Question about Nintendo Video Game Consoles & Games
Error code 51330 - Nintendo Video Game Consoles & Games
  • 2,272 Answers
This error is faced by many other users too. There is a procedure you have to follow to solve this error.With this procedure some gets solved and some does not. In that case the Nintendo support center needs to be contacted for reset internally.
The procedure is as follows:--read it carefully and completely and then follow it properly.
Error Code: 51330
This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
Are you using WEP or WPA security on your router?
Log into the router using the default IP (consult your router's manual for assistance)
Locate the "wireless security" section of your router settings and find the WEP or WPA key.
If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
If you are using WPA, the Wii console is compatible with the following types:
WPA - PSK (TKIP).
WPA - PSK (AES).
WPA2 - PSK (AES).
If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
If the Mac address filter was disabled, then continue troubleshooting.
Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available).
Check Nintendo's router info for special notes, if available, for your router.
Click here to go to our Wireless Router lookup page.
Use the drop-down box to select, if available, your router manufacturer.
Posted on Sep 01, 2010
  • raj somaiya
    raj somaiya Sep 01, 2010
    The procedure continued >>>>>>>----------
    Click on your router's
    model number, if available.
    Read any "special
    notes" at the top of the router's page. Many issues can be solved by
    changing settings described in the "special notes."
    Ensure that the router
    is set to broadcast in "mixed" or "b/g" mode. Routers set
    to "g only" may not be able to allow a successful connection from the
    Wii console. (The option to change this setting is typically found in the
    "Wireless" section of your router's settings. For information on
    select the brand name and model number of your router, if available.)
    Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration
    settings. To access these settings:
    On your PC, click
    "Start" and then "Run."
    Type "CMD"
    into the field that appears to open a new window.
    Type
    "IPCONFIG/ALL" and press "Enter" to display a list of
    internet settings. Locate the settings asked for by the Wii console during the Manual Setup process
    and enter them.
    Power cycle your router
    and modem by unplugging them both from the wall. Wait a few minutes, and plug
    the modem back in. Wait a couple of minutes for the modem to initialize, then
    turn on the router. Try to connect the Wii console online and test for proper
    response.
    If you are still
    receiving this error code, please click here for assistance.
    But if the above
    information doesn't help correct this problem, then give a call to Nintendo's
    1-800-255-3700 (6 am ~ 7 pm Pacific, everyday) Customer Service number, and one
    of the service representatives will do some over the phone troubleshooting to
    determine exactly what is causing this and then talk you through any needed
    steps to correct it.
    Thanks. Keep updated for any more query. You can rate this
    solution and show your appreciation.
Tip
Nintendo Wii Error Code 51330 usually indicates that the WEP/WPA key you set on...
<span><span style="font-weight: bold;">Nintendo Wii Error Code 51330</span> usually indicates that the <span style="font-weight: bold;">WEP/WPA</span> key you set on your Wii is not the correct one to gain access to your <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>router</span></a>. <br /><br />When you setup a router for wireless internet, you usually set a WEP key or by default one is set. This is basically a <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>security</span></a> key(<span style="font-weight: bold;">password</span>) that you set so any device that wants to use your <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>internet</span></a> has to enter correctly in order to gain access.<br /><br />If you know your router security key, go into your <span style="font-weight: bold;">Wii network settings</span> and make sure it is entered correctly. Click <a href="/../support/r9198848-connect_nintendo_wii_internet">here</a> to read my tech article on how to configure your Wii's network settings. <br /><br />If you do not know the security key of your router, then read my other article by clicking <a href="/../support/r9359087-find_wep_key_router_router_security">here</a>. This article will go over <span style="font-weight: bold;">how to find the router security key</span> or if need be, set one.<br /><br />Be sure to check out my other <span style="font-weight: bold;">Tips</span> by clicking on my profile name and then clicking "<span style="font-weight: bold;">Tips</span>" at the top left. <br /><br />Regards,<br />G33k<br /><br /><br /><br /><br /><br /><br /><span>Keywords</span><br style="font-weight: bold;" /></span><span style="font-weight: bold;">Nintendo Wii Error Code 51330, error </span><span style="font-weight: bold;">51330, Wii </span><span style="font-weight: bold;">51330, Wii error </span><span style="font-weight: bold;">51330, Wii network settings, can't connect Wii to netflix, Wii netflix, Nintendo error code </span><span style="font-weight: bold;">51330, Wii code </span><span style="font-weight: bold;">51330</span>
on Jun 14, 2011 | Nintendo Wii Console
Error code 51330 on wii
They have stop the Internet connection for what reason ikke dont knowhow maybe use IT og wii u
Oct 12, 2014 | Nintendo Wii Console
Netflix movies will not show, showing error code:51330
Error Code 51330: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again.
Aug 23, 2011 | Nintendo Wii Console
I am trying to connect Netflix to my Wii and I keep getting error code 51330 and 51331. I don't know what these errors are. I am trying to set up with wireless internet.
From Nintendo:
Error Code 51330, 51331, and 51332
    It appears that the wireless security pass code for your home network may have been changed or is entered incorrectly on the Wii console. Click here for more information about WEP and WPA security, including how to access the settings for your Access Point.
If your wireless network password isn't wrong, reply. Hope this helps somewhat.
Jul 21, 2011 | Nintendo Wii Console
Error code 51330 comes up what does this mean
Error Code: 51330
In order to view troubleshooting information please visit http://techforums.nintendo.com/thread/3355
Feb 26, 2011 | Nintendo Wii Console
Trying to connect to internet got error message 51330
here are the trouble-shooting solutions for Error Code 51330:
http://www.nintendo.com/consumer/wfc/en_...
This is a link to the official Nintendo customer support site, and I have specifically brought up the page with the steps to take for your error code.
Jan 23, 2011 | Nintendo Wii Console
Error code 51330
Apr 25, 2010 | Nintendo Wii Console
Video Game Consoles & Games Logo
42 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
