LAN light keeps flashing on Router, getting very slow load times or no connectivity what so ever. Just started last night
  • 95 Answers
Hi dustin110011,
unplug then plug-in your modem and your router to the power source.
thanks.
banaple
Posted on Sep 01, 2010
I have a netgear range max, it has been working fine. Just last night nothing wireless in my house works. Cable modem works. Power light on netgear box is green. "i" icon is flashing green,...
You need to reset and reconfigure router
please follow the steps to reconfigure router
RESET THE ROUTER:
1. Make sure router is connected to power supply and is on while you perform the task below. At the rear panel of the router, near the antenna, there is a very small round pinhole that contains the reset button.
2. Using a pen/pencil/paper clip, hold the reset button for 60 sec. so that the test light starts flashing.
3. After few seconds when the test light stops flashing. Turn off the router and turn it back on after a couple of minutes.
RECONFIGURE THE ROUTER:
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm in address bar.
4. On the basic setting page scroll to the bottom and click on Apply.
5. When prompted for Username and Password, please enter 'admin' for the Username and 'password' for Password.
6. Click on lan ip setup under advanced.
7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
9. Power off the dsl modem and the router after making the connections.
10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
11. Open a web browser like Internet Explorer, Mozilla Firefox or Safari.
12. Access the router (http://192.168.10.1).
13. Login to the router (Username = admin Password = Password).
14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
16. Click Apply.
17. Logout of the router.
18. Open up another browser window and try to access internet.
Regards,
Prakash
Apr 08, 2011 | NetGear WGT624 Wireless Router
My router is on but it seems so slow. i keep getting randomly disconnected, the connection is terrible and even when i turn it off for 30 seconds and on again it stills acts up, any ideas?
ping your router with a packet length strength. To do the ping test, go to Start-Run and type CMD and hit enter. Then, in the Command Prompt Window type in the following
ping 192.168.0.1 -l 30000 9
I suppose the 192.168.0.1 will be the default gateway of your router. To check which is the default gateway of your router you can double click the connection icon on your PC, and click the Support tab. You'll see the degault gateway IP third on the list.
Now, if it pings back all three times with times below 100ms then ok. If it doesnt then reduce the ping length to 20000, if again you have losses then reduce it again to 10000. If the ping loses packets and response is slow you'll probably need a new power cord.
If the pinging is ok at 30k then you'll probably need to change the LAN cable that leads from your internet connection onto the wifi router.
To verify this, run this command
ping google.com -l 10000 and see if you have any losses. If you do have losses, then do a ping like this
ping google.com -l 32000 if you again have losses in the ping then you'll need to change your LAN cable because the 32kb packet is almost a standard size of packets and it should have no problems to get through the router, unless the LAN cable is bad.
Hope this helps. Please vote a Thumbs Up if you found this useful and informative.
Jan 18, 2011 | NetGear WGR614 Wireless Router
Belkin router keeps losing connection to router
Reset the router and keep its setting default than check it out the problem is same or not...
Aug 10, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin router Flashing 5 out of 7 lights constantly. Help?
can you replace any cables to and from this router? Also, is it possible to turn it off for 5 minutes and retry?
Jul 06, 2009 | Belkin (F5D5231-4) Router
ZyXel Prestige 660HW T1, power light blinking
It's dead, sorry. You could TRY removing the power cord, holding in the reset button and powering it back up with the button HELD DOWN for at least 10 seconds. That will factory default it, so I hope you know how to program it all again! (please don't contact me and complain if you don't...)
May 26, 2009 | Zyxel P660HW-D1 Router
Intermittent or slow internet connection
Go here and upgrade your Router's Firmware - you will need to choose your location on the site at top left hand corner of the screen
http://www.linksysbycisco.com/UK/en/support
Feb 27, 2009 | Linksys Wireless-G Broadband Router
DISHWASHER WON'T START,ALL LIGHTS ON PANEL FLASH RED
how to download the game gat4 (i don't know ENGlish )
Feb 15, 2009 | Kenmore 24 in. 17052 / 17054 / 17059...
LAN led light alway on and flashing
Reset the router:
While the router is powered on press and hold the reset button for 5-10 sec. Release the button and wait until the router boots up (1 min).
If this does not work then you can try this
Try setting it into recovery mode and loading firmware:
Unplug power cable from the router and press the reset button. While holding the reset button plug the power cable in. Continue holding the reset button untill you will see LEDs on the router flashing rapidly.
You should be able to log into the router - you will see a prompt to load firmware. The firmware is available on our WEB site: http://www.dlink.com.au/tech/
Note - suggest you d/l the firmware BEFORE you reset router
Jul 05, 2008 | D-Link DI-704P Router
Computers & Internet Logo
David Payne
David Payne
