Question about Toro Electric Ultra Blower/Vac 12 Amp
Toro leaf blower with vacuum bag how do I install bag?
  • 5 Answers
SOURCE: I need instructions for using my Toro vacuum/ mulcher attachments
Mine is a Black & Decker so I don't know if this will help. On mine there is one release button near the top of the handle. You press that down to release and remove either the blower tube or the vacuum bag assembly, whichever is currently on -- you can't have both! Then you engage the attachment you want to put on into a pivot at the bottom of the handle assembly, press the release button and engage the attachment at the top.
Posted on Nov 30, 2008
kachbibi1
  • 979 Answers
SOURCE: craftsman leaf blower/vacuum
I have a Craftsman and you should have a separate attachment to it. Your motor will turn the same, instead of pushing air out the pipe, you will draw air in through the air intake.
Posted on Feb 03, 2009
highspeedsan
  • 61 Answers
SOURCE: I have a Weed Eater Barracuda leaf blower but
http://72.3.225.179/manuals/545117523e.pdf
Copy and paste. It will take you to .pdf for your Barracuda
Posted on Apr 30, 2009
rwvanlue
  • 486 Answers
SOURCE: Toro leaf blower Model 51591 from 2003 has started
Sounds like a piece of wood is caught under/between the impellor and the case/housing. When removing the impellor, you may find it has a left hand threaded nut.
Posted on Nov 13, 2009
vincob
  • 718 Answers
SOURCE: I bought a Toro ultra electric blower vac (model
Common sense tells me it is not that hard you probably do not need an instruction manual, does life come with a instruction manual O Yeah the Bible. Believe in yourself review the situation, think it over you can do it!!!!!!!!!
Posted on Nov 25, 2009
After using Toro leaf vacuum for over an hour, it now has no intake. The motor runs, but there is no suction.
the bag is clogged,leaves dust will clog bag and you can't get any vacume do to no exhaust through the bag
Nov 17, 2016 | Toro Garden
How to repair Toro Super Blower no longer blowing, only vacs/intakes?
when you remove the vac part there should be another "grid type" part that snaps in place of the vac tube. This engages the safety switch and keeps your fingers out of the impeller.
Oct 05, 2014 | Toro 51592 Super Blower Vac 3-In-1...
Toro model 51575. Was using it as a vacuum and it just shut off. Checked breakers ...all ok. Plugged it in direct to outlet and still nothing. What might be the problem?
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers
Apr 06, 2014 | Toro Blowers Rake and Vac - Electric...
Blower does not turn on
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Apr 03, 2014 | Toro Garden
Brushes on the motor are bad. where can I buy them
Sounds like the brushes are worn out and in need of replacement, if available.
Nov 04, 2011 | RTO Weed Eater Electric Barracuda 2595...
Need carbon brush replacments
google for sources. In the 80's i was employed by a co that probuced brushes according to specs. We received them in bags, or envelopes, etc. If you cannot find them through the orig. mfgr., send the remaining brush or the holder, with as much of the brush as is remaining for proper dim. estimate and brush composition. some brushes have the composition of dry charcoal. while some such as "EGO" can substitute for a very soft pencil.
Nov 26, 2009 | Black & Decker Leaf Hog 12-AMP Electric...
We have a leaf blower 51587 and I don't know how to get the blower on instead of the mulcher. Thank you.
Go to the Toro site I listed below. Choose your model and it takes you to a very neat interactive manual. Basically, the blower tube goes where the bag goes. Just about the extent of it. Good Luck.
http://www.toro.com/home/customercare/interactivemanuals.html
Oct 25, 2009 | Garden
Vacuum or Blower?
* Blowers perform the single, simple function of blowing material. * Blower/vacuum combinations combine the blower function with a vacuum feature. Leaves or debris can be directed into an attached bag, which makes this type of unit great for vacuuming leaves from shrubs. An additional mulching feature is available on some leaf blower/vacuums. Mulched lawn debris can be used in compost piles or bagged for disposal. Most convert easily from blowing to vacuuming mode.
Aug 27, 2008 | Toro Lawn Mower With Toro Power Tools
Toro Electric Ultra Blower/Vac 12 Amp Logo
222 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
