Question about Konica Minolta Maxxum 7D / Dynax 7D Digital Camera
Camera does not turn on
The battery is full, and the camera does not turn on
  • tnpjr Jun 16, 2008
    I have had the camera for four years and this problem has occurred twice. It cost me $350 to have it fixed the first time and I am afraid it is going to cost me another $350 to have it fixed again.
    Is this a chronic problem with this camera?
  • 4 Answers
Did you recently have the ccd replaced?
Posted on May 10, 2008
If you change a lens with this camera on it will burn out the camera sensor and will not do anything but whine like its searching for the type of lens you attach and then turn off after the 3 second whine. It happend to me once and I thought it was just a case of bad luck. But the second time I figured out that I left the camera on while changing the lens.. Hope this helps. Konica Minolta 7D.
Posted on Jul 12, 2008
Camera won't turn on
Proceed with this steps:
1) memory card slot/battery cover is open
2) batteries loaded in WRON sense
3)batteries are NOT same right type
4)insufficiente battery charge,,change the batteries by full charge
5) poor contact between camera and battery terminal clean with contacts cleaner spray carefully.
God bless you
Aug 02, 2012 | Canon PowerShot SD600 Digital Camera
Does the camera have batteries
Yes. The camera uses four standard AA batteries. Please refer to the "Battery Installation" section of the manual for full details.
Dec 25, 2011 | Vtech Kidizoom Digital Camera
I turn on my camera that has full battery but it doesnt turn on
Sounds like sand in the lens cavity. Use a fully charged battery, then lie the camera flat face down on the floor, ideally a carpet. With the camera OFF, lens face down with the carpet, switch the camera on. It will take a number of go's to release the **** stuck in it.
Mine took atleast 15 go's. Better than chucking the camera out, and saved atleast 80 dollars and a trip to Germany!
Jun 02, 2010 | Kodak EASYSHARE M763 Digital Camera
My camera stops working but the battery showed full.
Those are the symptoms of a battery that has been charged many times or has been allowed to completely discharge once or twice. Try some new ones.
Jan 06, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
Immediately turns off when turned on. New lithium
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it hasn't been dropped your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Dec 19, 2009 | Kodak EasyShare C875 Digital Camera
Sometimes it will not turn on and if you do get it to turn on and you take a photo it will turn off and not come back on.
Your problem is likely due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, it may be time to replace your batteries, or the camera may have a problem that requires professional repair.
Dec 05, 2009 | Vivitar ViviCam 5100 Digital Camera
Nikon D90 Memory Card Access Blinking
It's a deadly common problem of D90. Fixation:Simply go to the DSLR repair shop and ask them to change the power circuit board of the camera. Will take $60-70 if the board available. Reason of issue:The power control IC get short and feedback the battery power to the battery causing the draining out and other problem like the top LCD back lamp turned ON after turning on the camera. Careful:To avoid this issue in future, after full charge of the battery, do not put it in the camera right then. Wait for the battery to cool down for 5-10 min and then put it in. With the full charge, the battery hold high ampere for a short time. It could damage the power distributor IC suddenly if you put it in the camera right after a full charge. Best, Leo>>from personal experience<<
Jun 14, 2009 | Nikon D90 Digital Camera with 18-105mm...
My camera is turning off
First clean all contacts in the battery chamber with a pencil eraser. Also clean the battery's contacts and try again. If you still get the same error, replace the batteries. It could be possible that the batteries have lost their full capacity.
Feb 10, 2009 | Olympus FE-190 Digital Camera
Panasonic lumixDMC-FX7 camera
Could be either. If on switch on again the indicator is full and you get more work done then its a camera fault. If when you switch on again the battery remains flat then this could be the camera fault too the flash capacitor showing signs of distress. On the other hansd the battery could be nearing the end it useful life. How much is a new battery?
Aug 29, 2007 | Panasonic Lumix DMC-FX7 Digital Camera
Konica Minolta Maxxum 7D / Dynax 7D Digital Camera Logo
112 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
