FixYa.com
Tags:
JVC AV-56WP74 56 in. Rear Projection HDTV-Ready Television
Dcm (by 2 users)
posted by jrtgreen on May 09, 2008
where is the digital convergence module located on the JVC av56wp74 56.
I want to remove to take to repair shop to replace my ic with stk392-150. I can't adjust my horiz red lines
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on May 20, 2008
I have the same convergence problem (but with the Red). The Printed circuit board is behind the front speaker panel (remove 2 screws on each side plus 2 screws in the pull down access panel under the TV power on light). There is a center access panel with 4 screws, and the circuit board is right in the front. The 2 heat sinks are about 4 inches tall so you will see them easily. Originally I was looking for small chips , these are not small they are about 1 1/2" by 1" in size. There are 3 small connectors (red blue green markings) and 3 other connectors you will need to carefully remove. There is one connector that I could not remove from the board so I disconnected the other ends (2) of the harness. The board (approx 3" x 12") can then be removed.
Solution #1
posted on May 12, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
thks for the info, i will try to be very careful. did not know that info before
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 10, 2008
Not Rated (0)
Slinteriors
Rank:Guru Guru
Rating: 88%, 2004 votes
It is located in the front of the TV behind the speaker grille and access panel its the small narrow board on the left looking from the front. PLEASE NOTE do not remove the back panel on that model with the power still hooked or operate that model without the back panel in place or you will harm the digital section of the TV and cause major problems that model has a safety feature that will wipe out the digital memory if the backis removed while the cord is still plugged in
Can you Help with these Projection Televisions problems?
JVC AV-56WP74 56 in. Rear Projection...
no sound
where do i solve this one Answer This...
JVC 56in. is broken
My rear projection tv isbroke... Answer This...
52 inch jvc projection tv, cant...
i cant get any movie to fit the... Answer This...
jvc projection tv
I have a 56 projection tv that... Answer This...
colors are out of line
the red wont line up with the... Answer This...
Repair Service
Find Projection TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
