Question about Western Digital Caviar WD1600 (1600YD) 160 GB Hard Drive
I have a WD1600. When I turn the computer on, I hear a ticking noise from the hard drive. It ticks 10 times and pauses, and again until I get a hard drive failure on my screen.
  • 835 Answers
The writing pen on the inside is bent. its a piece of metal that can sometimes bend due to heating and cooling of the pc. The only suggestion other then buying a brand new one is taking it out of your computer, wrap it up in several walmart bags.tieit shut. then put if in your frezzer flat for about 6 hours, remove it, and let it set at room temperature for about 48 hours. Sometimes the heating and cooling can bend it back in place and fix your problem. good luck
Posted on Sep 01, 2010
  • 11,800 Answers
The ticking is the reading head trying to read the data. Since it fails that means that the hard disk has died. This is unfixable and all the data on it is lost. Just take it out and replace it.
My hard disk turn off every 1 hour then it make a unusal sound nd wont restart again . Then again next day its start and after 1 hour it gets hang nd start making tick tick noise ... does m hard disk...
Go to the power settings and set it to never turn off hard drive...the tick tick noise are the read and write heads working (that's what writes information on the hard drive) which is perfectly normal with an older hard drive....the hang is probably a virus or needs a good cleaning...I recommend advanced system care as a program to clean your hard drive and fix the errors....uninstall any and all programs not needed or unused
Sep 15, 2011 | Computers & Internet
When turning my car, i hear a ticking noise. What is that?
Actually it sounds like you have that noise when you turn your car not when you turn it on at least thasts what it sounds like to me. I f that is true then it is probably your cv axle not real hard to change but can be a pain to get the original one out just shake it back and forth and up and down til it comes free sometimes the heat from driving it so long that way makes it shrink then swell again and again kind of welding itself.
Feb 16, 2010 | 1991 Honda Accord
99 GMC Suburban -- While driving engine cut
Does it tick then a bit later tick again? If so that's most likely an automatic circuit breaker that you hear. If you have a short in the wiring the circuit breaker kicks out (tick) and shuts that circuit down, after a minute or so the circuit breaker cools enough to reset itself (tick again). That would explain the truck shuting down. The circuit breaker will continue to reset itself until the battery goes dead, I would suggest disconnecting the battery until you can get it to a shop. You have a short in the wiring somewhere. Good Luck!
Jan 02, 2010 | 1999 GMC Suburban
I just bought a 2008 Sienna w/ 44,000 miles. When the engine is cold, doesn't have to be really cold, I hear this ticking noise (not loud) when engine is under slight acceleration between 1500- 2000 rpm....
Sounds like you are describing lifter noise. Go to the car store and buy a pint of Berrymen's Chemtool. Next time the engine is cold, pour the Chemtool into the engine oil. Do your normal driving for the next few days or weeks until you have 150-200 miles (none of them should be highway miles) on the engine, then have the oil changed. Drive for 2000-3000 miles, and do the same thing all over again. Repeat this a couple of times. If the lifter loosens up, your good to go. If it doesn't, then it will have to be repaired by tearing into the engine.
Dec 16, 2009 | 2008 Toyota Sienna
Getting ticking noise from the computer and it does not recognise the drive
The arm for the hard drive is probably bad. That is the ticking sound. The arm is loose and not reading the platters. If you have data that needs recovered from the drive, I wouldn't run it any more. Take the hard drive out of the case and find another computer you can put the drive in as a slave. You can try putting the hard drive in a freezer for an hour or so, plug it into another computer and try to get files off of the drive. This might work for a bit until the drive gets warm then you'll have to freeze it again. Freezing the drive might tighten the arm up enough to read for a short time to maybe recover files but the drive is probably toast.
Oct 01, 2009 | Western Digital 320GB MyBook External USB...
Ticking problem on power up
The ticking noise is most likely the hard disk and the ticking noise indicates that the hard disk is faulty.
A normal functioning hard disk makes a spinning sound.
I suggest you get your money back or get a new hard disk and install Windows to get the laptop operating again.
Jul 31, 2009 | Acer TravelMate 518TX Notebook
My external is making a faint tick, tick, tick
I am sorry to inform you that your drive is failing. Normally drives will start with a faint ticking then move onto a solid clicking sound and maybe even a grinding noise. You will need to backup all of the data on that drive and then download the diagnostic utilities from your drive's manufacture and run the testing tool. If you can hear any ticking there is a very good chance the drive will fail the diagnostic tests. Assuming it fails you will then be able to RMA your drive for a working one as long as it is still under the warranty period. If your drive passes all the testing from the manufacture's tool I would advise you backup your data from that drive regularly and run the diagnostics weekly until it throws and error code.
Jul 23, 2009 | Computers & Internet
Will not connect to computer
If it's ticking, it's likely damaged. I know some hard drives have a high failure rate, and can die early.
Jun 08, 2009 | Maxtor Personal Storage 3100 (M01E100) 100...
IPod Errors
Distinct clicking, right? Your hard drive is about to crash completely. Other than the ticking, your problems are probably because the hard drive is not giving out the information it needs to because it can't. You need either a new Hard drive or a new player. once you get it all of you problems should go away.
Feb 14, 2009 | Apple iPod classic MP3 Player
TV making ticking sound when turned on
most times I hear that ticking its the high voltage failure ...most likely a shorted HOT fallowed by flyback. the ticking is your shut-down engaged.
Jan 17, 2008 | Philips 32PT6441/37 32" TV
Western Digital Caviar WD1600 (1600YD) 160 GB Hard Drive Logo
139 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
