-C5100DN Color Laser Printer 23...
Why is the kyocera fs-c5100dn print smudging
If the final product is smudging after it prints out the fuser unit is not working and the toner is not fused to the paper. Also the paper should be warm when it prints out.
If it is during the printing you may have loose toner in the printer that is contaminating the print process.
Aug 29, 2014 | Kyocera FS-C5100DN Color Laser Printer 23...
Kyocera service codes
Magenta developer unit non- install-
ing error
• The toner sensor 1 inside the magenta
developer unit did not output the den-
sity detection signal, judged the
engine controller PWB (KP-1054) the
magenta developer unit is not
installed.
You may want to leave that to a certified tech!
Aug 29, 2014 | Kyocera Office Equipment & Supplies
What causes the printing to be cut off around the page edges on my Kyocera FS 4020DN?
when we want to print from email then
there is a print button within email if self probably right side of email which one is opened
a small print symbol is there try with these button
it opens a new widows from which good print can done
Aug 19, 2014 | Kyocera 1102J22US0 Model FS-4020DN Laser...
Error on display call service 7402:0005942
The machine is not detecting the cyan developer unit . I would first try reseating the unit or replacing it.
Jan 29, 2014 | Kyocera FS-C5100DN Color Laser Printer 23...
ERROR CODE F186 FOR KYOCERA FS-C5100DN
Guten Tag,
Kyocera FS-C5100 error code 186
was sagt der fehler aus
Aug 06, 2013 | Kyocera FS-C5100DN Color Laser Printer 23...
Kyocera error f186
Upgrade firmware to the most recent version.
I have a kyocera FS-2000D with error code: Call for service 0150:0000049. Help...thanks in advance
Error code 0150 is an engine EEPROM communication error. The engine board might need to be replaced. I have heard that sometimes a defective developer unit could cause this same error code. I would try swaping a develper from a working FS-2000D first.
May 20, 2010 | Kyocera FS-2000D Laser Printer
Kyocera printing very slow
Has it always been slow, or is that a recent development? At its fastest, the FS-2000 only prints 31 pages per minute, and that's for regular single-sided 8.5" x 11" with no special requirements. Anything else will (thick paper, longer paper, duplexing, etc.) will slow the print speed down.
One thing you can try to speed up the print speed is to change your spool options in the print driver. Go into the print driver (Control Panel > Printers & Faxes, right click on the FS-2000 and select Properties) and find where the spool options are located. Try selecting different spool options (such as waiting to send the job until all the pages have spooled, or sending it page by page) to see if any of them affect printing speed.
There are other options in the print driver's properties which could affect printing speed as well. Look around the different tabs and try changing some of the options to see if they make any difference.
You can also go to Kyocera.com and download and install the newest version of the print driver, which might speed up processing as well.
Hope that helps!
Mar 18, 2010 | Kyocera FS-2000D Laser Printer
I cannot seem to get my excel spreadsheet to cover the whole page when printing on my kyocera fs-c5100dn. Has anyone experienced this with this type of printer before? Thanks
I am guessing that you have not highlighted all of the cells you want to print.I assume your using a PC..Mac's are the same. Click and drag over the cells to be printed. Is the page set up corrrect? Maybe your page is bigger then 8.5x11 or 8.5x14
Oct 27, 2009 | Office Equipment & Supplies
Kyocera FS-3900DN Laser Printer Logo
214 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
