Question about U-Line CO2075F-B Echelon Refrigerator Ice Maker Combination
Ice maker will not push out cubes. - U-Line CO2075F-B Echelon Refrigerator Ice Maker Combination
    Brigadier General:
  • 3,917 Answers
Hi
Please check the bellow link regarding your query…
http://applianceandair.com/Icemaker/icemaker.html#norelease
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Posted on Sep 01, 2010
  • 26 Answers
SOURCE: Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Posted on Mar 18, 2008
WCAnderson
  • 9 Answers
SOURCE: ICE CUBE MAKER SMELLY ICE CUBES
Unfortunately, this is one of the inherent problems with a self defrosting freezer units. Some frost free models/brands are less smelly than others. Grabbing the cubes as soon as they drop so they don't sit in that nasty freezer air and placing them in a zip lock would help a lot but probably not completely. Be sure and clean the inside of the freezer often so there is less of the smell left in the plastic that surrounds the ice cubes as well as the foods. Don't eat freezer burned vanilla ice cream, for sure! Hope this helps.
Posted on Oct 11, 2008
SOURCE: Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Posted on Jul 30, 2009
woodchuck789
  • 4066 Answers
SOURCE: Ice Maker GSI-26 dispenses crushed ice and will not dispense cube
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Posted on Aug 17, 2009
aasc
  • 1606 Answers
SOURCE: ice maker not dispensing ice
If the dispensor light switches to cubed or crushed , the panel is good . Remove the ice bin , and hold the light switch in . Press the arm for CRUSHED ice , and if you hear a buzzing or hum , then the auger motor is frozen . Use a hair dryer directly on the " forks " for a while , ocasionally holding switch and activating arm , until the forks move . Lower the freezer temp slightly and reinstall the ice bin .
Posted on Aug 30, 2009
Samsung refrigerator ice maker
Many icemakers use a bar or a sensor to shut off water when ice levels are at a maximum. Check to see if it's bent, missing, or pushed down below the ice level, tricking it into thinking there's no ice there.
Aug 03, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Dumping ice
If heater element is open the newly made cubes will stick to the tray and not be pushed out by the fingers doing the ejecting.
Apr 08, 2014 | Whirlpool 2198597 Ice Maker
Ice maker make ice but not come out
Hi there! If the ice maker is making ice properly but is not pushing it through tot he bucket or to the door dispenser, it is clogged somewhere. This could be from melted ice cubes blocking the pathway or even a faulty switch arm (or auger) that pushes the ice cubes forward. Check those areas and let me know if you find anything additional or out of place. Also check for any cracks in the ice maker housing.
Mar 31, 2013 | Frigidaire FRS3R5EMB Side by Side...
NEED PROCEDURE FOR REMOVING THE ICE MAKER FOR INSPECTION AND TROUBLESHOOTING. FRIG IS NEW...ICE MAKER NOT MAKING ICE !!!!!
Are you sure you have the ice bin properly in place?
Ice bin must be locked in place for proper ice dispensing. If necessary, turn auger driver behind ice bin counterclockwise to properly align ice bin with auger driver.
• Press the switch ON to activate ice maker. Slide bin into guide rails located on either side of the enclosure. Push the ice bin in until resistance is felt. Raise the front slightly and push the ice bin completely in. An audible "click" is heard when the ice bin is located correctly.
• After freezer section reaches between 0° to 2° F (-18° to -17° C), ice maker fills with water and begins operating. You will have a complete harvest of ice
approximately every hour.
• Allow approximately 3 to 6 hours after installation to receive first harvest of ice.
• Discard ice created within the first 12 hours of operation to verify system is flushed of impurities.
• Stop ice production by pressing the ON/OFF switch located on the front of the ice maker.
• The first one or two batches will probably contain undersized and irregular cubes because of air in the supply line.
• When the ice cubes are ejected it is normal for several cubes to be joined together at the ends. They can easily be broken apart. The ice maker will
continue to make ice until the supply of ice cubes raises the ice maker arm, shutting the ice maker off.
• Certain sounds may accompany the various cycles of the ice maker. The motor may have a slight hum, the cubes will rattle as they fall into an empty storage bin and the water valve may click or "buzz" occasionally.
Jun 01, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Ice maker will only make crushed ice and no cubes, what could be the problem
Open the freezer door.
Pull the ice bin forward about 3 inches.
Push the ice bin to the rear of the freezer until it seats and locks in place.
Then try to dispense cubes.
The ice bin can become dislodged from its locked position and the crushed ice solenoid activates automatically.
Sep 17, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
The Ice maker has stopped working.
There are usually 2 small solenoid valves that are used to control water. Both are generally installed at the rear close to the bottom of the fridge. One of the solenoids controls the water flow for drinks and the other is to control water flow to the ice maker. You can determine which is which by tracing the water supply tubes from the freezer compartment to the solenoid or by process of elimination. The latter method requires that you feel for movement (clicking) or heat on the water dispenser solenoid while someone starts to fill a glass with water from the fridge.
Before going any further, make sure that the ice cube detection arm in the freezer is not up. Gently push the arm down if it is. When ice cubes are ready, the ice maker turns on a small heater to break the bond of the ice cubes to the cube mold. The arm is lifted up and out of the way. Then the mechanical fingers wipe or push on the cubes to dislodge them from the ice cube mold and they fall into the container. The arm is then lowered again and rests on top of the ice collected in the container. The position of the arm when resting on the ice cubes determines whether or not any more ice cubes are made.
If the arm is hanging down, then ice cube production should be on. The problem may be either a faulty solenoid valve (mentioned above), switch in the ice maker assembly - the detection arm in particular or wiring between.
Jun 18, 2010 | Maytag MFI2568AE Side by Side French Door...
Ice maker will not stop,even when the tray is full of cubes.. will only stop if arm is put up..
The ice tray arm is mechanical. It is pushed up by the ice cubes. Try bending the arm down so it makes contact with the ice cubes sooner and gets pushed up sooner when it reaches up posistion it should stop.
Mar 29, 2010 | GE Profile 24.7 cu. ft. Top Freezer...
Just got Neff ice cube, crushed ice maker and ice
Will probably find the freezer fan has failed.Push in the door switch on left hand front of freezer with the door open & you should here fan running,if not new fan required.
Jul 01, 2009 | Neff K3965XO Side by Side Refrigerator
Automatic Ice Maker making grinding noise and will not release ice
The mold heater on the bottom of the ice maker is shot, that is why the cubes will not release. The grinding is the sweep arm trying to push the frozen cubes out.
May 06, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Ice Maker Issues-only crushed ice works, cubed comes out crushed
There is a solinoid in the freezer section by the motor that turns the ice auger. Test it by selecting cubes and with the ice bucket out, open the door, hold the door switch so the lights turn out and push the dispenser button. It should make a loud snap and travel upward. If not then I would say you have a bad solinoid. If it does, then I would look at the bucket. the metal rod that runs along the side of the bucket opens a flap in the bucket that is supposed to let the full cubes drop. look for anything that might cause it to be hanging up.
Jan 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
