Question about Panasonic Lumix DMC-LS80 Digital Camera
My daughter lumix dcm fs62 was dropped on damp sand and now wont work , no power and lens out is it worth getting repaired thanks
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Sep 02, 2010
Lcd screen blank lumix dmc-fs62
While the displays of the DMC-F2 and the DMC-FS2 are the same size, they are NOT the same part. I suggest using a compatible part for the replacement.
Jun 11, 2013 | Cameras
Lumix dmc-fs12c
Lens errors (System or Zoom Errors on Panasonics) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Nov 12, 2011 | Panasonic Lumix DMC-TZ1 Digital Camera
Camera lens will not retract - sistem error (focus)
Lens errors (system errors on Panasonics) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Aug 28, 2011 | Panasonic Lumix DMC-LC33 Digital Camera
I have an FS15 and get the error message, 'system error zoom' the lens is not centred and does not retract. The camera has not been dropped and is c15m old.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 18, 2011 | Panasonic Lumix DMC-FS15 Digital Camera
Camera is saying to turn off and back on...i do but it still will not take a picture it only says this message.
Feb 09, 2011 | Panasonic Lumix DMC-TZ2 Digital Camera
I have the same problem with my camera. My lcd started showing that system error(zoom) after i dropped my camera while it was open. Do you think that i have any chance to repair it? Thanks
Jan 09, 2011 | Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital...
How to fix system error zoom
Dec 28, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
My daughter(5) dropped it and when they turned it on the lens came out and won't go back in.And on the screen it say "Focus Error".Can it be fixed or should I get her a replacement?
Lens errors (focus error's on Fufi's) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Dec 24, 2010 | Fuji FinePix A500 Digital Camera
Dropped camera which landed on zoom lens.
Have you tried manually trying to pull out the part that is pushed in?
Sep 24, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
Digital camera got dropped into the sand, and some sand worked its way into the lens and focusing system, and now the camera cannot zoom or focus, but still turns on and takes pictures i have a lumix dmc...
THIS SOUNDS TERMINAL, BUT YOU MIGHT TRY USING CANNED AIR LIKE YOU USE TO BLOW DUST OUT OF YOUR COMPUTER, AND SEE IF IT HELPS ANY. MOST OF THESE CAMERAS ARE MADE WITH THE IDEA THAT THEY WILL NEVER BE TAKEN APART OR OPENED FOR CLEANING ETC. SO, THAT IS THE ONE PROBLEM YOU ARE FACING. I DOUBT IF IT WOULD BE WORTH SPENDING THE MONEY TO SEND IT IN TO BE CLEANED. THAT CAN GET VERY EXPENSIVE IN A HURRY, PLUS TAKE A GOOD MONTH OR MORE FOR THE REPAIR. SORRY, I CAN'T HAVE MORE CHEERY NEWS, BUT THINGS LIKE THIS JUST AREN'T TAKEN INTO ACCORD WHEN THEY MAKE THESE CAMERAS. IF I CAN HELP MORE JUST REPLY TO:
ARCLIGHT1217
Nov 04, 2008 | Cameras
Panasonic Lumix DMC-LS80 Digital Camera Logo
59 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
