Question about Janome 6260QC Computerized Sewing Machine
2 year old Janome 6260 QC. Today freemachine stitching when machine jammed. No thread tangles, reel and bobbin released normally. Feed dogs working normally. Lo signal on screen and handwheel jammed. Waited suggested 15secs+++ but no return to normal. Turned machine of and on. Wheel remains jammed. This is second time this has happened. Took back to dealer who said he didn't know what caused the problem. Dealer closed today. What can I do?
bargainbox
  • 1388 Answers
SOURCE: Janome MC 9000 Embroidery/Sewing Machine
This is the diagnistics routine for Janome 9000.
Run each test in sequence from 1 - 13, or until you find error
The results of this may not be what you want to hear, and may be why no-one has yet replied....I hope for an easy resolution for you
If you are having trouble reading this here, simply send a request via the "contact us" page on:
www.bargainbox.com.au
Martyn
Posted on Feb 16, 2008
SewTechWayne
  • 186 Answers
SOURCE: Raising and Lowering the feed dog on Janome 4900 MC
These machines are known to have this problem. The feed lift cam has a groove worn in it that won't allow the feed dogs to come back up. It is on the lower shaft and needs to be replaced. You can get the feed dogs back up by taking off the needle plate and lifting them up manually while turning the hand wheel. They should stay up until you drop them again.
Some people will not replace the cam and live with it.
good luck!
Posted on Feb 08, 2009
SOURCE: We have a Janome sew precise machine that we bought new about two
I had the same "problem" with my new machine. I called Janome's customer service and they told me the stitch length dial needs to be on S.S. I did that and it worked!
Posted on Feb 12, 2009
  • 43 Answers
SOURCE: need insturtion manual for janome memory craft 6000
I can help you with the manual, but you need to provide a model number. "Memory Craft" is a designation used an many Janome models.
Dave
Posted on May 07, 2009
Mongo32
  • 111 Answers
SOURCE: When sewing the bobin thread tangles and jams
upper tension/threading wrong?
Posted on Jul 08, 2009
Janome Magnolia 7318 suddenly started making a lot of noise, sews a couple stitches then jams, bobbin thread tangles. It is clean, no lint or thread anywhere in the undercarriage.
Remove all the thread. Install a new needle. RAISE the presser foot and rethread from the beginning. Confirm it follows the correct thread path and the upper tension is set at the midway point.
If that doesn't resolve the issue, you may need to take it for service.
Jan 15, 2017 | Janome Sewing Machines
I have a a Janome 6260. The thread eVentually splits in half, then breaks. This problem is worse when I use decorative stitching
I'm going to guess on this one; if your stitches are even (no bunching or pulling), you might have a build up of thread somewhere in the machine. Take out the bobbin and, if possible, the bobbin casing and check for any tangled or loose threads. Second guess, check the feeder on top of the machine, thread may be working its way into and catching on that feeder... be very careful when threading through the feeder because thread will often catch. If neither of these 'fixes' work, might be time to take the machine in for a cleaning and tuneup.
Dec 05, 2014 | Janome Sewing Machines
The bobbin case on my singer feaherweight is stuck
Sounds like thread or lint has got on the centre spindle of the hook. and jammed bobbin inside case. unclip race and remove hook and bobbin assembly. remove feed dogs and all tangled thread. machine should then be freed up
Feb 05, 2014 | Sewing Machines
Thread is tangling in the bobbin casing
Hello
The feed dogs should be in the highest position for regular sewing. If the feed dogs are not raised above the plate it will do this. With the machine unthreaded and no fabric.. run the machine to see if the feed dogs are moving and are working.
Always make sure you have about 3 inches of both threads before taking any stitches, and both threads are positioned directly behind the needle. ( this machine is fussy about this).
make sure you rethread it exactly as the owners manual shows
Change the needle
Change the thread
Take it in for service
Jul 23, 2011 | Janome Memory Craft 10000
E6. Motor locked up because the thread is tangled. I have re-threaded machine and bobbin; thread still tangles after 2 or 3 stitches. HELP!
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
Jan 18, 2011 | Brother CE4000 Computerized Sewing Machine
Have a brand new Singer 1507 that keeps jamming the bobbin thread. Have followed threading and winding bobbin instructions closely, but am still having problems with the bobbin thread jamming after 1-2...
I would try adjusting the tension on the machine - this sometimes causes the bobbin thread to jam while sewing. Re thread the entire machine including the top thread. Also it is recommended to use new thread as old thread can ball up after time. If no luck I would call the store you purchased the machine from.
Nov 30, 2010 | Sewing Machines
When i start to sew on my Janome sewing machine model Sewist 525S it does a couple of stitches on any stitch type then bangs then sews then bangs then stops. I look to see the problem and the bobbin and...
There has to be a problem in your threading or your needle. You may have the needle inserted backwards, flat side has to face rear or the needle is bent. Totally unthread your machine and make sure that there are no tangles and that it feeding the right way. Watch how they show your for threading and winding the bobbin, plus threading the bobbin. Good luck, but I truly think it is in your threading.
Sep 25, 2010 | Brother LS-1217 Mechanical Sewing Machine
Machine makes noises and tangles up then jams from the bobbin side I do not have a manual
The bobbin case,shuttle rack and hook,and or feed dog,are in need of cleaning and oiling. Thread,fabric fibers and dust collect during sewing.
Jun 15, 2009 | Janome Sewing Machines
Janome 6260QC Computerized Sewing Machine Logo
117 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
