Question about Kitchen Ranges
I have a whirlpool acubake oven model rf368lxts2 the display panel does not work unless you turn on one of the burners... help
  • pepler May 10, 2008
    you are the best! I reset the breaker twice and it fixed it!!!!!!
  • 117 Answers
Make sure you have 220v
That happens when just one fase works(110)
Ck your breaker box or power cord behind the stove
Posted on May 10, 2008
I have a Whirlpool electric acubake wall mounted double oven which is 15 yrs old. Most of the time the digital controls work fine. Twice now the digital display has gone totally dark. An hour or so...
Anonymous, we're sorry to learn that your Oven isn't heating. We will be glad to further review your concerns. Please email us at Whirlpool_Reviews@Whirlpool.com with your name, contact number, address, model and serial number.
Oct 23, 2017 | Whirlpool Ovens
Hi OldTech, Whirlpool Acubake electric oven stopped working after it suddenly displayed a flashing F2EO error message accompanied by a persistent beep. I unplugged and plugged it again. Thought it...
Hi
F2-E0 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 21, 2011 | Ovens
How do you change the key pad from celcius to ferenhite on my whirlpool acubake oven
Look for the button marked "Precise Clean" in the upper left corner of the control panel.
Press and hold this button for five seconds until the display reads "Temperature Unit Celsius.
Release the button and push it again for another five seconds until the display shows "Temperature Unit Fahrenheit."
Push the "Off/Cancel" button to lock in the Fahrenheit setting.
Jul 10, 2011 | Whirlpool SB160PEE Gas Single Oven
My oven light on my acubake whirlpool oven will not turn off it just beeps
Hello & Welcome to FixYa
The beep sound in oven is caused when either the door latch mechanism goes bad or the control board itself is bad. First check the door latch...if the problem is still there then replacing the control is recommended repair. Please get back to me if you have any other questions.
Kevin
Jan 16, 2011 | Whirlpool RBS275PD Electric Single Oven
When I turn the oven to 400 degrees for instance the temperature doesn't go to 400 degrees and the top element is hot, not super hot and doesn't get red. It is a Whirlpool Gols, Acubake system. Model...
Hi
Thanks for using FixYa. This indicates oven temperature sensor circuit failure. To resolve this issue you'll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 14, 2010 | Whirlpool Ovens
Whirpool Gold Acubake gas stove model GW395LEPB02 purchased in Oct 2006.When I am baking on 350 the oven jumps to 500 and smokes is everywhere. The number E2F3 shows up on the control board. What is the...
This error indicates the Oven temperature is too high,
You will need to replace the Oven temperature sensor (RTD).
This part can usually be replaced from inside the oven.
Jun 22, 2008 | Whirlpool Kitchen Ranges
Kitchen Ranges Logo
75 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
