Question about Kenmore Dryers
My dryer make the noise like it is coming on but does not turn. and when you hold the on button it cut off i don/t know if that make sense, but in other words it is not working.
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 04, 2010
Start button starts dryer and dryer stops when button is released.
Ge dryers have a belt sensing switch inside that won't let the dryer run (just as you describe) when the belt breaks or comes off. My guess is you broke a belt. With door open---hold in button door switch and hit the start switch to get it too run a few seconds. Watch the drum and see if it turns. My guess it will not. Belt is a long skinny band that goes all around the drum outer area and then down around the motor.
Jul 09, 2015 | GE GTDP180GDWW Gas Dryers
Dryer doing nothing
Your dryer is sensing a problem, but not being specific about it. Check that you can turn the drum first to make sure that it hasn't wegged in place. But it sounds more like a control board - from the limited indications you are giving us.
Jun 20, 2012 | Frigidaire Electric Dryer
Kenmore dryer Tub will not turn freely. Feels as if it's hung up. When you you press the start button it will just make a humming noise.
A guess, sounds like you are hearing the motor running but no tub belt as it is probably broke. If you are asking then you probably don't know how to fix it so you should call a repairman. Or the tub guides are wore out either way a repairman can help.
Nov 22, 2011 | Kenmore Dryers
Dryer won't start. Lights on panel come on and everything seems ok until you hold the start button. You then hear a click and the sensing light comes on but the dryer does not start.
heatman101
Dec 26, 2010 | Whirlpool GEW9200L Electric Dryer
I get no response when i push the start button of my dryer. Only a humming noise.
unfortunately the noise is your motor,try spinning the drum by hand,if it spins it's the motor,if it's hard to turn you could have something stuck in the blower wheel or the belt could be hung up on something that's not letting the motor turn,also try spinning the drum and hold the door switch in and have someone else hold the start button in to see if it starts,sometime there's a flat spot on the motor and you can get it to start this way but if it happens again you have to change out the motor or get a new dryer,good luck let me know what you find and if you need more help let me know
Aug 05, 2010 | Kenmore 62802 Electric Dryer
Dryer not starting
Sounds like a bad motor. A DIY job of about 3 hours and $125.00 for a new motor.
Dryers are pretty easy to work on if you have some tech ability and some common sense.
Mar 29, 2009 | Maytag Dryers
Humming noise when i press the start putton
When I push the start button it would hum if I hold the button to long and then it would cut off.
Jan 27, 2009 | Whirlpool LER5636P Electric Dryer
Dryer problem
You need to listen for the motor working ? Open the dryer door hold the door switch in and start the dryer . A buzzing sound may indicate a bad motor. If you hear a slight spinning noise ,it may just be the belt.
Sep 24, 2008 | Dryers
Dryer wont start
Commonproblems...blown house fuse, broken belt ( on some models )...door switch...*thermal fuse open (venting needs attention )...broken or burnt wire....timer....motor, in order from mostcommon to least common. * If you find a blown thermal fuse, always clean, change, adjust the ventingsystem and vent hood first, then it is often a good idea to replace the operatingthermostat at the same time. This is a picture of some modernthermal fuses.
I hope this will solve your issue.
Good Luck
If my solution proves useful please accept it.
Regards
Arjun
Sep 07, 2008 | Whirlpool GEW9200L Electric Dryer
Dryers Logo
24 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
