I have a 5 year old Carrier 2 Ton hvac system and heard that the CK5B N Coil has been know to have issues. I had the system looked at a year ago and the coolant was low. They added coolant but never looked inside the unit. They came out in the winter for a second service call and didn't find much loss of coolant. (probably because unit wasn't used in the winter) Just last week same issue started and company came out and finally after pushing to have the unit opened so that you could see the coil it was found to be very deteriated/rusted. The sensor tool did not go off with a high amount of coolant leak detected though. They did not find any other visible signs of coolant leak outside or inside. Just the large deteriation. They are charging me $500 to replace the coil. Is that a good price? It should include the recharge of coolant. Plus a $89 service call. I'm wondering why they did not open/find this last year when I signed on for the $160 service agreement for a twice of year check? I'm hoping this coil (under warrently, the $500 is labor only) will fix the leak issue? Is this Carrier Coil known to be defective? The level of deteriation after 4 summers use is like it was sitting outside in the rain for all those years. Parts of the metal can be just pressed off so rusted. Seems like parts and labor should have been warrentied by Carrier? I can't find a recall or anything on this. Any thoughts to what I'm doing and paying is the right direction?
  • 107 Answers
We have noticed some of these same problems in TEXAS.. the coils have a potential to leak earlier than their expected lifetime but the problem is not severe enough for government to force a recall unfortunately... Maybe in 10 years... grrr right ? .. That price is good for materials and labor to change the part under warranty and most system checks for service agreements do not include looking for a leak.. usually just cover a pound or two of refrigerant.. I hope this helps.. the new coils are awesome..
Posted on Sep 01, 2010
  • jmdatl123 Sep 01, 2010
    Thanks so much for the comments! Guys installed the new coil today. New pressure gage included on new coil! When old coil was pulled out there was a few small holes in the back. they flushed the line and pressurized the line and the run from HVAC to outside tite. So hopefully this will solve this over a year issue. I'm shocked that a service contract wouldn't include looking for a leak. Strange. Just putting more refrigerant in is a patch and not a solution. If they opened the panel last year they would have seen all that deteriation and it would have been done already. Thanks for the comment!
Can I fix my Carrier Heat Recovery Ventilator HRV?
Check to see if the thermostat is set for blower .if thermostat is off unit would not do anything
Jun 01, 2017 | Carrier Heating & Cooling
Bad condenser unit GOODMAN
it is a 3 ton condensor you still can buy r22 freon condensors new but they have nitrogen charge and its expensive to charge I recommend to go with 3 ton goodman condensor which is new 410a puron and also change indoor coil and flush the line set so you dont endure the high cost of new copper lines these new systems come with 10 years warranty and the r22 systems come with only five years
Feb 26, 2013 | Heating & Cooling
Condenser fan replaced one year ago, fan not turning but can hear motor
the answer to your problem is most likely the motor start capacitor. A AC motor can run in both directions. The start capacitor is used to cause the current to lag behined the voltage which determines the direction the motor will turn. Its posible the start and run capacitors are in one can. so changing one will change the other. However look for a wiring diagram. Do not asume that both capacitors are wired in properly. They may be fighting one another causeing premature failure.
Sep 18, 2012 | Carrier 38CKC036 Air Conditioner
Going to replace hvac system. Don't know what
According to the model number it is a 2 ton or 24,000 BTU unit. It is very important that you change the indoor coil as well as the outdoor section, due to it being a 10 SEER unit, and the new basic systems are 13 SEER, the old coil cannot handle the higher SEER ratings.
Rheem and Ruud are the same equipment, just 1 number different on the model number.
I hope this has helped, please rate the new guy :)
Please contact me if I can be of any further help to you.
Have a great day!
Sincerely,
Paul Gibson
Apr 04, 2010 | Ruud Matching Split Air Conditioner
Compressor kicks out and it's new
First of all, clean your outside coils so that you are assured of good cooling air. The compressors have an overtemp device that is usually internal to protect them against heat. If you have an air compressor use it to blow out the coils good. If the compressor will start, the capacitor is good so it sounds like a cooling problem with the compressor
Jun 25, 2009 | Ruud UAMB Air Conditioner
I have a Carrier 4 ton unit model number 661CJ048-A which is charged with R-22 capacity is 9,25lbs. It has developed a leak at the evaporator coil. It has rust on the coils which from what I understand...
First your system is 22 and 134A is a auto AC refrigerant. I have never seen it used in residential ac. I have been in AC business for 45 years. The new refrigerant is 410A or Puron. But you can not use it. Your outside unit is set up for 22. Mix 134A with the oil used in a 22 system is not done. You need to get the correct coil for your system. They are going to make 22 for years. They now have a Drop in for 22 called NU22. I know times are tough but you may have to get a Service Tech anyway.
Jun 09, 2009 | Whirlwind FH-778 Air Conditioner
Coil leaking freon on the inside unit. Estimate is $2,100!
If indeed your evaporator (indoor) coil is leaking, the best option IS replace it (it may not even BE repairable). If you live in the USA and your furnace is getting old, a new ultra high efficient SYSTEM that qualifies for the tax credit would probably be a better option (Obama will pay 30%).
May 09, 2009 | Carrier Heating & Cooling
Carrier air handler tonnage?
That is a fairly large difference. It is usually ok to have the inside evap. coil and blower up to 1 ton larger than the outside condenser. That will make the unit slightly more efficient as well as less likely to freeze up on low airflow situations. It is not recommended to install a new condenser on an old evap coil. There has been a lot of changes to the design of the coils in the last little while. For example a 10 year old 2 ton coil may only have 3 cubic feet of volume but a new 2 ton coil may have 4 cubit feet of volume.
There are many factors that may have infulenced the decision on what size condenser to install. Many of which can only be done by visiting the home and doing alot of work, checking the duct sizing bioth supply and return, inspecting the insulation and windows of the home etc. etc. Most of the time that never gets done. You can blame the contractor for not doing a complete check, but at the same time you can blame the customer because many contractors that are that good loose the job to a cheaper bid that did not no any of the research. It is a catch 22 for everyone involved.
There is ALOT more to sizing equipment that many people think, sadly that also includes many HVAC contractors. Way too many people use "rule of thumbs" or flat out "guess".
Sorry for the rant but your queston can only be answered by a good well educated HVAC contractor visiting your home. That type of a contractor is getting hard to find these days in such a price competetive world.
Oct 14, 2008 | Carrier Heating & Cooling
Central air and heating being installed
2.5 ton should be able to handle up to around 1750sf house. Price looks good especially if having to do ductwork too!
Jun 15, 2008 | Carrier Heating & Cooling
Carrier evaporator coil
I recently contacted Carrier Corp after our routine annual HVAC check on our residential system indicated that our 4 ton AC unit and 3 ton unit had leaking evaporator coils.
They basically told me to shove it in a very curt letter - In other words even though a leaking evaporator coil is a manufacturing defect they will not offer any financial assistance in replacing the failed evaporator coils.
I spoke to several HVAC engineers and they indicated Carrier has a high percentage of evaporator coils and compressor failures on residental HVAC systems.
The copper wall of the evaporator coil is being drawn thinner than in earlier years and the R22 being acidic slowly eats through the copper tubing.
Evaporator coils should not fail according to the HVAC Engineers if properly manufactured.
The Bear
May 19, 2008 | Heating & Cooling
Heating & Cooling Logo
122 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
