Question about D-Link DCS-5220 Network Camera
How to completely reset a dcs-5220 camera to the dafault factory values, including password, lan configuration, etc.
SOURCE: Cannot factory reset DLink DCS-G900
i had the same problem and it was frustrating at first. You have to access your router and find the start ip address and the range and make sure dhcp is enabled. then plug the camera into one of the lan ports using the cable provided and plug the other end into the camera. then refresh the list of wireless clients in the router. Also if using a pre n router make sure that the broadcast is not mixed and is set to g mode. Only a g router will work or a router with g set to broadcast. i couldn't get the camera to work until i changed this setting. Anyways getting back to what i was talking about. When you see the list of clients you will see the camera listed on the client list. Write down the ip address example (192.168.1.108) and then on the computer (make sure you have another cable plugged into another lan port on the router and plugged into your computer) go into the dlink setup wizard. Press the search button the camera will appear on the list. Then click on the wizard and wait. It will say that the settings do not match there is an ip conflict or something to that matter do you want to change the settings click change settings and put the ip that the router configured. subnet mask is 255.255.255.0 and put the default gateway of the router which is usually 192.168.0.1 on most dlink routers but on the linksys i was using it was 192.168.1.1. After changing these settings it will let you into the camera configuration and after that you can unplug the cable and wait a minute or two. the green light should start blinking showing that the camera is connected to the router. Bingo your all done your camera is back to normal wireless function. You might have to unplug and reset the camera. If you have more than one camera make sure you unplug all the other camera's before configuring the first one. This will prevent any ip conflcts. Hope this helps you.
Posted on Nov 29, 2008
SOURCE: DCS reset
Push the reset button on the back of the camera
Posted on Feb 23, 2008
SOURCE: Wireless installation for DCS-5220
check wep and wap security in your camera.
check if your wireless signal is good
Posted on Jul 15, 2008
  • 1170 Answers
SOURCE: download software
You can download the driver from the following link :
http://driverscollection.com/?file_cid=390169192057c4f19a60c24a889
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Posted on Apr 01, 2009
  • 181 Answers
SOURCE: How to set Static local IP Address for D-link DCS
To set a static IP on the camera, do the following:
1. Chose an IP address for the camera that is outside your normal DHCP range but within your network subnet.
For example, if your router uses DHCP and gives out addresses in the range of 192.168.1.1 up to 192.168.1.10, you should chose an IP address beyond that (e.g. 192.168.1.20).
2. Login to your camera's current IP address and go to Setup -> Network setup
3. Turn off DHCP and type in the IP address that you chose into the configuration.
4. Restart your camera.
The above should fix your Static IP address question.
With regards to your Wireless question, you should make sure of the following:
1. Your router is set to broadcast its SSID
2. Your router is setup to use WPA (not WPA2)
3. Your AES password in the camera config is the same as that as the routers
Hope this helps
Posted on Jan 04, 2010
How to recover corrupted firmware for IP camera DCS-5220?
http://support.dlink.com/ProductInfo.aspx?m=DCS-5220
Go to this site and download the drivers
Then
Uninstall old drivers and install new ones
Jan 06, 2017 | D-Link DCS-5220 Network Camera
How to setup aztech router for remote ipcamera (dlink dcs-5220 model)
Install the installation disk of the ipcamera. Configure the ipcamera base on your requirements. Then install the ipcamera on the position you require.
Sep 13, 2010 | D-Link DCS-5220 Network Camera
I forget my sonicwall admin password how will reset this password
If the SonicWALL's admin password is lost, there is no backdoor or other mechanism to bypass the administrator login. Please note that prefs files do not contain the admin name and password. So if you reset the firmware and import a current prefs file, you can gain access using the default login credentials ('admin' & 'password'). Without a current prefs file, you must reset the firmware and configure from scratch.
For models running SonicOS (Enhanced or Standard), you can reboot to factory defaults. This resets all settings including the admin name, password and LAN IP address. Import the current prefs file. The configuration is restored and use the defaults 'admin' and 'password' to login.
For models running Firmware 6.X, you must reset the firmware (wipe and upload using the reset procedure). Import the current prefs file. The configuration is restored and use the defaults 'admin' and 'password' to login. The 'Reset to Factory Defaults' button does not reset the admin name, password or LAN IP address for these models
Feb 03, 2010 | SonicWALL PRO 1260 SonicOS Enhanced...
I changed my GE DVSR admin password but forgot to note down how do i reset it to dafault/factory default
i changed my GE DVSR admin password but forgot to note down how do i reset it to dafault/factory default
Jan 11, 2010 | GE Home Security
How to set Static local IP Address for D-link DCS 5220 IP Camera? Am using Linksys WRTG54 Router, with SSID & WPA. I had set the D-Link DCS wireless to use the same SSID and WPA, but once I plug out...
Hope this helps
Nov 24, 2009 | D-Link DCS-5220 Network Camera
Settings on Linksys router for the DCS 5220 to view remotely and settings on Securicam
Configuring your Linksys router for remote desktop is a task that's needed before you can access your computer from outside the network. If you plan to connect to your remote desktop machine from the Internet, you need to configure the router to allow traffic to the PC. Linksys is a common router used on home networks for wireless and LAN configurations. Configuring your router to allow port forwarding to a remote desktop only takes a few steps through the graphical user interface.
  1. tep 1 Open your browser window and type the IP address of the router in your address bar. This opens a window for the username and password needed for access to configure the router.
  2. Step 2 Click the "Applications and Gaming" tab on the opening screen. This opens a window with a list of ports of which you can open for access on your network.
  3. Step 3 Type "Remote Desktop" in the application textbox.
  4. Step 4 Enter "3389" in the "Start" and "Stop" port ranges. This port number is specific to the remote desktop application.
  5. Step 5 Leave the value of "Both" in the protocol listbox.
  6. Step 6 Type the IP address of the internal machine on your network. The IP address is the machine running remote desktop. When traffic from the Internet reaches the router, it forwards the request to this IP address.
  7. Step 7 Check the "Enabled" checkbox and click "Save Settings."
  8. Step 8 Close the browser window.
Nov 14, 2009 | D-Link DCS-5220 Network Camera
Plug in the network cable first and make sure the following settings are correct:
1. SSID is the same and set to broadcast
2. You are using the same WPA AES password as the router (or WEP password if you are using WEP)
3. The wireless antennae is connected
4. The camera is located not to far from the router
After that, remove the network cable and restart your camera.
May 19, 2008 | D-Link DCS-5220 Network Camera
Inability access from other computers
You need to check with your router vendor on how to setup DMZ or Port Forwarding for your DCS-5220 in your router. (For Port Forwarding, please open BOTH HTTP Port and RTSP Port and select the Protocol as TCP for HTTP Port and select the Protocol as TCP/UDP(Both) for RTSP Port.
Nov 14, 2007 | D-Link DCS-5220 Network Camera
DCS reset
Oct 05, 2007 | D-Link Express DCS-900 Network Camera
D-Link DCS-5220 Network Camera Logo
1,401 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
