Question about ASUS A7N8X Motherboard
Updates where do I go to get motherboard updates
    Problem Solver:
  • 5 Answers
Cerna obrazovka nemam disketu bios
Hi, you can download the bios here:
http://www.asus.com/Motherboards/AMD_Socket_A/A7V600X/#download
Download the asus update utility from here:
http://www.softpedia.com/get/Tweak/System-Tweak/ASUS-Update-Utility.shtml
The asus Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows environment.
The Asus Update utility allows you to:
· Save the current BIOS file
· Download the latest BIOS file from the Internet
· Update the BIOS from an updated BIOS file
· Update the BIOS directly from the Internet, and
· View the BIOS version information.
Aug 25, 2011 | ASUS A7V600-X (90M7A820G0EAYZ) Motherboard
Helo, i have updated the bios on asus p532n-e sli premium, and after instalation the sistem won't turn on.pls this is urgent. a nice day
According to your problem first check the bios update. Check that you have updated the bios properly. Run the motherboard in updated bios, so reset the bios. This may occur for another cause also. So check the electric outlet where the system is being plugged. Make sure that the SMPS is OK and compatible with motherboard. If the SMPS fulfil the minimum requirement of the pre updated motherboard then updated bios may not support. Check that you have installed the SMPS power cable in your motherboard properly. It will help you.
Jun 06, 2011 | ASUS P5N32-SLI Premium Motherboard
I want to update my P4BG-VM asus m.board bios update
Please go to this site and select your operating system. Your bios update options will be listed under the bios drop-down. Hope this helps.
May 22, 2011 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
How can i make bios k8n-vm.rom to motherboard because i cant read from flopy this file , thank you
anaging and updating your BIOS
The following utilities allow you to manage and update the motherboard
Basic Input/Output System (BIOS) setup.
1.
ASUS EZ Flash
(Updates the BIOS using a floppy disk during POST.)
2.
ASUS AFUDOS
(Updates the BIOS in DOS mode using a bootable floppy
disk.)
3.
ASUS CrashFree BIOS 2
(Updates the BIOS using a bootable floppy
disk or the motherboard support CD when the BIOS file fails or gets
corrupted.)
4.
ASUS Update
(Updates the BIOS in Windows
environment.)
Refer to the corresponding sections for details on these utilities.
prepare the motherboard support CD or the floppy disk containing the updated motherboard BIOS before using this utility.
• Make sure that you rename the original or updated BIOS file in the
floppy disk to K8NVM.ROM.
Recovering the BIOS from the support CD
To recover the BIOS from the support CD:
1. Remove any floppy disk from the floppy disk drive, then turn on the
system.
2. Insert the support CD to the optical drive.
3. The utility displays the following message and automatically checks
the floppy disk for the original or updated BIOS file.
4. Restart the system after the utility completes the updating process.
DO NOT shut down or reset the system while updating the BIOS! Doing
so can cause system boot failure!
more details read http://dlcdnet.asus.com/pub/ASUS/mb/sock754/K8N-VM/e2537_k8n-vm.pdf
Aug 22, 2010 | ASUS K8N-VM Motherboard
This program is unable to continue .the system you are trying to update does not support intel(r) express biose update or there are incompatible application running . pleade close all open application and...
Updating your bios is to risky it can ruin your your motherboard if you have mistaken to update your motherboard. Try to check your board has a newer version bios before you update it read also the how to update your bios and the problems you may encounter
Aug 08, 2010 | Intel D945GTP Motherboard
Bios update
If updates are available, you can always get them from the motherboard manufacturer's website.
Why do you think you need an update? If something goes wrong like a power cut, or computer problem, your motherboard will be scrap. Doing bios updates is very risky and should only be undertaken if absolutely neccessary.
Regards
sir andrew
Nov 25, 2009 | Computers & Internet
BIOS update
It is not necessary to update your BIOS if everything is working correctly.
Jun 29, 2009 | ASUS A8N-VM Motherboard
Multimedia Audio Controller Needed as Well!
I find VGA and Audio triver for motherboard MSI-661FM3
Jun 02, 2009 | MSI 661FM3-V Motherboard
Updating memory and cpu.
GO TO ADDRESS BAR TYPE:
MOTHERBOARD UPDATE DOWNLOAD DRIVERS,
MOTHERBOARD UPDATES,
CPU UPDATES,
CPUID OR CPIUD
CANDYMANGANDY
Jan 27, 2009 | Toshiba Tecra 510CDT (P000224080)...
P4p800se bois update
go to www.asus.com/motherboards to update your BIOS.
Feb 23, 2008 | Intel Motherboard
ASUS A7N8X Motherboard Logo
48 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
