Remove washer pedestal drawer - Washing Machines
  • 1 more comment
  • mattrat10 Oct 14, 2008
    Cannot remove drawer from Frigidaire pedestal.
    Not found in the instructions.
    HELP!!
  • Anonymous Jan 02, 2009
    i have the same problem. It is very annoying as i am only able to remove the detergent dish. But i really need to remove the whole drawer so as to give it a good clean. can any one help!!
  • Anonymous May 05, 2009
    Our pedestal drawer won't close all the way. We want to take the drawer out to see if something fell behind it to stop it from closing. We can't get the drawer out.
I have a GE front loader on a pedestal & needed to remove the drawer. I got an answer from their website below. Basically, on this model, unscrew the hex-head screw at the FRONT of the side rails on each side.
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SPECPAGE&SKU=SBSD137HWW&SITEID=GEA&TABID=4 Manuals & Documentation tab - page 2
Posted on May 11, 2009
  • tallpines344 Aug 30, 2010
    HELLO MR SSOTT THANK YOU FOR THE INFO MAY GOD BLESS YOU.
    MR.BOB
Ok ladies and gents.I have a kenmore 45862400 that went on me.The dreaded bearings.Had to take the pedestal off so I hopefully can use it on a new whirlpool thats coming today.You have to take the draw front off.6 screws inside and 1 on each of the sides.Once you take this off pull the draw out and its sits in there like a tube.By the way machine lasted almost 5 yrs.Stripped it of all parts.Mom and cousin have the same model.Good luck.
Posted on Aug 04, 2009
reg501
  • 413 Answers
SOURCE: need to remove drawer from
There are two ways this drawer is held in place;
  1. Open the drawer fully. Look at the rear of the support slide is there a small, black plastic lever? If so, on one side push the lever down, the other side pull the lever up. (sorry don't remember which side up or down)
  2. No lever? Remove the small screw on either side of the support slide at the front of the drawer. Lift the drawer and push support slide away from the drawer.
If you need further assistance, let me know
Regards;
reg501
The FixYa Team.....
Posted on Jun 24, 2008
SOURCE: Samsung Pedestal Drawer
If you pull out the drawer (completely) you should find 1 or 2 screws on each side that bolts the slider to the drawer. Remove these, then lift out the drawer. This then gives you full access inside. ...JimS
Posted on Aug 04, 2008
SOURCE: Washer is off balance. Need to get to levelers.
Remove the two phillips screws inside the front right and left side of the drawer. They have 3/8 nuts holding them to the drawer rails. The drawer separates from the rails and comes out, leaving the rails attached. The levelers can be adjusted with a 1/4 inch wrench after loosening the 9/16 locknut under the base. This drove me crazy too, until someone mentioned taking the screws out as a step in removing the entire pedestal. For what it's worth, I posted this question to sears online and received an email saying: Unfortunately, we are unable to provide you with the information you
have requested.
Posted on Jan 05, 2009
  • 82 Answers
SOURCE: How can I remove the Whirlpool Duet washer pedestal drawer?
there should be a clip on the top or bottom if not pull it out as far as it will go grab it on both sides and pull sharpley towards you DO NOT GRAB THE FRONT IT WILL BREAK
Posted on Jun 29, 2009
SOURCE: how to remove drawer on pedestal
You need to remove the 2 screws holding the black rails on both sides of the drawer. Took us a while to figure this one out also.
Posted on Jan 31, 2010
How do I remove a pedestal drawer on and electrolux dryer
Hello friend, thanks for your inquiry!
I have researched that information for you and was unable to locate steps on how to remove the drawer from your pedestal. I would suggest seeking assistance from a professional for proper removal of the drawer. Hopefully this helps. -Matt
Sep 28, 2014 | Electrolux Washer/Dryer Laundry Pedestal...
Remove washer pedestal drawer Cannot remove drawer to check behind or underneath, please help.
  • Open the drawer fully. Look at the rear of the support slide is there a small, black plastic lever on one side push the lever down, the other side pull the lever up.
  • Remove the small screw on either side of the support slide at the front of the drawer. Lift the drawer and push support slide away from the drawer
Oct 30, 2008 | Whirlpool LAB2700ML Pedestal Drawer for...
How do you install whirlpool duet pedestal
Make sure that you get the pedestal designed for your washer. The white pedestal for the GHW9400P would be LAB2700MQ. (There are slight differences in the pedestals for different series washers. The holes in the base of the washer will not line up with the holes in the pedestal for a mismatched combination.)
First if your washer has been installed, uninstall it. You need to turn off the water. Then disconnect the power cord and (carefully) the fill hoses. Loosen the hoses first and then completely remove them. Drain the hoses into a bucket. Disconnect the drain hose from the back of the washer. Use pliers to squeeze the clamp to get the drain hose loose.
Pull the washer away from the wall. Cover the area behind the washer with cardboard and tip the washer onto its back (on the cardboard).
Pull out the drawer of the pedestal. Next snap the spacers into the holes on the top of the pedestal. (These are part of the hardware kit in the drawer of the pedestal.) Remove the shipping spacers from the front of the pedestal (behind the drawer). Remove the Philips head screw from the drawer slides and pull the drawer completely out (save the screws). Push the slides back into the pedestal.
Look at the washer and remove the feet if present. Partially install two of the hex head screws from the pedestal installation kit in the bottom holes of the washer. (These are at the center back of the washer if it is standing up.) Leave the screws about 3/8" from the bottom of the washer. Move the pedestal over to the washer and slide the keyhole openings of the pedestal over the two partially installed screws. Position the pedestal against the top of the washer and insert the remaining two hex head screws. Do not tighten completely.
Align the pedestal with the base of the washer on all sides. When it is lined up, tighten the 4 screws by reaching through the drawer opening of the pedestal. Bring the washer and pedestal back upright. Reinstall the washer (remove the packaging if this was a new install). Level (front to back and side to side) the washer using the pedestal feet (again reach through the drawer opening). Make sure that all 4 feet touch the floor. Tighten all 4 locknuts.
Pull out the drawer slides and reinstall the drawer. Reinstall the Philips screws. Close the drawer.
For pictures of the install, go to the Whirlpool support site http://www.whirlpool.com/owner_center . Search for your pedestal and get the installation manual. The direct link for the LAB2700MQ0 install is http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208537141.pdf .
I hope this helps.
Aug 04, 2011 | Whirlpool GHW9400 Duet Washer
Installing pedestal to washer
You want to level just the pedestal in the place where you will be using it so when you put it in position mounted together later it is done. Also very easy to do first. Get the pedestal level, tighten the lock nuts, put the washer on its back. Usually you remove the washer feet, take the pedestal drawer out, screw on each side, bolt the pedestal to the washer with the four screws provided. Tip pedestal and washer up, on to something that slides easily to protect floor. There usually are some type of shipping bolts that have to be removed from back of washer before using on new units. Usually four and these have to be removed.
Jan 13, 2010 | Maytag EPIC MFW9700S Front Load Washer
How to remove drawer on pedestal
Jan 01, 2010 | LG WM2487HWMA Front Load Stacked Washer /...
How do you remove the washer from the pedestal?
not an easy task---try to remove the drawer. there is a bolt going upwards in each corner (inside)
Dec 10, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
When you look this will not appear to be how it is done but it is in fact the way. Pull the drawer all the way out and then look on the side of the drawer at the very front and you will see a single small screw that attaches the track to the drawer. It would appear this is part of a series of screws and the track itself should seperate but neither side of the track removes. Simply remove these screws on both sides of the drawer with a small hex head socket and the drawer will pull right out. Push the tracks back into the pedestal until done cleaning the drawer.
Jun 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Jul 31, 2008 | Samsung WE356A5W Washer/Dryer Laundry...
Remove pedestal drawer from washer
First remove the top of the washer via 3 tork, 7mm hex head screws (they are hidden located on rear of washer) then you can see to line up the tub with the shipping bolts. Just put 2 in --one lower and upper opposing each other and that will be sufficient. I believe there is two screws holding the drawer in located at the track towards the front of the drawer. Now you can lean it over with no worries to remove pedestal
Jan 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
4,926 people viewed this question
Top Washing Machines Experts
