Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore 106.50522102 SidexSide Fridge and Freezer
Kenmore 106.50522102 SidexSide Fridge and Freezer are both warm. Husband moved the temp control for both without looking at the directions next to the knob "Turn one control at a time within 24hrs". He also moved it slightly (he said) to cold, not colder like he wanted to. Thier is air being blown into the freezer still, but it's not cold. There is also a clicking sound every now and then. (Kind of like the click you hear when you're preheating the oven). Any information would help. Thank you!
SOURCE: Kenmore fridge not cold
If you hear a clicking sound and the comp. kicks on then off , it could possibly be relay for the compressor or low of freon.
Posted on Dec 11, 2007
  • 93 Answers
SOURCE: fan running, weak air, fridge not cold enough, freezer working fi
it sound that your fridge is cloged of ice if so defrost it by unpluging it for the day to defrost completlyb with freezer door open then replace defrost timer if to much ice is formed on coil air does not cuculate properly thanks from gille
Posted on Mar 15, 2009
tborn6
  • 700 Answers
SOURCE: Whirlpool refrigerator. Freezer temp. -20, fridge temp 38. unit
you need to probly replace the thermostat for the freezer.
Posted on Apr 07, 2009
  • 159 Answers
SOURCE: Fridge is cold and freezing up no matter what the temp control is set, and freezer is also overly cold freezing even stored liquor
it sounds like the thermostat. but check the defrosthing element also
Posted on May 16, 2009
woodchuck789
  • 4070 Answers
SOURCE: I just bought a used Kenmore bottom freezer
Yes, you are correct in assuming that.
Posted on Aug 13, 2009
Kenmore 596.69142992 bottom freezer temp fluctuating from 10 to 40 degrees. Refrigerator maintains steady 40 degrees. No ice on coils.
The freezer temps fluctuate that much, I am thinking your cold control is going bad... Kenmore Refrigerator Temperature Control Thermostat W10752646
You can clean the fridge with warm soapy water and/or a hand steamer
Jun 29, 2016 | Kenmore Refrigerators
Fridge and freezer not cold. Ice melting.
Need to replace circulation fan in freezer,
Remove plastic bump out in the back of the freezer, to access fan...
Mar 02, 2015 | Kenmore Refrigerators
Kenmore refrigerator side by side. EnergyStar sticker says model series 56541-56551. Freezer side cold; fridge side between 50 and 60 degrees. I unplugged for at least 2 days for ice to melt. Fan at...
If there is ice built up on back inside freezer wall, you have a defrost problem. Either defrost heater, defrost thermostat, or defrost control (timer or Board) is bad.
Sep 05, 2017 | Kenmore Refrigerators
Side by side refridgerator part too warm
Make sure the small door between the freezer and fridge is open. It should be at the top towards the rear on the wall between the fridge and freezer. Thermostat controls its open/closing. And make sure freezer is in fact freezing and you don't just have residual cold in it. Freezer should be about 0 dertees.
Feb 05, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore refrigerator Freezer is cold but fresh food side is warm
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Jan 26, 2010 | Kenmore 57029 Side by Side Refrigerator
Freezer too cold--refrigerator too warm
If the cold control is not adjusting the temp when you move it, that can be part of the problem.
Jan 26, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Amana bz22rw fridge temp fluctuates & is a little warm - freezer is ok should i replace the fridge temp control or the damper
Temp control = controls run time of the compressor and temp of freezer.
damper and cold control = control how cool the fridge is...
also check you fan speed and air flow to the fridge.
Sep 19, 2009 | Amana Refrigerators
Freezer thawed, fridge warmed
The compressor is short cycling, or not starting. being purchaced in 2004, the compressor may be under a 5 year part and labor warranty with SEARS ...BUT GOOD LUCK!!!. Find ur receipt and warranty. read carefully and hold them to it.. empty it and unplug to be safe
Aug 25, 2009 | Kenmore Refrigerators
Whirlpool sidexside m-gd25dq does not cool properly
Sounds like bad cold control. Replace it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 15, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
129 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
