Question about Philips Audio Players & Recorders
I need philips tuner amplifier AH718 SERVICE MANUAL FOR REMEDIAL MAINTENACE
    Top Expert:
  • Philips Master
  • 41,797 Answers
A service manual would have to be requested directly from Philips.
Posted on Jan 07, 2017
Amplifiers manuals
http://www.manualslib.com/manual/87152/Kicker-Kx100-2.html
Jul 23, 2014 | Fisher Am Fm Stereo Receiver Tuner...
I need to know how to hook up Sony amplifier ta-ax 295,Sony tuner st-jx 295, sony cassette tc-w295 with a RCA 5 disc CD player and a Samsung DVD/ video CD/CD player in stereo. It always worked when my...
There are a number of amplifiers in the TA series, but the connections are basically the same.
In your system, the amplifier serves as master control. How do you know? Look for the component that offers input selection -tuner, cassette, CD, video, phono and probably auxiliary. Every other component plugs into and is controlled by the integrated amplifier. For example, plug the tuner wires from the tuner output to the amplifier input marked "Tuner." To use the tuner, just select that input from the front panel. Same with all the other components.
On the back of that unit will a bunch of RCA jacks for left and right channels. Take the hook-up wires, usually RCA cables with colored plugs on each end, and connect the OUTPUT jacks on each separate component to the INPUT jacks on the amp. Power may also be controlled from the amp. On audio plugs, red is right and white is left. Keep the polarity constant as you connect each component. Connect the speaker wires to the speaker outputs, usually spring clips or screw terminals on the amplifier end and the same on each speaker. The DVD video cable will have three wires: Yellow, red and white. Yellow is always video. It may also have a little round video connector for S-VHS which provides a much better picture when using DVD.
Select your desired input and enjoy the show. Service Manual free download schematics datasheets eeprom bins pcb...
Jul 13, 2014 | Audio Players & Recorders
I can't operate my Philips Magnavox 42MF521D/37 Television
Philips has the FAQs and manuals for the 42MF52D/37 here: http://www.m4c.magnavox.com/cgi-bin/cpindex.pl?ctn=42MF521D/37&mid=Link_FAQs&scy=US&slg=AEN . The direct link to the User's guide is http://download.m4c.magnavox.com/files/4/42mf521d_37/42mf521d_37_dfu_aen.pdf . You will need Adobe Reader of a similar program to read the manual.
Is there a specific problem you are having with your set? (OTA or cable setup or another issue) Please add a comment if you would like additional support. Note: digital OTA signals are subject to a "cliff effect" if your tuner doesn't get enough data from the antenna. This will be determined by the tuner, the antenna location (indoor, outdoor, elevation), distance from the transmitter, and any splitters or other wiring problems. I've seen failed amplified splitters turn into filters that block the incoming signal from reaching the TV.
Dec 16, 2012 | Philips Magnavox 42MF521D/37 Television
CANNOT GET PHILIPS DVDR3305 TO RECORD ON PANASONIC TV.TX-L37D25B WHILE WATCHING ANOTHER CHANNEL?.
What is your source? Since the DVDR3305 has an analog PAL tuner and most TV stations are broadcasting in digital, you probably have some sort of set top box connected to the recorder. If you change the channel on the set top box, you will record the program on the new channel. If you are recording PAL and your TV has a PAL tuner, you should be able to just record one show while watching another with the DVDR3305 daisy-chained to the TV. Just make sure to change the TV channel not the channel on the DVDR3305.
If your TV has a digital tuner, you can split the signal before the set-top box to record one channel and watch another. (Note: basic splitters will cause some extra loss of signal and may reduce a digital signal below the threshold needed to tune in the signal. An amplified splitter can avoid this - when the amplifier is working properly.) Otherwise, you need a second set-top box (or a dual tuner set-top box).
On my set-up with an aerial antenna, I would put the splitter between the wall jack and the electronics. The incoming cable goes to the splitter, then cable 1 goes to the TV. Cable 2 goes to the set-top box. Tune the set-top box to the channel to record and check the settings with the TV set to the DVD source. (DVD set to record on Tuner (and the specific channel of the set-top box output) or front s-video or EXT1 or EXT2.) Then change the TV back to the TV source and change to the channel for the second program.
The manual for the DVDR3305 is available from Philips. The link to the manual is http://download.p4c.philips.com/files/d/dvdr3305_05/dvdr3305_05_dfu_eng.pdf .
I hope this helps.
(I actually use an A/B switch and do not try to watch a second program on the TV connected to the DVD recorder. However, most of my recordings are for time-shifting of programs that air when I can't watch any TV program.)
Apr 29, 2012 | Televison & Video
Philips Tuner Amplifier AH719
What is the problem with your Philips tuner amp?
Apr 09, 2012 | Philips Audio Players & Recorders
Hello, sorry for my english, please. I have an AIWA stereo integrated amplifier, It`s Rx-N5. In this system, the display is dead but the amplifier and the tuner are good. Please, can you help me? I think...
Try searching somewhere like DiploDocs . com website for a service manual. It seems to me you know what you are doing, all you need is a service manual :-)
Best Of Luck
Sep 02, 2010 | Audio Players & Recorders
Self service on '07 Camry
You likely need the oil changed and the owners manual will tell you how to reset the the oil life warning.[maint req light]
Jun 12, 2010 | 2007 Toyota Camry
ONKYO Tuner/ amplifier R-100 Need PDF Manual
The tone controls are only on the remote, Part number RC-174S. I can create a PDF of the manual if you still need it, just post here.
Oct 25, 2009 | Audio Players & Recorders
Philips intergrated RDS Tuner FT980
mail me at siegfriedvik@gmail.com and i'll send you the repair manual;i also have one that has a similar problem and finally i found the manual
Jul 07, 2009 | Philips Audio Players & Recorders
Phillips tuner amplifier AH 719 series
Still I'm looking for PHILIPS Tuner Amplifier AH 719.
If anybody have the same in good condition for sale, please let me know.
Jun 22, 2009 | Philips Audio Players & Recorders
149 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
