Question about Sony Playstation 3 (PS3) Console
My PS3 has had the YLOD 3 times now and I've repaired every time myself. Each time I repaired it last about 6months before it gets hit by the YLOD again. After repairing the console for a 3rd time I was able to get in 2 hours of game play before my PS3 froze up on me. I turned it off and restarted it however something keeps happening which has never happened before. I've been searching over the Internet for the best part of an hour and I can't find any reference to it let alone a solution. As I turn my PS3 on from the main switch it automatically turns on to solid green without me pressing the on switch at the front or by pressing the PS3 button on the PS3 controller. After it turns on it stays solid green for 3 seconds, there's 1 beep then 2 seconds later there another single beep then it turns off to solid red. If I attempt to turn it on from the front after the first shutdown from the solid red standby mode, it turns back on to solid green for 3 seconds, 1 single beep, 2 seconds later 2 beeps, another 2 seconds later there a single beep again and finally it shuts down to a solid red light. I also have a disc in there which I am unable to remove. I'm trying to keep this PS3 running as long as possible until the PS3 Slim white is released to the EU. I would rather not spend £150 on getting a refurbished PS3 in the mean time. Thanks for any assistance.
  • so_chilled Sep 17, 2010
    Thanks for the advice however I corrected the problem myself.
    After diving in to the PS3 system I discovered a faulty Ribbon that connected to the on/off
Thank You..... Thank You... Thank you.. for answering your own question :) I was going through the exact same thing and couldn't figure it out for the life of me. Only difference was this was only my second re-flow. I know I did everything perfect too. Because like you mine last 6-8 month's. Not two weeks some some who don't put the added tlc needed. After reading your solution I noticed that because of the way that ribbon bends. Some of the beads were protruding from the ribbon. So I pushed them down with a plastic fork prong so I wouldn't rip it. Then flipped the ribbon so it wouldn't bend over the end again. Thank you again Chilled....
Posted on Oct 06, 2010
My PS3 doesnt turn on, it only flash on red the power light...
you got the YLOD!! This is varry bad sorry to say.
Your ps3 got to hot to many times!! I own electronic repair shop and we see this all the time.
get more info here...
http://en.wikipedia.org/wiki/YLOD
Jul 15, 2011 | Sony Playstation 3 (PS3) Console
When i put ma ps3 on it goes green yellow red
I experienced the same issume before. This is called Yellow Light of Death or (YLOD)
Please see below on some information regarding this issue and some possible reslotion to prevent this from happening:
If we go by Sony's definition then having PS3 YLOD means "general hardware failure". So it means that a fault could have occurred anywhere in your Console. Don't be afraid though, since most of the times PS3 YLOD is due to motherboard getting detached.
Tips on how to fix it:
Alternatively you can try to repair ps3 YLOD yourself. There are a couple of things you can try to fix YLOD - check for any loose connections since some connections might be loose, you can also try switching it off for around 30 mins and switch it on again. This will help in cooling your PS3 down.
If these tricks don't work, then I will suggest you go through a dedicated PS3 repair guide instead of tinkering on your own. Such guide will cost you almost nothing in comparison to what Sony charges. And, god forbid, if it happens again you can solve the problem for free.
One of the greatest thing about doing it yourself is that you don't have to pay hefty charges to the big companies. Also, you don't have to wait for weeks, you'll completely fix ps3 ylod in no more than a few hours. Many people have already successfully fixed yellow light of death and I don't see a reason why you won't be able to do it. If my PS3 has yellow light of death then I won't pay Sony to repair my PS3. I'd rather fix PS3 lights myself.
If all this steps wont work i suggest to call SONY
1-800-345-7669
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
A VERY HELPFUL RATING IS APPRECIATED, Thanks Regards
Nerdierob
Jun 06, 2011 | Sony Playstation 3 (PS3) Console
Yes i was playing my 60gb playstation 3 comsole in it shut off in i hit the ower button it came on went yellow and the shut off red
Hi there, unfortunately what you are describing is called the Yellow Light Of Death (YLOD). When the PS3 was originally made Sony used lead free solder in their consoles. Lead free solder is not as flexible as normal leaded solder and over time due to expansion and contraction because of heat given off by the console's components hairline cracks formed in the solder joints between the CPU and GPU and lots of PS3's failed. You have got a couple of options, you can either have the console professionally repaired which is going to cost around £50. If the console is out of warranty Sony will only replace it for a cost of around £130. As a last resort if you are good with electrical items you might want to have a go at repairing it yourself. If you google YLOD you will find plenty of guides that will instruct you on how you can repair it yourself.
Please bear in mind that once a console has the YLOD there is NO guarantee as to how long a repair will last, it could be a couple of hours to a couple of years
Hope this helps and thank you for using FixYa
Jan 02, 2011 | Sony Playstation 3 (PS3) Console
When i turn my ps3 on it immediatly beeps 3 times and goes to standby
Hi there, unfortunately this sounds like the Yellow Light Of Death (YLOD). When the PS3 was originally made Sony used lead free solder in their consoles. Lead free solder is not as flexible as normal leaded solder and over time due to expansion and contraction because of heat given off by the console's components lots of PS3's failed. You have got a couple of options, you can either have the console professionally repaired which is going to cost around £50. If the console is out of warranty Sony will only replace it for a cost of around £130. As a last resort if you are good with electrical items you might want to have a go at repairing it yourself. If you google YLOD you will find plenty of guides that will instruct you on how you can repair it yourself.
Please bear in mind that once a console has the YLOD there is NO guarantee as to how long a repair will last, it could be a couple of hours to a couple of years.
I hope this information helps you and I hope you get your PS3 up and running soon.
Nov 27, 2010 | Sony Playstation 3 (PS3) Console
My ps3 wont turn on when you try it blinks blue then yellow and makes a click noise and shuts down and flashes a red light tell u hit the power button again
Hello there, this is sadly called the Yellow Light Of Death (YLOD). When the PS3 was originally made Sony used lead free solder in their consoles. Lead free solder is not as flexible as normal leaded solder and over time due to expansion and contraction because of heat given off by the console's components hairline cracks formed in the solder joints between the CPU and GPU and lots of PS3's failed. You have got a couple of options, you can either have the console professionally repaired which is going to cost around £50. If the console is out of warranty Sony will only replace it for a cost of around £130. As a last resort if you are good with electrical items you might want to have a go at repairing it yourself. If you google YLOD you will find plenty of guides that will instruct you on how you can repair it yourself.
Nov 16, 2010 | Sony Playstation 3 (PS3) Console
PlayStation 3 yellow light wont turn on
Hi there, unfortunately this is usually a sign of the Yellow Light Of Death (YLOD). When the PS3 was originally made Sony used lead free solder in their consoles. Lead free solder is not as flexible as normal leaded solder and over time due to expansion and contraction because of heat given off by the console's components lots of PS3's failed. You have got a couple of options, you can either have the console professionally repaired which is going to cost around £50. If the console is out of warranty Sony will only replace it for a cost of around £130. As a last resort if you are good with electrical items you might want to have a go at repairing it yourself. If you google YLOD you will find plenty of guides that will instruct you on how you can repair it yourself.
Oct 03, 2010 | Sony Playstation 3 (PS3) Console
My playstation turns off when i trun it on ????
by not turning on do you mean.....
you press the power button, it beeps to come on and then the light changes color to yellow and beeps few more times and finally has the blinking red light. if this is the case
what you got is what is know as yellow lite of death --YLOD
this is the site i got the info from...
http://boardsus.playstation.com/t5/PlayStation-3-General/Unofficial-Yellow-Light-of-Death-YLOD-Informative-Still-Thread-R/m-p/40726489
and you are not the only one to experience this. more and more ps3 owners are getting hit with this problem. your best bet will be to send it off to sony if its under warrenty for they'll fix it for free. but be cautious of this for they may even replace your system and you may not get your original system back. if its not under warrenty you'll get hit with an $150 charge. you can check youtube for videos on how to open up/fix your ps3. look for videos "YLOD FIXES" i get people telling me that their system only works for few days to few month so i have to assume that the fix is not a permanent. last i checked i think sony only cover your system for 30 days if they fix it. there are also guides you can buy.
background
The YLOD is a major hardware failure for the PlayStation 3. The specific cause is somewhat known, but Sony has not commented about this failure whatsoever. Some theories for the cause include:
overheating (accelerated by dust build-up), blu-ray drive failure, bad power supply, and/or a hard drive critical error.
**UPDATE**
According to an eBay store that repairs YLOD PS3's, the hardware failure is caused by either/or of two things:
1. Hardware malfunction on the motherboard due to heating/cooling (solder physically cracking/breaking) which can be fixed by "reflowing", which is a fancy way of using a machine that has a super controlled (+ or - .5 degrees) hot air nozzle to re-melt the solder on the base of the defective chip to re-attach it.
2. The power supply has the failure in one of its capacitors or diodes. This can also be fixed by "reflowing" but it is harder to diagnose due to the need to chase down which one it is.
**According to this eBay store, this scenario is a much more difficult way to repair PS3's with the YLOD. They state they can only repair 8 out of 10 PS3's with the YLOD**
You know you have received the YLOD when the following occurs:
* You power on the console.
* The console starts up normally for about 2-3 seconds,
* The console beeps 3 times while flashing a faint yellow light,
* The console continues to flash a red light.
May 20, 2010 | Sony Playstation 3 (PS3) Console
My sony ps3 is not powering up,everytime I go to turn it onit cuts out mmediately and there is a disk stuck in there as it cut out and won't stay on long enough for me to eject the disc.,
by not powering up do you mean.....
background
**UPDATE**
about the only way to get this disk out (outside of sending it in to get it fix either to sony or local repair shop) is to open up your ps3 yourself. if the system is out of warranty and you want to give it a shot you could watch these videos to help
this is a video on how to open up your ps3
http://www.youtube.com/watch?v=ILtruYvt7S4
this is a video on how to open up your blu-ray
http://www.youtube.com/watch?v=7O-8NzYHr80
Playstation 3 will not turn on when the on button is pressed it bleeps and then the green light flashes yellow then a red light flashes
background
**UPDATE**
May 19, 2010 | Sony Playstation 3 (PS3) Console
My ps3 wont work
seems like you´ve got the terrible PS3 YLOD
What you can do?
Try to disssemble the PS3 and you will need to do a reflow fix in the Cell and Rsx processors solder points...
You will need soldering skills and a good Smd air resoldering stations..and a good flux...
Good Luck...
Sep 10, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
285 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
