Question about Whirlpool Duet GHW9150P Front Load Washer
Smell from my whirlpool duet
I also have the same machine and I have the same nasty smell too. At first I didnt know what it was until I eventually got so aggrivated about it that I had to know what it was. So I googled it and I found all these forums and other sites explaining where the smell is comming from. My question for you is when you said wreaked havoc with skin rashes and allergies exactly what was happening to them. I too have been having very odd skin problems and really bad allergies.. I actually live in a basement apartment and thats bad enough without having to have my Clean Clothes smell like someone's old smelly dirty basement. Can you please or anyone who has expirienced any health problems that they think is linked to this odor contact me cause i would like to hear and compare what its doing to my skin to your problem or problems.....
    President:
  • Whirlpool Master
  • 2,651 Answers
Dont let this be an end all fix for your skin/allergy issues, im an appliance repair guy not a dermotologist or allergist for that matter. there is a product out there to clean your frontload washer and remove most if not all the smell(s). www.affresh.com . as far a s what the smell is, most likely its an imcomplete breakdown of laundry detergent and/or fabric softeners. this produst was speciffically designed to adress this issue.. you MUST use an HE (high efficiency) detergent , and very little of it as well (2-3 tablespoons all that is reccommended be manufacturer.
Posted on May 12, 2008
Whirlpool duet ghw9250 smells like burning rubber and very loud
Does the drum turn, if not then the drum bearings may have siezed.
Dec 30, 2012 | Whirlpool Washing Machines
I have a whirlpool cabrio washing machine. I have a problem. Our clothes are coming out smelling musty and nasty. They dont start smelling until they are wet, like with sweat Or the towels when we dry off...
If you dont wash whites with clorine bleach, you may want to every once in a while. Clorine kills germs and backteria which can smell. washer pumps do not get 100% of the water out.
Sep 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer stinks
Hi, problem occurs due to cool washes(i.e. 40c and under) not destroying bacteria from clothing/detergent which then breeds inside your machine, therefore creating a sometimes sulpherous or musty smell.
I would advise you to regularly do a hot wash(minimun 60c) with an old towel, soda crystals and washing machine bleach i.e. vanish, ace etc with an old towel in the drum to move the mixture around. if you keep up with this the smell will eventually go away.
You can buy limescale/detergent removal powders which will do the same job.
Sep 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washed clothes still smell dirty
If you don't leave the door open after each use you will get a musty smell and mold will build up in the bellows. also you need to wipe the bellows dry and the door glass dry as to not get a build up of soap residue on it which will eventually make the door leak. Also, only use one or two tablespoons of soap, not what the soap manufacturer says on the package.
Mar 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Musty smelling washing machine
www.smellywasher.com you can order here to take care of that problem!
Jan 17, 2010 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool fron loader washer leaks at the door
The water should be able to come up to the door level without leaking. Chances are you have build up on the bottom side of the glass on your door. If so take a razor blade and scrape the build up off. Your door will quit leaking.
Aug 12, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Where would i look for a lint trap on a whirlpool front load wash
if you remove the bottom cover you will see a round white dial..it will be full of water so beware! a gallon or more so be ready. unscrew it counterclockwise and remove filter. does it have nasty smelly lint it it? problem solved.this is all you can do so good luck! :)
Jun 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Our Clothes smell musty and the washer smells too
clogged water screens , defective water level pressure switch , clogged drain, kinked drain hose ,. defective water pump , defective water tempeerture switch, damaged water valve solenoid , water inlet valve has an interal malfunction
Oct 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Terrible mildew type smell
Water forms in the Bellows it is a rubber boot between the door the drum.. clean this out real well ..To prevent this in the future leave the door cracked open when you are done using the machine to allow it to dry out.
Aug 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOOL DUET FRONTLOAD WASHER
I had similar problem, the front door seal can trap small items,socks,handtowels. I didnt figure this out for some months, each load of clothes had a foul, mildew smell, Check door seal for trapped clothes, run intermittent cycles with bleach only, no clothes, be sure to leave door open when not in use to air out , this will reduce smell.
Nov 27, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
173 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
