Question about Frigidaire Refrigerators
Frigidaire refrigerator is only 2 years old!!! Ice forming in freezer compartment, food not cold in the refrigerated section. I should have taken advantage of the extended warranties, but didn't. Please help
    Brigadier General:
  • 3,917 Answers
Hi
Please check the bellow link regarding your query…
http://www.repairclinic.com/Refrigerator-Troubleshooting#Thefreezercompartmentisicingup
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Posted on Sep 01, 2010
Testimonial: "This was not what I wanted to hear in terms of repair options, but your response was quick and comprehensive. Thanks."
Fridge section not cold, freezer section o.k.!
Normally, the cold is only generated in the freezer compartment, and then the cold is pulled or pushed throuch cooling tubes from the freezer section to the refrigerator section. So if your cooling tubes become blocked by ice (usually caused by a defrost circuit failure) then the freezer will seem to work fine but the refrigerator section will not receive the cold air it should.
Suggest you remove the food from the freezer section, then remove the shelves and then the back panel of the freezer. If there is a lot of ice on the evaporator then you should manually defrost the unit. Unplug it from the wall and use a hair dryer to melt the ice. There will be an entrance to a cooling tube right below the evaporator make sure the you keep blowing the hot air from the hair dryer down than tube until you can feel it in the refrigerator section.
If there was ice, you also need to troubleshoot the defrost circuit and find out which component failed. It is normally made up of the defrost heater, defrost thermostat and defrost timer and troubleshooting methods can be found in the tips section.
NOTE: There will be a lot of water to deal with when you defrost your freezer so make sure you are ready to handle it with buckets and large sponges or a wet/dry vac.
Jul 13, 2011 | Frigidaire Refrigerators
Water leaking on the floor
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. Make sure water drains when you pour it in.
Good luck! :)
Vlad
First Choice Appliance
Jun 03, 2010 | Jenn-Air JCD2290HES Side by Side...
Freezer ice cold but refrigeratoer side warm
Must adjust the food compartment settings to a higher level. If that does'nt do it in 24 hours .You have a faulty evaporator fan....The evap.fan distributes cold air from freezer to food compartment...Jack Arevian
Jan 24, 2010 | Frigidaire FRS26H5AS Side by Side...
After emptying the ice bin on 2 year old side frigidaire, the freezer is OK, but the fresh food side has stopped cooling. Any ideas?
check that the fan in the freezer is running,it circulates the cold air,if it isclose freezer door,open refrig. door lookto the upper left you will see where the cold air enters the refrig compartment and should fill air coming thruough vent this is a motorized unit and they sometimes fail,also check the return air hole located at bottomof refrig.sometimes get blocked by plastic bags etc
Jan 18, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Top freezer quit freezing. Refrigerator works.
Good day,
Yes, the cold weather is the cause.
Your machine is cycled off and on by the thermostat located in the fresh food compartment. When the fresh food compartment is satisfied, it will shut off the entire machine.
Any temperature below 55 degrees will reduce running time until the freezer will not function, or at best poorly.
Engineers designed domestic refrigerators to balance properly between 70 and 95 degrees. It should be in your user manual.
Thank you for using FixYa
Jan 12, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Frigidaire refrigerator. freezer part gets cold but refrigerator part does not get cold.
check your seal around the door, also check the air vents between the freezer and the fresh food section. The appliance has to be able to transfer air between the 2 compartments in order for the fridge to be cooled.
Sep 24, 2009 | Frigidaire FRT21H8 Top Freezer...
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
Refrig not cooling
Either the fan that blows cold air from the freezer compartment to the fresh food compartment is burned out or the door/flap that seperates the compartments is stuck or the linkage connecting it to the fresh food temperature dial is stuck or broken.
The evaporator coils are in the freezer compartment and air is blown from the freezer compartment to cool the fresh food compartment. For some reason, air is not moving to fresh food compartment.
If the fan is running, it could be something as simple as Ice blocking to door between the freezer and fresh food compartment. I know modern refrigerators are self-defrosting, but that's only the evaporator coils, which are defrosted by a timer and a heater.
Ice can form on passageways inside the refrigerator, like the exit of the ice maker and in this case, on the door and 'tunnel' between the freezer and fresh food compartment. It's free, and doesn't take a lot of time, so try completely defrosting the unit before doing anything else.
BE SURE to keep the doors open, as odors can form as particles of food are allowed to defrost that may have been frozen in an ice pack for months or even years. Clean the interior of the refrigerator while you have everything out and reset the controls to normal settings.
If this doesn't help, there may be a mechanical problem with the air transfer control flap/door that will need to be fixed.
Hope this helps.
Jun 10, 2009 | Refrigerators
Sub zero refrig - ice forming inside
The solution posted previously is TOTALLY WRONG. A Sub Zero ref doesn't have a heating element in the fresh food section. Only in the Frozen food section. It has 2 totally separate systems for each section. 2 Compressors and 2 evaporators. They share a condenser. If you are having ice build up in the refrigerator then the problem you are having is a refrigerant leak in the fresh food evaporator. You need to have a certified tech come out and replace the evaporator in your refrigerator section of your Sub Zero. Not sure what you are asking about the thermostat.
Oct 12, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Refrigerators Logo
284 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
