This bm2e213371 pcb is useing for online ups with lcd display. Lott of pcbs are not working. I need to service the pcb or need new pcb.
5 Suggested Answers
bearydude
  • 62 Answers
SOURCE: Broken lcd display Nikon sb-800 flash
You can order the part from NIKON or I can fix it for you .
Berrie Smith Camera Repair
bbmw@bellsouth.net
Posted on Feb 06, 2008
lars_olsson6
  • 3400 Answers
SOURCE: NO OSD MANU & SCHEEN DISPLAY LENOVO 19" MONITOR
http://www.lenovo.com/psref/pdf/mbook.pdf
here are a manual hope this can help you.
Posted on Jun 20, 2013
lpfaff1
  • 11573 Answers
SOURCE: Could the new main PCB and/or invert PCB be faulty or is TV completely waste of time? I replaced both main power & inverter or interrupt power PCBs now I have no power at all.
Liza-Maree; sorry all boards not created equal , you may have gotten faulty parts. Always make sure to ground yourself before doing this work.
press the helpful button
Posted on Jan 26, 2016
  • 3828 Answers
SOURCE: If servicing records show that equipment manufactured after July 2, 1979, was serviced with fluid containing PCBs, may I still assume the equipment is non-PCB?
depends on the level of PPM PCBs
and questionable equipment used to manufacture fill fluid containing PCBs after any year
at a higher than industry stds .....should be de contaminated or disposed of correctly
Posted on Aug 02, 2016
Aug 02, 2016 | XPLOSIV Pop Cap Games - Con/Term...
How do PCBs get into natural gas pipelines?
start at the drill area and work back
gas at a depth behave differently than when being piped from the field
so will have all sorts of contaminates not just pcbs
when you get time.. to do a crash coarse on geology of a gas field
the gas is extracted from naturally formed (lets say gaps )
between certain types of the rock formations or layers
that is able to keep natural gas fields contained
can also be from a contaminated water table within the path of the drill hole
Jun 17, 2016 | Indesit Repair Pcb / Module Widl102
What assumptions apply to silicone-filled transformers manufactured prior to July 2, 1979 and after July 2, 1979
Silicone dielectric fluid was manufactured not to contain PCBs. There is no assumption applicable to transformers known to be silicone-filled while in use, regardless of the date of manufacture. These transformers are regulated based on their actual PCB concentration. It is possible the transformer could have become contaminated during servicing with fluid containing $50 ppm PCBs
May 26, 2016 | Hotpoint Repair PCB / Module for WF530...
Jan 26, 2016 | Cars & Trucks
I have a Lg 42" lcd tv (42LG3000) TV is wall
White screen with good audio. before buying pcbs & such. try my repair method.. you need to get the lcd unit off the facia & then remove the front lcd metal frame. at the top of the screen you have 2 thin pcbs - chances are that the ribbon cable got at least one track unbonded. first off put some double sided tape under the pcbs to stick then to the frame - that'll take the bend out of those pcbs !! next put cellotape over the ribbon cables. i then cut 6 pieces of sponge 15mm thick & wide as the ribbon cable & glue to the tape on the ribbon at what would be the top edge of the screen (covering the point where ribbon meets pcb).. put the metal frame on top edge first to keep the sponge straight !! put it back together & fire it up. if it still aint working you may need a tcon pcb (little square one at the top). this fixed my 42lg3000 but can work on others with same fault !!
Mar 16, 2011 | LG 42LC2D 42 in. LCD HDTV
I have a tascam dr7 with a device error 2 code...I used a 5v power supply not from tascam for quite a lot of time.....it eats batteries like crazy. Device error 2...what is it?
Device Error [2] is "memory bus error". There is nothing that you can do to fix it. There are two PCBs in Tascam DR-07. This is the bigger one that has LCD display and all control buttons. Your best bet is to find a broken one that does not power up at all (the smaller PCB - which host the CPU - is bad) then swap the PCBs.
Dec 16, 2010 | Tascam DR07 Digital Voice Recorder
I NEED PCB BOARD FOR HOTPOINT WF865 WASHING MACHINE
I have checked the Hotpoint web site, and a pcb is £114.00.
You also need the eprom which plugs into the pcb,this is another £24.00, and is unprogrammed, this means that it is a blank memory chip, and has to have the programmes put into memory.
This is something that only Hotpoint can do, so you have to add the cost of calling an enginner to the cost of the parts.
This as you can see, makes it very expensive to repair.
It would be in excess of £200.00.
There is one other alternative, and that is, if the washer is less than 5 years old, then you should be covered by the Hotpoint 5 year part guarantee, but you would have to confirm this with Hotpoint.
It would certainley be cheaper to do it this way.
Plz rate my solution.
Thanks,
Jan 11, 2009 | Hotpoint Ultima WF865 Front Load Washer
Brother Fax 2820
sorry to say but the new board needs to be flashed. Only can be done by a authorized service center.
Dec 17, 2008 | Brother IntelliFax-2820 Laser Fax
Self Repairing the K-jam
I have just replaced the touchscreen on my wife's K-Jam, not a trivial job but not as impossible as some postings I had read. Also I was able to replace just the touchscreen and not the combined LCD/touchscreen which most people have said you have to. Basically you need to start from the back of the PDA (battery side) and work forwards with the last thing you get to being the touchscreen you need to replace. I do not recall exact order of dismantling but it was fairly obvious once you got into it. I started with the sliding keyboard closed for this. What I do remember is that to start off you have to remove a snap on cover above the camera, removing the external area connector cover first and then gently prising with a jewellers screwdriver. Then remove 4 screws and gently prize the main unit into two. (Obviously at this stage battery, SD card, etc are all out). You will find on one side the unit the two parts are now joined by a small flexible PCB, this is into a connector which you can release by very carefully lifting up a small plastic tab along the top of the connector (note this is different to some connectors I have seen like this where you have to slide a section of connector out - on this one (and one you come across later) you have to flip the plastic tab up by 90 degrees. Once you have done this you can carefully pull out the flexible PCB. This phone is very layered and I found it help to put each 'layer' in a bag with it's associated screws, etc to make life easier later. You are now left looking at the main phone PCB which if I remember right will now be loose. Carefully lift and remove the PCB. you will find it attached by a flexible PCB that goes to the display unit - this is a push in connector which can be carefully removed by gentle prising. You now have just the display unit and the back part of the main unit. Slide the keyboard slightly out and then remove the 4 screws which secure the main unit to the sliders. You should then be able to separate the screen unit from the main unit and finally get to the fixing screws you need. Undo the 4 screws that hold the screen unit together. The rear of the screen unit is still clipped in place and you need gentle prising to remove the back from the screen. Memory begins to fail me here but again I think there were 4 screws securing 2 small PCBs for the lights and the navigation buttons which I removed and removed the PCBs and the navigation button block. Somewhere in all of this there was also a second slightly larger version of the flexible PCB connector that required its tab lifting 90degrees to remove the connector. You should now be able to lift out the LCD and touchscreen as one unit - and now comes the fun bit. The touchscreen is bonded to the LCD and the connector for it is resistance welded to another flexible PCB. I first (and very carefully) lifted the sticky tape that is protecting this connection. I then (even more carefully!) cut the ribbon that goes to the touchscreen leaving a tab attached to the screen. By very careful lifting it was then possible to get the 4 way flexible PCB that goes to the touchscreen to separate from the main section without damaging what was left - if you have a hot air gun with a micro nozzle that may be an alternative. To separate the touchscreen from the LCD I used a sharp scalpel to gradually cut between the glass of the touchscreen and the bezel of the LCD - it is only glued to the bezel and not the LCD itself but be very careful not to damage the LCD surface. After a lot of careful sliding around all sides with the scalpel the touchscreen came off in one bit. I then positioned the new touchscreen and used what was left of the original double sided tape on the bezel to hold it in place (after removing the protective film from the toucscreen). If you cannot get the touchscreen off neatly you may end up having to carefully scrape the bezel clean and then use new double sided tape - goes without saying do not touch the LCD surface. Now you need to connect the new 4way flexible PCB from the touchscreen to the main LCD unit. For this I first taped it in the correct position, leaving the end to be connected exposed - NOTE for the touchscreen I sourced (from Hong Kong) the connector pitch was slightly out but there were positions where the connectors lined up but did not short out. Really scary bit - using a VERY small tipped soldering iron and low melting point solder and VERY short application times I was able to remake the connections onto the new flexible PCB for the touchscreen. Basic technique was to get the solder on the old part of the connection on the main LCD to flow and then dab in a little fillet of solder. Again if you have a miniature hot air gun it may be possible as well. Check you have continuity on all 4 and no shorts and then re-assembly is a reversal of the above. Nothing too tricky in re-assembly but getting the connectors back in before flicking the tabs back down is a bit of a fiddle. All a little scary but in my case the repaired unit is now working fine. The main risk is that you damage the LCD unit either when separating the touchscreen or soldering the connector (which is a little bit of a fudge to be honest but works). However given that any official repairer will replace the LCD and touchscreen anyway you don't have that much too lose - especially as the official repairer told me they have no parts to repair it with anyway til at least December. If this sounds too tricky or if you do damage your screen there is someone on ebay selling combined LCD/touchscreen assemblies for about £70 and offering a fitting service (although to be honest fitting a combined unit is fairly trivial as long as you are careful. Hope this helps, Russell
Sep 27, 2006 | i-mate K-jam Smartphone
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
