Question about Hampton Bay 24002 Ceiling Fan
I'm lookinging for a hampton bay model # ac 552(52-350) can you help
SOURCE: hampton bay ceiling fan , model # 55295
I had the exact same problem. To solve it, I had a friend hold the area of the fan that the globe screws into. I wore rubber dish gloves to get a good grip and pushed up slightly on the globe as I turned counter-clockwise. My friend held the other part and turned clockwise a little as well. It took a lot of pressure for it to finally come loose and then we just turned it about another 90 degrees and the globe slips right out of the groove.
I couldn't believe how hard this was to do.
Posted on Feb 14, 2009
  • 323 Answers
SOURCE: Receiver won't fit Model 52-CS
Turn the breaker off first.
You'll have to take the fan down and of course disconnect the wires. I run into this a lot. What I do is take a razor knife and cut carefully into the ceiling on the side of the box, Then connect the wires from the box to the remote module with wire nuts. I always wrap them in a couple turns of eletricians tape.
Then connect the long wires to the other end of the module and push it up through the slot I cut out and lay it flat on the top side of the ceiling.
When you put it back together the part that goes against the ceiling will cover the hole in the sheet rock. Pain in the rear, huh?
Sirwriter
Posted on May 15, 2009
  • 26 Answers
SOURCE: Hampton Bay 52 In. Clarington. How do I reverse the fan?
Try these two: 1) look for a small switch up near the light area on the dark-colored area of the fan. If a switch is there, then simply flip the switch to the other position; 2) if you have a remote control for the fan, the reverse mode may appear on the remote control. Hope this helps.
Posted on May 19, 2009
  • 3 Answers
SOURCE: Lost Instructions for Hampton Bay remote control 838956
Go to www.kingoffans.com and follow the site. They are the makers of Hampton Bay.
Posted on May 24, 2009
  • 10865 Answers
SOURCE: i bought a hampton bay ceiling fan model uc7083t but i didn't
hi there i can help. There is a "dip switch" on nearly all fan remote units, much like a garage door opener has. To keep all the fans in your home from operating at one time, each fan needs a seperate "code". To use your other remote, you need to locate the receiver unit in the fan, usually in the "canopy". This is the bowl looking piece against the ceiling. then note the "code" which is the position of the switches. For instance, most have a block with 4 switches, and if the first is "on", and the remaining are "off", that is it's set code. This "code" can be changed to any combination of "on , off" that you like. BUT, you must also open the remote control and set it's switch to the exact same "Code", or order of "on off" as your Fan receiver. (Usually the control "Dip switch" is in the battery compartment.
Posted on Jun 20, 2009
Need to purchase fly wheel for Hampton Bay five blade fan 1988 model. Where could I?
I didn't know a low end fan had a flywheel. Can you send or post a pic? fanman9952@aol.com
Oct 17, 2014 | Dryers
Do you have free manuals for a hampton bay ceiling fan model 52 rdt?
http://www.homedepot.com/catalog/pdfimages/c6/c640c29e-5efd-4045-be74-016e88d7e04b.pdf
According to Home Depot this is the Hampton Bay manual for that model number.
Indicated here: http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10051&catalogId=10053&productId=100032172&R=100032172
Excerpt:
  • MFG Brand Name : Hampton Bay
  • MFG Model # : HD302243
  • MFG Part # : YG092-VPW
Jun 05, 2011 | Hampton Bay YG092-VPW 52'' Preston Vintage...
Need both dials for my Hampton Bay HBQ100
Hello, I have a link to a website where they sell parts for your ac, however, it looks lile the knobs were discontinued by the manufacturer. http://www.repairclinic.com/Model-HBQ100-ID-506907-Parts?n=2
May 05, 2011 | Hampton Bay Heating & Cooling
I HAVE A HAMPTON BAY MODEL AC-418 CEILING FAN. IT
Your issue is most likely a faulty speed control. The part is integral to the remote receiver in the fan housing. You can purchase spare parts for this fan through Home Depot (Hampton Bay) Service at 800-654-0688.
The fan unit itself is manufactured by AirCool 800-896-4908
May 10, 2010 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Blown capacitor on 4 year old ac hampton bay is
Not common, keep in mind compositor work almost like a fuse but restrict certain amount of voltage to flow through, power surge or unit overload from AC compressor kicking on and off can cause the resistor to fail; its parts of electronics working. My AC unit trip my main fuse box once in the great while, nothing surprises me when it come to electronics.
Jul 16, 2009 | Hampton Bay Heating & Cooling
Hampton Bay 24002 Ceiling Fan Logo
136 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
