Question about Fisher and Paykel GWL11 Top Load Washer
Machine will not advance to the rinse / spin cycle. It just beeps at us or does nothing at all
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now when the machine beeps it will show an ERROR CODE.This will be a series of lights that will light up when the machine starts to beep.They will be in a row of 8 lights.Starting from the left to the right which ones are lit,Is it the 3rd and 5th or the 1st and 7th ---etc---?Please reply with additional information on the question and I am sure I can help you.Looking forward to your reply.
Posted on Sep 02, 2010
Kenmore washer 110.16112503 works in wash & spin cycle but not rinse. After wash cycle finished I hear a humming sound and the machine does nothing until I manually start spin cycle. Broken timer?
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
Sep 18, 2016 | Kenmore Washing Machines
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
Wont adavace after wash cycle like its stuck replying back
Hi just read your posting. The problem appears to be your drain pump is either blocked or faulty.If you would like I can guide you throe the removal of the pump. The reason it does not reach full spin speed is there is still water under the bowl slowing it down.It is impossible to drain the machine by hand completely.Please reply If you require extra help on the pump removal.
Jun 07, 2010 | Fisher Paykel EcoSmart GWL15
F&P washer lights on and beeps
Clogged pump stopped up drain. If the washer does not think all water was pumped out in 8 minutes then it shuts down. Slow drain is my first inclination.
Dec 31, 2009 | Fisher Paykel EcoSmart GWL15
Rinse cycle does not work on washing machine
Sounds like a belt or clutch issue. What is the make and model #?
Nov 02, 2017 | Kenmore Washing Machines
Frigidaire top load washer won't rinse
this can be two issues. One could be the control knob. there could be a malfunction here. secondly, you may have a faulty water valve assembly. the relay or solenoid may need to be replaced. i would start with the control knob.
Mar 13, 2009 | Washing Machines
The machine works fine until it reaches the rinse cycle.
The buzzing sound is the cold water inlet valve is getting power but water is not able to enter. You need to have the valve replaced or make sure the cold water is turned on at the sink. Hope that helps, let me know.
http://tclaundryrepair.com/
Feb 28, 2009 | Kenmore 24032\24036 Top Load Washer
Fisher and Paykel Pride 5.5kg washing machine, everything works fine until you get to the spin cycle and then it just beeps and won't do anything more. What can I do to check or fix this?
My washing machine will not cut off on a high water level, but will on the medium. It will wash until it gets to the short wash and then it just beeps at me. I tried to advance it to the rinse cycle but the light just blinks and won't do anything more. It did drain the water out though. What's the problem and how do I fix it.
Aug 05, 2008 | Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
54 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
