Question about Rowenta Irons
I have a Rowenta ultra professional - model DM991G - I just discovered the cord seems to have broken where it comes out of the iron - it melted the rubber thing & gets extremely hot. I am not using it and wonder if the cord can be replaced or if I need a new iron ? Christine Francis
satscoop
  • 59 Answers
SOURCE: Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
Posted on Nov 15, 2007
DiYerTech
  • 70 Answers
SOURCE: Cleaning the bottom of my rowenta irom.
Rowenta does sell a soleplate cleaner kit. But if you must do it yourself, I use nothing but Q-tips, a wooden orange/popsicle stick to genly scrape the tough brown stuff...and finish it off with "Dutch" cleanser, and old cotton sock, either dry or with a tiny bit of filtered drinking water. Do not use anything stronger, as the soleplate can be easily scratched.
Posted on Jul 14, 2008
SOURCE: Rowenta Steam Iron Leak
Yes, my rowenta model DX6700 is also leaking from the heal. I bought this iron after having a GE for ten years because I thought it would iron my clothes better. I've had it less than two years. How frustrating!!!!!!
Posted on Aug 01, 2008
wizzard8955
  • 18 Answers
SOURCE: I have a Rowenta 1700
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Posted on Mar 06, 2009
  • 109 Answers
SOURCE: need to know how to clean a rowenta iron plate
As long as it's not a coated surface - plain steel - get 0000 steelwool to rub it with. It will take some elbow grease but it will work to clean and (almost) polish the surface.
Posted on Mar 26, 2009
Retractable cord
Don't be in such a rush to repair your Rowena when the cord won't retract. Simply spray the opening with silicone spray and wait 20 minutes. Hit the retract button and VOILA!!!!!
Feb 03, 2014 | Rowenta Professional DE880 Iron
Power cord on rowenta dm991 is split- needs a new one- can I do this myself?
On the end of the iron there are 2 screws - remove them; on the bottom of the end there is a small slot - put a small screw driver in the slot and pull on the end; you will find the wire that goes into the iron - get a replacement from an iron shop and you are good to go!
Dec 14, 2010 | Rowenta Ultra Professional DM991 Iron
Rowenta Iron-Professional Luxe The power cord seems to short out when you move iron. You can wiggle it next to the movable ball and it clicks on and off. The two screw heads on bottom appear to be special...
I drilled out the nubs in the center of the screws. removed the screws, and took off the back plate. The problem is that the cord seems to be abraiding when it swivels, and eventually wears thru. It seems like a fire hazard and should be looked into by Rowena. Anyway, I cut out the damaged cord and reattached it. Problem fixed..
Oct 22, 2009 | Rowenta Irons
My Rowenta iron is leaking down by the cord. can
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Oct 16, 2009 | Rowenta Professional DE880 Iron
My rowenta stopped heating , mid-shirt!!......now it seems dead and wont heat at all !.........thanks !!!
The most likely cause is a broken wire in the cord. Replacement should only be done by a qualified electrical appliance repairer. Ask for a quote as it may be cheaper to buy a new iron!
Oct 04, 2009 | Rowenta Powerglide DM273 Iron
My Rowenta Professional will not come on.
Yes, there is a broken wire inside of the cord. This is a potentially dangerous situation for you as it could result in a deadly shock or a fire. The cord can be replaced for about $25.00 at a repair shop. Therefore, it may be more logical to trash this iron and get a new one.
Either way, good luck.
Feb 04, 2009 | Rowenta Professional DM890 Iron with Auto...
Rowenta problem
mY de 87.1C WAS WORKING AN ABOUT TWENTY MINUTES OF IRONING, THE CORD & PLUG IN BLEW & IT QUIT.
Dec 26, 2008 | Rowenta Professional DE871 Iron
Rowenta Iron
Special screw called "Torx tamper proof" call 925 8271011 and order "Rowenta tool" $10.00 plus shipping-this place also sells Rowenta parts
Apr 09, 2007 | Rowenta Professional DX8800 Iron
Irons Logo
115 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
