Question about Canon PIXMA iP4000 InkJet Photo Printer
When I try to print I get the following message: "Error Number: 5100 A Problem has occurred with the printer mechanism. Cancel printing and turn off the printer. Wait a few moments, then turn the power back on. If the problem persists, contact one of the service centers." Can this be fixed? If so, how? Thanks.
    Brigadier General:
  • 10,406 Answers
Did you follow the "cancel...." instructions?
Did the problem persist?
Did you contact your local CANON office, and ask for the location of the nearest authorized CANON Service Centre?
If so, what did they say?
Is your printer still under warranty?
Have you exercised the warranty, to get it repaired/replaced?
Posted on Sep 01, 2010
Canon LBP6000. Data transfer to the printer timed out, or a transfer error has occurred. Click [Resolve Error] to resume printing, or click [Cancel] after pausing the job, then try to print again.
Best to un-install the printer drivers, softwares related to this printer. Go to Canon.com and download the latest drivers and software. Connect the printer to the computer and let the computer recognise it and then install the drivers from your download. You can also check if there is any damage to the cable as this could also stop the communication between the computer and printer.
Dec 09, 2013 | Canon LBP6000 Laser Printer
I have a Canon 4300. It says "Error Number : 5100
Turn off printer.
Remove both the cartridges from the printer. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches.
Return the cartridges and turn on the printer.
Error 5100 means that the cartridge can not be detected by the printer.
Hope it helps!
Nov 29, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Check printer 5100 error message.
error code 5100 means print head temperature rise error. In other word the print head is overheated. First,turn off your printer for some minutes (it recommended to take about 30 secs or more) and let it's cooled down. Turn on again. If the problem still persist,try to check whether the print head is good or not by comparing with another print head. Be carefully,sometimes this problem is caused by short circuitry inside the print head.
Jan 03, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Error message is this: Error Number : 6A00 A problem has occurred with the printer mechanism. Cancel printing and turn off the printer. Wait a few moments, then turn the power back on. If the problem...
Unplug printer power supply from wall or powerstrip. Wait 10 minutes then plug in power supply and turn on printer and try again. If problem persists and it is under warranty contact Canon for repair. Otherwise it might be time to buy a new one.
Dec 05, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Error 5100 on canon mp 160
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Hope it do for you
All The Best: Pineworks
Nov 27, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Last week i tried to print but it didn't work and appeared 5100 error. i have the pixma mp 170 printer... i don't know how i can fix it
Hello
The manual states that the error code 5100 is a result of:
Service error 5100 is displayed
Cause: Movement of the FINE Cartridge Holder is blocked.
Action: Clear the paper jam or foreign object that is preventing the FINE Cartridge Holder from moving, cancel printing from your computer, then turn OFF the machine and turn it back ON again.
You might see something blocking the printer head, check inside to see if there is a paper jam, staple, or some other object blocking the print head.
If this does not work, try resetting the device:
  1. Turn the printer off.
  2. Hold the button Resume / Cancel (red triangle in the circle), click POWER - indicator lights green.
  3. Release the button Resume / Cancel, keeping POWER.
  4. Click Resume / Cancel 2 times, keeping POWER, and then release all the buttons.
  5. When the indicator light Green - click Resume / Cancel 4 times!
  6. Turn the printer off button POWER.
Hope this can help you.
Best regards
Andrea
Oct 20, 2009 | Office Equipment & Supplies
Error 5100 in Canon MP160
Hi You can Try
Error Code 5100
Solution 1:
Solution 2:
Apr 19, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Error message 5100 on Canon i560 printer
Hi You can Try
Same old errors
Error Code 5100
Solution 1:
Solution 2:
Oct 27, 2008 | Canon BubbleJet i560 InkJet Printer
Ram disk
Stangowner, In this case, the print job is too large for the available printer memory. Your choices are one of the following: Press to clear the message, cancel the current print job, and conduct the next print job, if any. · Press Cancel to cancel the current print job. · Press Menu to open the Stored Print and delete the current job. To avoid this error in the future, do the following: · Reduce the number of print pages such as splitting the print data. · Increase free memory space by deleting unnecessary data in the RAM disk. As for the RAM disk: When you send a job to the printer, you can specify in the driver that you want the printer to hold the job in memory. When you are ready to print the job, you must go to the printer and use the operator panel menus to identify which job in the memory you want to print. You can use this function to print a confidential job (Secure Print), or verify one copy before printing additional copies (Proof Print). NOTE: The printer holds the job until you delete it by using the operator panel or you turn off the printer. (This is the RAM disk) NOTE: Print and Hold functions require a minimum of 320 MB available printer memory. Also, you need to configure the RAM disk settings on either the OPERATOR PANEL OR THE PRINTER DRIVER. NOTE: Depending on the documents, its job may be too big for the available memory. In this case, an error occurs. Take this link and print it out. It will help you later when you get "other" error messages. http://support.dell.com/support/edocs/systems/3100cn/en/UG/section19.html And here's a link for more "operational" situations. http://support.dell.com/support/edocs/systems/3100cn/en/UG/section16.html#1087088 ZT3000 "Beta tester of "0"s and "1's"
Aug 21, 2007 | Dell 3100cn Laser Printer
Canon PIXMA iP4000 InkJet Photo Printer Logo
263 people viewed this question
old marine
old marine
