Question about Dell Inspiron 1525 Laptop
A DELL Inspiron 1545 laptop - when the charger is plugged in - it says not charging..........
  • 2,567 Answers
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 08, 2010
Plugged in, not charging
First, try another charger. Perhaps your charger isn't providing enough volts to the laptop
Feb 27, 2014 | Dell Inspiron 1545 Notebook
New battery and charger wont charge over 45%
The battery needs to be calibrated from the setup. I this doesn't work, then ask for change of battery
Jan 27, 2013 | Dell Inspiron 1545 Notebook
Battery wont charge dell inspiron 1545
Buy a replacement cord\charger at a computer store or online, make sure the power specs match. If you are refering to the AC power plug JACK in your computer, similar to this:http://www.parts-people.com/index.php?action=item&id=9377&gclid=ciw47k7sulmcfqufnqodreeaew. I would take it to a Qualified Computer tech, or send it to the manufactor, Dell in you case. Unless you have the tools and expertise. It can be done but are you comfortable doing it?
Nov 04, 2012 | Dell Inspiron 1545 Notebook
Dell inspiron 1545 laptop has went through 5 chargers they work for 6 months and then say does not not charging does not recognize battery
This is similar problem I had on my laptop.
Its a problem with the battery not the Charger If computer is in Warranty you get it from Dell or buy a new battery
Jun 21, 2011 | Dell Inspiron 1545 Notebook
I have a dell inspiron 1545 laptop. Just recently I have been getting a message that the computer does not recognize the power source when I have the AC cord plugged in. We have been using this AC power...
If you are using a Genuine Dell charger, the battery should charge. I don't think its the battery however. My guess would be that there is damage to the inner pin of the charger jack, or possibly damage to the socket where it fits. It could also be down to worn contacts. The charger will power the laptop, as long as there is sufficient contact on the + (inner pin) and a tight enough fit on the outer (-) contact.
If you look closely at the inner pin on the charger, check and see if the inner pin has snapped.
The best check is to obtain or borrow a known good dell charger (aftermarket ones will simply not charge the battery) and see if that resolves the problem, or if you know anyone with the same model, ask them to see if their laptop will charge the battery. That at least will either confirm or deny the fault being with the charger or battery.
More serious is the possibility that the charging circuit has failed. On occasions, the small fuse on the motherboard can fail, or, there is a more deep seated problem on the charging circuit.
Jun 19, 2011 | Dell Inspiron 1545 Notebook
I have a dell inspiron 1545. i have the charger plugged in but a red light is flashin on my laptop. this light then turns white and immediately red again.if i remove the charger the laptop just switches...
Probably battery, although that should be orange not red..
Remove battery and try it on AC alone, if that works, it was a damaged battery halting the process
If it does not, check the charger's tightness in the charging port, if sloppy or loose, this will need replacing.
Some Dell's are VERY picky about the charger, if not the exact model specified, they will not charge the battery
If none of the above, remove battery and test with another Dell charger of the same spec, if this also fails to work and you are sure the light is red, you have a problem with the motherboard. Commonly the charger power board fails on these.
Jan 06, 2011 | Dell Inspiron 1545 Notebook
take the battery out and try powering on your computer only with the power cord plugged in
if the computer turns on then
this is the problem with the battery
you need to replace the battery
Thank you
My dell inspiron 1545 says plugged in but not charging
its the charger if the charger is longer before trie changing the battery or if that doesnt work u have to replace the motherboard (around 155.00 GBP)
Jul 26, 2010 | Dell Inspiron 1545 Notebook
Dell Inspiron 1525 Laptop Logo
126 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
