Question about Vizio VP322 32 in. Plasma TV
Vizio VU42LFHDTV10A will not turn on. Power board fuse is sautered into circuit board. Checked out good, but do I need to remove it to check if its blown? Capacitors look good. No burn marks on sauter side of board. Any ideas?
4 Suggested Answers
SOURCE: I have a Vizio VO74L TV almost 3 years old. Last
If the capacitors have blown then it would not cost much to change them all, Capacitors in LCD tv's are a common faulty due to poor chemical compounds used to make them and heat exhaustion, especially with the tvs that have the same chassis. Try changing them all and see if it makes any difference. Vizio or other manufacturers wont say anything as its not under warranty and they dont like people looking inside their tvs :).
Posted on Mar 22, 2011
  • 155 Answers
SOURCE: vizio vp422hdtv10a plasma tv will not turn on.
Good call checking the fuses first. Next I would try replacing the power-board. If you have a volt-meter you can test it first, but BE CAREFUL as it would require having the TV plugged in.
The power-board is the one with the most large components on it, like transformers (coils of wire) and capacitors (tin-can looking things). The board itself will be much smaller then the main board, and may be the first place the power cord leads to.
The good news is that this is probably the cheapest component in a TV to replace (besides a fuse that is). Check online.
Posted on Mar 19, 2010
budmrtn
  • 11361 Answers
SOURCE: Got sound but no picture
Check to make sure you do have 24vdc feeding the inverter board, there are surface mounted fuses on the inverter bd.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Vizio+GV42L+
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 28, 2010
I have a Sauter oven. When I try tuning it on nothing happens. No light,no fan,no heat.The clock display seems OK.I tried pressing the menu button several times.Nothing helps.What can be the solution?
I should suspect the fuse or circuit breaker that is supposed to power the oven if turned off.
It could be nothing more than a power surge from a lightning strike somewhere.
Find the electric box and check it out.
If the fuse or circuit breakers panel is good, remove the oven and check for current at the wiring that goes from the oven to the fuse/circuit breaker box.
If all that tests good, you have a problem with the oven control.
It may be "toasted". (No good)
God bless your efforts.
Sep 08, 2016 | Ovens
47 inch vizio blown fuse
i am having the same problem and my power light wont even turn on so i think it might be tht power fuse. Is tht what was wrong with urs?
Dec 18, 2011 | Vizio VO47LF 47" TV
Vizio 1080p making a clicking sound with a blackish / gray screen no picture model VU42LFHDTV10A
Sounds like your controller board is bad or a power supply issue. Try to change input. If it does the same thing it is the controller board. You can get a replacement on ebay if no longer under warranty
Mar 31, 2011 | Vizio 42 in. LCD TV
The LCD inverter backlight board.It a 2 long boards connected by a fiber opic cable to form as one big long borard.
May 27, 2010 | Vizio GV42L 42 in. LCD Television
Vizio vp422hdtv10a plasma tv will not turn on. Made kind of a real loud click and shut off and will not turn on again. Removed back, fuses don't appear to be blown. Circuit boards don't appear to have any...
Mar 19, 2010 | Vizio VP422 42 in. Plasma TV
I have a Vizio VX37l and was watching it and then I heard a pop and the tv went black. The power light still is on on the Vizio on the front. I checked the fuse inside and it was fine.
It sounds like the 5vdc standby circuit is still working, that is why the main fuse is still good but you may have bad 24vdc power supply, look real close again for blown transistors or IC on the power supply board, but it can also be the backlight inverter circuit boards that blew up also. Look here to see what good parts look like: http://www.shopjimmy.com/catalogsearch/result/?q=Vizio+VX37L+
Please post back what you find.
Dec 08, 2009 | Vizio VX37L Television
VU42LFHDTV10A Vizio will not power up. I am guessing that my power supply went out when our breaker blew. It was hooked up to a surge protector but still went out. How much other damage could have occured...
You should check the fuse in the power supply module, that will be the first thing. You can look for new power supply on EBAY at such place as jimmypart.
Oct 29, 2009 | Vizio VU42L 42 in. LCD TV
LCD TV WONT POWER ON
A dead condition usually indicates one of the following: Open fuse (often internal, and usually pops due to other circuit defects). Short (overload condition) in the circuitry. Failure elsewhere in the circuitry. Most modern electronics have some logic circuitry, and if there is a section of the circuit not working, the logic circuit keeps the set from coming on at all.
First, if your power cord plugs into the set, check that it is properly connected. If you can get into the internals, find the fuse, check it, replace with an exact or near exact size.
If problems are beyond the simple, technical expertise will be required to nail down and fix the problem.
Nov 28, 2007 | Televison & Video
Vizio VP322 32 in. Plasma TV Logo
272 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
