Question about Compaq Presario M2000 Notebook
Some vertical lines are runing on my laptop screen. may i know the reason for this and any solution.
  • Compaq Master
  • 11,800 Answers
If the lines are always there, looking the same then the connections to those columns of pixels are nonfunctional. Try to reattach the connector to the lcd panel in the laptop's lid. If this doesn't fix it then the connections are broken inside the panel and this is unfixable - you need a new one.
Posted on Sep 01, 2010
Vertical lines
It sounds like dead pixels in the LCD display. the only way to get rid of the lines is to replace the Display unit in the laptop. This can be a very expensive repair so I'd check it in with an IT professional first.
Nov 07, 2013 | Sony VAIO VGN-NS135E/S Notebook PC
Horizontal and vertical lines on ACER laptop
Hi there some how your laptop screen pressed & the screen is damaged. Just the option is replacing the screen. Another reason is over heating of screen by manufacturing default. Your laptop still under warranty so i suggest you visit the Acer service center & claim the damaged things if your screen does not have any over pressed symptom then. I hope you understand me. Thanks & waiting for your feedback.
Apr 02, 2010 | Compaq Presario M2000 Notebook
I have vertical lines on screen I have changed the whole screen assembley but lines are still thers , exactly in same place
Hey There,
The reason this happens is because the graphics card is either loose burned out or jsut needs to be cleaned... to clean it use a pencil rubber in the gold tips that connect it, blow on the card to remove any dust build ups and reconnect the graphics card when done (make sure its clipped in properly).... different brands of computers will do different things such as the different coloured lines and screens flashing red. My dell latitude 630 had green and blue verticle lines. Just follow what i said and it should be fine
Hope this will help you in Resolving the issue with the vertical Lines on the screen.
Cheers!!!!!
Vivek
Feb 14, 2010 | HP Compaq nx6325 Notebook
Dell 1720 screen
If you can see the vertical lines during POST, try to check the vertical lines in BIOS. If the vertical lines are there in BIOS, the only thing you can do is to replace your LCD screen.
Oct 31, 2009 | Dell Inspiron 1720 Notebook
Vertical Lines on Screen
Either the cable has come loose, or the display is going out.
I would call Toshiba and see what warranty is left ...
Jun 23, 2009 | Toshiba Satellite P100 Notebook
White vertical line
That is either a faulty ribbon cable to LCD display, or a defective lcd display itself.
In both cases tha computer must be taken apart and part replaced to fix the fault.
Parts are commonly found on Ebay, or can be ordered from toshiba.
Oct 10, 2008 | Toshiba Satellite A135-S4527 Notebook
Vertical lines in my laptop screen
I know not everyone has this ability, but if you can, go to a friend's house and hook up an external monitor to your laptop. You may need to use the function keys to switch from LCD to external, but if the lines go away on the external, you have a bad LCD. If the line shows up still on the external, then your problem is either:
a) video driver (free, easy fix)
b) bad inverter (video 'outputter') ...approximately $10-50/varies + labor costs to replace
c) bad video card/motherboard ...usually between $200-$400 + labor to replace
Hope this helps - please be sure to rate my answer :)
Sep 29, 2008 | Computers & Internet
There can be 3 possible reasons for this
1)Screen connector cable is loose. You can try to re-seat it and see if works.
2)display card problem. Connect your laptop to an external monitor and see if the problem persists. If it does not then
3)You will need to get a replacement LCD screen.
Hope this helps!
May 04, 2008 | Dell Inspiron 6400 Notebook
Sampo PME-42S6 W/red lines runnig through the picture
Try using a DVD player with Progressive Scan, it might work fine. I don't know what the problem can be but that's the only way I can see anything.
Jan 08, 2008 | Televison & Video
Gateway laptop vertical dotted lines across the screen
Sounds like a problem with the LCD assembly or cable. You may want to reseat the LCD cable at the LCD end. It could be a loose internal connector in the LCD assembly.
Ron-
Dec 13, 2007 | Computers & Internet
Compaq Presario M2000 Notebook Logo
22 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
