Question about Fisher and Paykel GWL11 Top Load Washer
Machine which actually says GWL 15 US will not drain. I suspect drain inside machine is clogged
  • 2 more comments
  • mssewnsow Sep 01, 2010
    How do I get to this the pump?
    Or rather drain area.
    Do I get charged everytime you respond to me?
    Could not get that link to work.
    I am grateful for your help.
    And repair instruction manual?
  • 11,896 Answers
It is very common for the drain or drain screen to become plugged. It is not as rare but is very possible that something has gotten lodged in the pump and could block it from spinning. Most often the drain or the screen is plugged.
Posted on Sep 01, 2010
Trying to find pump.
Hi - I understand you will like to know where to find pump and check for clogs. Try the following steps below and hope it is helpful:
To completely clear any clogs in the washing machine drain you will use a pipe auger (snake). Start at the roof plumbing vent and drop cable to roughly 10 or 15 feet past the actual drain. If there is a clog present, the snake will bring up a chunk of debris. Remove it from the top of the vent and discard.
The drain hose is visible toward the bottom of this washing machine. It is held in place by a clamp or a couple of screws.
Remove the drain hose from the back of the washing machine. This is normally held in place by a clamp or a couple of screws. When a drain backup occurs, pieces of debris can lodge in the hose, causing clogs and odors.
Soak the hose in a bucket of warm bleach water.
Soak the drain hose in a bucket of warm water mixed with 1 cup of bleach. Look to see if the line is free of obstructions. Run a small length of clothes hanger through the hose to clear any hard debris.
Reattach drain hose and connect to drain pipe.
Reattach the drain hose using a screwdriver or pliers. Insert the hose into the washing machine drain. Be sure it is all the way into the drain opening.
Run the washer through a full cycle with 2 cups of bleach added.
Cycle the washer with warm water and 2 cups of bleach. The bleach will help remove any odor-causing particles in the machine and drain hose. Running the washing machine through a cycle will help flush away any remnants of the drain pipe clog.
Oct 12, 2012 | Frigidaire Affinity ATF7000E Front Load...
Replace fisher paykel iwl 16 mother board with gwl 11 motherboard
I cannot find your mothers IWL16 model, but I have found various similar machines that are the same phase as your GWL11 machine, the electronics in there although different are compatible, you can swap the drain pumps, there almost universal, avoid the drive shaft machine, fix the other one If you want further help, post a photo of both pcb's (the electronics) After swapping your machine will stil require programming which is simple enough
Sep 14, 2012 | Fisher and Paykel GWL11 Top Load Washer
AFTER 15 MINUTE FROM OPERATION I SEE ON SCREEN SEMBOLE LE AND MACHINE STOP
Please check on the error codes list for LG machines and confirm if the codes seen is LE.
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6333
Since the machine shuts down after working for few minutes , it is possible that it shuts at the time of drain and the suspect can be a damaged or clogged drain pump.
So check the voltage on the drain pump at this time to confirm
Thank you for using Fixya
Sep 24, 2011 | LG Washing Machines
Fisher Paykel GWL 15 will not drain, nor go into spin cycle. Cannot find a service manual for this machine.
normally thats a bad door safety switch,, bypass it with a Jumper wire , if it works with the jumper, replace the switch
Jul 13, 2011 | Fisher and Paykel Kitchen Ranges
Model gwl 15 us not draining
find black rubber drain hose under machine and squeeze several times to loosen soap and hair gunk.
start the mahine on the rinse cycle. This should start the draining process.
Dec 08, 2010 | Fisher and Paykel Fisher & Paykel Washer
Gwl 15 washer no power. panel doe,s not ligthup and machine will not run. I checked elect. outlet. Outlet has power.
Hi just read your posting.There are 2 reasons why your machine does not power up.!st-- The drain pump is open circuit, and --2nd---your motor control is faulty.If you can look underneath the machine for me and see if you have the pump with a red or black fan.It will be towards the front of the machine and slightly to the right.Please reply with if you have this pump or another type and I can guide you throe testing the pump to find the exact part that is faulty
Jun 13, 2010 | Washing Machines
Altus washing machine wont drain
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
3. Drain Filter
Check the drain filter for clogs as well. This filter can become clogged overtime, preventing the free flow to exit the drain tube. It is located inside the unit, mounted on the pump housing.
**The most common issue will be an obstructed hose or, line
NOTE-If the hoses filter,and pump check out ok, this will confirm that there is a serious within the actual control sector(Timer module or control board). It should be replaced i this case.
Nov 26, 2009 | Tecnik TKL9260 Front Load Washer
My GWL 15 pumps so hard water comes out of the
A washer cannot pump the water out too fast, regardless of what you have done or have been told, the problem is too do do with the drain outlet, I suggest you completely take apart the stand pipe and any other pipes connected, and thouroughly clean them .
Please rate my solution.
Thanks.
Jun 21, 2009 | Fisher and Paykel GWL11 Top Load Washer
E20 error when starting tumble dry cycle
E20 on your machine means some sort of Drain problem. If it actually goes through the Spin cycle o.k. then there is most likely some water still not drained out at the time of the tumble dry. Check the drain to make sure it isn't clogged. also the drain hose.
Feb 29, 2008 | Washing Machines
Will not turn on
If led'slight up when POWER button pushed but nothing happens when START button pushed ITis likelt to be lid reed switch open circuit or pump is open circuit .If nothing lights up when turned on at wall socket suspect controller dead or pump open circuit.Pump sounds like it has caused problem joker 120 need to check loop resistance of pump 35ohms for Aus/NZ
Nov 18, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
205 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
