Question about LG WM-2277HW Front Load Washer
Sensor Replacement RobinF, Do you mind stating how you replaced that sensor? Where is it located? I'd appreciate any info, thanks Mike
  • Andrew Lauder May 11, 2010
    what is the issue you are having?
    Champion:
  • 210 Answers
The Hall sensor is located on the stator. Unplug the unit. Remove the back panel exposing the rotor, using a 19mm socket, remove the rotor. The wire harness is clipped there so unscrew it. Using 10mm socket, unbolt the stator, carefully remove the stator. The hall sensor is located on the stator. Remove and replace it with a new one and reverse the proceedure. Be careful when putting it back, the stator has 3 plastic pins for alignment, and when putting the rotor back on watch your fingers as it pulls when you put it back. You may have to have someone push the basket back so the bolt will catch. If you want to test it first, here is some key information for you.
Sgt 48
Posted on Jun 04, 2008
    Novelist:
    Champion:
  • 261 Answers
Yes and Oasis is very much the same
Posted on Sep 04, 2008
Thank you ver much, works like new now!!! Saved lots of $$$
Posted on Jul 16, 2008
Whr the yaw rate sensor located in d4d 2004 Toyota avensis,and how I fix it , Thanks
Hi there:
I looked the information up as you listed it and for a sedan and the yaw sensor is located under the center console assembly. Is mounted within a couple of brackets in the console. Click the link below to enlarge IMAGE.
Visit this link to look parts replacement:
- Toyota Parts" ' "Toyota Accessories"'1stToyotaParts.com
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Nov 21, 2012 | Cars & Trucks
Price of a camshift position sensor
Hi there:
In this link can see Camshaft Position Sensor replacement around US$ 20.00
Jun 25, 2012 | 2004 Dodge Neon
For my o2 sensors the codes r bank 1 sensor1 bank 2 sensor 2 bank 2 sensor 1 bank 1 sensor sensor 2
Hi there:
Oxygen sensors are always numbered like this:
- Bank 1 sensor 1 or Bank 1 sensor 2
- Bank 2 sensor 1 or Bank 2 sensor 2
Keep in mind that Bank 1 is always the side of the engine where cylinder number 1 is located and, of course, Bank 2 is the opposite side.
On a 4 cylinder engine, there is only 1 bank and it is always referred to as Bank 1.
Sensor 1 is always the upstream sensor (The one located BEFORE the catalytic converter) and Sensor 2 is always the downstream sensor (the one that is located AFTER the catalytic converter.
Jun 21, 2012 | Cars & Trucks
Where is the fuel sensor located?
Hi there:
On Trailblazer, the Fuel Tank Pressure (FTP) sensor is located on top of the fuel tank, mounted on the fuel tank module.
Additionally, check attached in fuel pump...
...push in the fuel level sensor retainer (1) on the bucket.
May 20, 2012 | 2006 Chevrolet Trailblazer
How do you check an O2 sensor
Check this info: TEXT/O2_Sensor.html
Generally, this replacement part solve the problem.
Feb 24, 2012 | 1997 GMC Yukon
2005 chevy cobalt IAT sensor wire colors
Hi Mike:
The IAT sensor is an integral part of the Mass Airflow Sensor, located on the air filter box. The MAF sensor has 5 wires. The yellow wire with the green stripe is the output from the IAT and feeds terminal THA on the ECU.
Feb 15, 2012 | Cars & Trucks
What color are the wires for the IAT sensor on a 2005 Toyota Tundra 4.7L V8
Hi Mike:
Location of the crankshaft sensor 2008 corolla
Hi there:
Generally, CKP sensor is located near the bottom timing belt cover (on the top left). Check HERE for parts replacement.
Feb 14, 2012 | Toyota Corolla Cars & Trucks
Where is the maf located on 1996 mercedes benz c220
Look in the air intake system, there is a mass air flow sensor from the air filter...
Part Replacement link HERE
Feb 07, 2012 | 1996 Mercedes-Benz C-Class
LG WM-2277HW Front Load Washer Logo
290 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
