Question about Samsung SyncMaster 540N 15" LCD Monitor
My samsung syncmaster 540n lcd monitor remains black when i boot the system but the monitor is not switching on i.e the monitor screen appears black and no images are displayed. but the cpu is working perfectly.please suggest
  • 11,361 Answers
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 01, 2010
When i turn on my lcd samsung syncmaster 540n it displayed a lot of colored vertical and horizontal lines.no video when i attached my cpu but it turns on when i powered my cpu
boot up in safe mode (press f8 while booting) If your monitor works now, you need to go the the samsung site and download the driver for you monitor. I assume windows 7, since that is where most of the monitor problem occur.
Mar 08, 2011 | Samsung SyncMaster 540N 15" LCD Monitor
My LCD syncmaster 540n can't display the pictures but power is on. Pls help what i have to do ?
you have to explain more detail the problem, but is there bios detail appear while pc startup?
any way try to change the cable first
if that can solve your problem may be in the past you set the resolutions higher so you lcd can't display it
May 13, 2010 | Samsung SyncMaster 540N 15" LCD Monitor
My samsung 540n monitor wont display only white light, how to resolve it?
if only white display is appear on screen it's means the problem is in main pcb section. its may be a loose contacting of the flap beetween main pcb & lcd panel. plz check it. if the main pcb will defective then no way to repair and replace the pcb.
Mar 03, 2010 | Samsung SyncMaster 540N 15" LCD Monitor
Screen is black. Power lignt is on. Mouse works.
Does it make a difference in Safe mode? Its Possible that your monitor or vidio are out of range Safe mode (f8) on botting will boot with the bare system settings, if safe mode works then reduce the resalution, Color and Possibly the monitor refresh rate
Nov 02, 2009 | Samsung SyncMaster 540N 15" LCD Monitor
I have samsung syncmaster 540n lcd monitor . i want install the driver file
For this samsung monitor driver search in driversguide.com before downloading the driver register your name.
or
Click this Direct Link from download.cnet.com
Happy Downloading
Thanks & regards
Nandu :)
Apr 28, 2009 | Samsung SyncMaster 540N 15" LCD Monitor
My monitor is receiving power but the screen stays black.
Hi..!
check your system's RAM or memory..
otherwise your motherboard is faulty..
Check it out..
Amit..
Feb 20, 2009 | Samsung SyncMaster 540N 15" LCD Monitor
Problem with samsung syncmaster 540N 15"
To replace all Electrolatic capacitors in Power supply& drie Currected
check all connectors are properly connected r not
Sep 13, 2008 | Samsung SyncMaster 540N 15" LCD Monitor
Samsung SyncMaster 540N 15" LCD Monitor Logo
98 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
