Question about PANDIGITAL (DPF802) Digital Picture Frame
My Pandigital frame was working fine for a couple of years and now the screen is totally black.
  • 37 Answers
That is probably the back light system neon where they defective
or the power supply its self
it is probly an easy problem to fix by a good technician...
good luck
regards allan.
Posted on Sep 01, 2010
PANDIGITAL Digital Photo Frame works perfectly except the SCREEN Flickers Black after a few moments
Annemarie, I had a similar problem with an off-brand photo frame from Wal-Mart last year, although in my case the frame would shut down entirely after it had flickered a few times. In my case, I was able to remove the back of the frame's case by removing 4 screws (two were hidden underneath model number stickers) and inspecting the device's innards... what I found was that, as you surmised, there was a loose connection from the female end of the DC-in power supply. The ground connection to the device's circuit board had been poorly soldered, leaving the connection itself loose and a small piece of solder on top of the board and very near the positive connection.
While not being the best solderer in the world, with the aid of a magnifying glass, a solder removal tool, and a ColdHeat soldering wand, I was able to heat the offending piece of solder and remove it from the circuit board and then, as I was personally uncertain of my ability to re-solder the connection without melting the board, I simply held the connection in place and applied a dab of hot glue to keep it there. After the glue cooled, I reassembled the case and the frame worked for almost another year before something else finally burned out and it was left cold and dark.
Hope this helps, good luck!
Dec 03, 2013 | PANDIGITAL 7-Inch Digital Photo Frame with...
Pandigital net support
Contact the original vendor
Aug 09, 2017 | Photography
Screen is totally black got new charger still wont turn on
did it ever work? does it run on batt, if so try powering it your computer
Feb 18, 2010 | PANDIGITAL Digital Picture Frame 9.2...
Wanted to erase a single picture, accidentally erased all. Now, computer not recognizing frame, asking me to format removable disk before I can use it. Unable to reinstall. Before, computer recognized...
Yes, that's because you have deleted the files. The frame will work just fine. You can can rename 'removable disk' to PANDIGITAL but it doesnt really matter.
All you need to do is copy the images and it will show up on the frame.
Jun 09, 2009 | PANDIGITAL 7" Digital Photo Frame With...
My pandigital photo frame is frozen on the sytem start screen
Mine does this when the power cord shorts itself out. For a whileI could fix it by simply untwisting the cord close to the plug, but eventually I had to cut and splice the cord to keep the lines separate (think a bunch of electrical tape. It works fine now that the cord isn't shorting out. Hope this helps!
Feb 02, 2009 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
Picture Frame is not turning on
there must be abreak in wires of in put cord
Apr 11, 2017 | PANDIGITAL 11-Inch LCD Digital Picture...
How do I load my photos on a pandigital picture frame?
I could not load my directly directly from PC. I had to put them on my camera memory card, then insert memory card into frame. worked well but took more time.
Dec 29, 2008 | PANDIGITAL 6.0-Inch Digital Picture Frame...
I NEED A INSTRUCTION MANAL
I got my digital "pandigital frame last year and lost the instructions. Can you tell me how to download photos from my PC via Usb to frame?
thanks Deejohn2127
Oct 29, 2008 | PANDIGITAL (DPF802) Digital Picture Frame
Pan digital 7 frame screen goes white
Removing the internal battery will clear all settings. I have done this on two different versions of the Pandigital frames (seems to be a very common issue) and it has corrected the issue instantly both times.
Good luck.
Sep 09, 2008 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
PANDIGITAL (DPF802) Digital Picture Frame Logo
318 people viewed this question
Top PANDIGITAL Photography Experts
Gareth Cockram
Gareth Cockram
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
