Question about RCA DRC277 DVD Player
Everytime I put in a disk in the player it searches and comes up no disk. I tried using my cleaning disk and it doesn't even acknowledge it. The dvd player is a RCA DRC277
    Genius:
  • 1,175 Answers
Hi...The only other thing you can do is:
UNPLUG from the AC..Take the top case off and see if there is any access to the laser lens..( very small "1/8th inch" clear plastic)
If you can , clean it( VERY lightly) with swab of 90% alcohol
Posted on Sep 01, 2010
Toshiba DVD SD73000KU will not recognize ANY disk
hi
have you been tried to clean the lazer lens with a cd lens cleaner. if doesn't work you can do with manual cleaning using a fiber cloth moist with alcohol damped gently the laser lens which may be dirty causing not to detect a disc. now if those tries still doesn't work your last option to make an adjustment on the speed settings of the drive motor. at the lower portion of the lens their is a trimmer adjustment, you can used a small flat head screw driver then try to adjust the trimmer just a little bit counter clock wise, make sure the player is unplugged for safety. then try to plugged it and turn on the player, insert now a cd and observed. if the motor doesn't rotating, removed then check if worn out, replaced a new one if needed.this will worked now.
hope this will helped thanks for consulting the fixya.
Dec 25, 2011 | Toshiba Televison & Video
My cd and dvd player is not working. i have a toshiba laptop with windows vista. please advise. thank you.
If by not working you mean that the drive physically works fine, will eject and stays closed when you put a disk in, but does not read the disk or gives errors when it tries, then a simple cleaning could be enough to revive it. A lens cleaning cd is easy enough to find at any local department store and running this in the drive should take care of any problems reading disks unless the disks themselves are damaged.
If however you meant that the drive doesn't respond to eject requests, either when pressing the button, or choosing "eject" in windows, then the hardware itself is at fault and will need to be replaced. The drive is easy to swap out with a replacement or you could even get a portable external drive and only connect it when you actually need to use the disk. Also if the cleaning suggested above doesn't help, and you are sure the disks you are trying are not dirty or scratched to heavily on the bottom, then a replacement drive would also be in order.
Sep 07, 2011 | Microsoft Windows Vista Ultimate Edition
My playstation 3 has recently developed a problem with reading certain disks. Some blu-ray's I put in it will not even acknowledge that the disk is in the system and some of my games freeze up when I...
You need the DVD DR. cleaning disk that is made for blu-ray players...I've used my disk over 20 times now to fix drive errors in ps3 systems!
Please rate if this helped!
Mar 04, 2011 | Sony Playstation 3 (PS3) Console
PD5203 says no disc when disc is in the player
If this problem occurs only at this cd it's a disk problem. If it occurs on various disks try using a cd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alcohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case you can, use a Q-tip with isopropyl alcohol to clean up the cd lens manually. In case this doesn?t solve your problem, the cd player needs laser lens replacement by a technician.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 07, 2010 | Emerson PD5203 RadioCD Boombox
RCA am-fm steroe radio / dual cassette recorder & compact disc player model rp-9518A. when I try to play a disk it stops and then restarts again at all 5 stations need to know what may be the cause...
I assume that the problem occurs on the cd player. If this problem occurs only at this cd it's a disk problem. If it occurs on various disks try using a cd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alcohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case you can, use a Q-tip with isopropyl alcohol to clean up the cd lens manually. In case this doesn’t solve your problem, the cd player needs laser lens replacement by a technician.
Thanks and regards
Stelios
Sep 07, 2010 | Audio Players & Recorders
My Sony 5 disc dvd player stopped acknowledging that there were disks inside the player. It just says "NO DISC" and won't read the disc. I tried putting in a cd cleaning disc, but the machine won't run...
I sent a premium offer to solve dvd player issue but got no response so far, not sure why.
I'm Sony tech and can be helpful to resolve this problem.
Aug 22, 2010 | Audio Players & Recorders
Everytime put a game in it doesn,t read have tried cleaning disk but still doesn,t read disks
This can be caused by a dirty laser in the drive. Try cleaning the laser with a q-tip and alcohol. If this does not fix the problem, the laser may need to be replaced. Contact Sony and see if the unit is still under warranty.
Feb 05, 2010 | Sony Playstation 3 (PS3) Console
Disk drive not reading disk
Try using another computer or laptop to rip the CD if you encounter the same problem then the cd is unreadable or dirty try cleaning the cd
Nov 18, 2009 | Acer Aspire 5520-5908 Notebook
CD player acknowledge CD, starts to play, then stops
I belevie you have problem in laser assembly it might not worth to repair it
Cheers
Dec 10, 2008 | Audio Players & Recorders
RCA DRC277 DVD Player Logo
65 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
