I know it's not my machine it's brand new. I have been fighting this probem all the time. I try rinsing an rinsing and it' still on them. It is like a white film.
  • 4,102 Answers
Hi it sounds to me like its not warming the water up try putting in a couple of towels and put the washer on its hottest settings and then when its going through the cycle touch the glass and see if its hot, its usually leaves these marks when the water dont heat up as it dont disolve all the cleaning powder or what ever you use.
try it on its hottest settings and touch it to see if its hot if it is then try another normal wash after and see if that has improved things, if it still feels cold then it could point towards the heating element not working inside the washer.
also check you have it on the correct settings put it on about 90degreed for the towels as you can pretty much boil them so give that a try and let me know what happens.
also the quick wash or rapid wash will do a poor job if your not using the right powder or gel so also try it on a normal wash
let me know what you find or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Sep 01, 2010
I had troubles with my washer going through a cycle and stopping when it got to the rinse cycle. I put in a new timer, the machine worked great through part of a cycle but again quit just at the rinse...
Verify that BOTH hoses are hooked up to the correct water inlet and they are TURNED ON and FLOWING. Your condition acts like hoses are reversed, and the hot (cold actually) is turned off, that will cause the machine to stop on the rinse cycle....
Mar 04, 2011 | Roper RAS6233KQ Top Load Washer
Wont spin or rinse out ends wash clicks and nothing else
without knowing brand or model, can only recommend check pump and drain outlet. Front loaders seem very finnicky about their outlets. You should be able to access it easily for regular maintenance. If your machine has stopped before it drained you will need to be aware of that water 'waiting' to exit! Check for string, twigs, anything blocking the outet. A jammed toothpick nearly cost me a new timing switch ($260) !
good luck
Jul 15, 2010 | Washing Machines
Maytag washer stops after wash cycle for long periods of time
Good day,
If the issue your describing occurs all the time then being brand new it's a warranty issue. It will be covered free of charge.
Call your selling dealer for details on getting a free warranty service call. Sounds like either a motor problem or timer issue, but it's not your problem.
Jul 05, 2010 | Maytag MVWB300W Top Load Washer
1989 nissan pathfinder v6. I have been fighting
If your burning any kind of water then thats your probem.you put water with fire or electric what do you get. also if your smelling gas that can be the map sensor.it mesures the mixture and air.it also compensates the mixture when the motor is running like **** because of water in the cylinders or intake manifold. head gasked yes or intake gasket.
Apr 28, 2010 | 1989 Nissan Pathfinder
Stuck on ''rinse hold''
not knowing the brand and age i guess you have a touch control dishwasher with a membrane switch which may be contaminated over time which makes it impossible to operate best thing to do is get model and brand visit your nearest spare parts supplier and purchase new part if you are handy not hard to fit if not call in repairer please switch of dishwasher before inspecting alwys work safe
Nov 05, 2009 | Coffee Makers & Espresso Machines
My washing machine stops mid cycle, and it won't drain, rinse or spin. I've tried several times, not sure what to do?
I'm 99.99% sure its the timer. Timers are easy to replace. Write down brand, model and serial no. and go to an appliance parts distributor and pick-up a timer. When you replace first unplug unit. When wiring new timer make sure timer looks exactly the same. Then transfer one wire at a time to the new timer.
Oct 09, 2009 | Washing Machines
Brand new front Load GE washing machine stop at rinse cycle
Check that the Cold water valve faucet is open. Perhaps the earlier vibration problems have caused a wire to come off the water valve connections inside the machine.
Sep 30, 2017 | GE Energy Star WCVH6260F Front Load Washer
Fight Night Round 4 disc unreadable
carlo me hi hello to all im new sign up to fixya hi 2 all!.
Jul 06, 2009 | Microsoft Xbox 360 Console
Clothes washer
well that's a tough one need to ask a few questions first whats the brand and model number second does it fill in the rinse cycle ok.If it fills in rinse try selecting wash with cold wash/ cold rinse selected and let me know how that works please hold my rating till we are finished
Jan 11, 2008 | Washing Machines
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
