I have a customer with a central a/c system, the air handler is in the attic (horiz. mount) The bottom of the airhandler is dripping wet! I checked the drain line for blockages, freon preasures and air flow, everything checked out ok! I even changed to coil and primary drain pan! Its still dripping wet!! WHY????
  • 2,427 Answers
Chances are the problem isnt with the unit at all!!!! check the attic to see if something there can be giving off vapors that's condensing on drain unit..
Posted on Sep 17, 2010
Were is the reset button on the unit?
Hi, here is the theory on the reset button on Air Conditioners. They reset via the breaker panel box in your house. Check that first before anything else. However if your unit is popping breakers, it is because the rating for the breaker is incorrect, or there is something that needs servicing usually in the outside unit called the condenser. That piece contains the compressor. A faulty compressor and pop the breaker. Or If the condenser fan that blows over the coils of the outside unit stops (common failure) The compressor will overheat and shut down. That may not trip the breaker but the house will get hot anyway. Usual action for this is to replace the condenser fan motor and starting capacitor. Make sure the speed rating and directional rotation for the replacement motor is the same as the motor removed.
There are other reasons why the system won't come one fully. If the wall thermostat is digital and does nothing. including turning on the fan. There will be a small fuse located on the circuit board of the air handler (part of Air Conditioner mounted inside the house. It houses the circulation fan). That fuse could be blown. That one shuts down just about everything.
On air handlers mounted up into the attic crawl space there is an overflow pan. This pan is mounted directly below the air handler. This pan can fill with water when the drain pain contained inside the air handler starts to overflow because the drain system to that is clogged.
There is a "float switch" mounted in the overflow pan wired to the system in such as way as to shut down the entire AC system if that pan fills.
The handling is to clear the obstruction in the Drip Pan inside the air handler. Then remove enough water from the overflow pan and the AC will run as though nothing has happened.
If you have more questions, write to me on this site.
One thing more. The capacitor alone in the Outside condenser unit can fail and that will stop the condenser completely if it is of a "split" design and used for both the compressor and fan. When replacing this unit alone, ALWAYS find the same specification part.
I hope this helps,
Have a Happy New Year,
Mark
Jan 02, 2011 | Goodman CLJ30AR32 Air Conditioner
Drip pan wet furnace filter lennox air handler
verymuch so it is clogged up , now open system treat drain pan with bleach ,blow out two lines if there are available but if theres only one treat that on ,then treat the coils clean an treat them after cleaning pour little bleach in the bottom of the pan
May 23, 2010 | Ruud UBHC Air Conditioner
Need to connect a universal fan relay with a transformer
I hope you are good at electric becaue you are biting off a chunk here...
Check out these diagrams they are for Honeywell but all the fan centers are pretty much universal...
http://customer.honeywell.com/techlit/pdf/60-0000s/60-2023.pdf
or this one...
http://customer.honeywell.com/techlit/pdf/60-0000s/60-2171.pdf
one of those should be pretty much like yours...
heatman101
May 06, 2010 | Carrier 38CKC036 Air Conditioner
Excessive water dripping from Central A/C drian line
sounds like the overflow drain is picking up the water that means the main drain is clogged.you need to find the main drain pipe if lookin at the air handler in attic there should be 2 drains from unit one higher than other follow it and blow out drain they put the other overflow drain out the eve so if it stars leaking someone notices it and it doesnt damage cieling but it sound like it needs imediate attention befor it does go to the overflow pan and damage your cieling. i hope this helps and good luck
Sep 29, 2009 | Amana PTC153B35AJ Air Conditioner
Central A/C unit has a leak
The air handler has either a drip pan with exit pipes on the side or a drain pipe and any of which could be clogged.. Find out were the water is supose to exit,, and at that end - tape a strong wet vac to suk out any clog or debris..
Rate well ;o)
Jul 22, 2009 | Heating & Cooling
MY GOODMAN AIR HANDLER IS DRIPPING WATER FROM THE BOTTOM
You may have dirty stopped up drain pan or drain. Take a dryvac and **** the drain from outside. This will clear all the drain. Is it cooling ok? Is the unit in an attic? The drain is not hard to clean. Check your coil(evap) inside to see if this is clean. Rus
Jul 11, 2009 | Heating & Cooling
I can not find the furnace in our home. Is it in the attic??? or crawl space??? i have a newer home in Phoenix
it could be an air handler in the attic, do you have gas or ele. some are built into the water heater if it is gas, do you have base boards running around the bottom of your floor or air vents with am ac condesor outside if this is the case it could be either the crawl space or attic
Jun 06, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Does my Heil air handler have a air filter or just coils??
The Air filter should be located under a grid in the ceiling somewhere in the house. That is where the air in taken and returned after it passes thru the air handler in the attic. There has to be an access to the attic in order to service the air handler if needed. That is Code. Your system, I presume, is a "split system" with the condensing unit outside and he air handler in the attic...
May 30, 2009 | Heating & Cooling
Vertical to horizontal
most all airhandlers have a second pan included . if not they can usually be purchased with directions to mount to the side of the coil for horizontal right or horizontal left application. remove the front panel and take a flash light look inside and you should see a cookie sheet looking pan on one side of the coil usually on the right side coil can usually be removed and reinstalled with the top of the coil facing the filter or the blower depending on how you want the air to go . just be sure the pan is under the coil and you will be ok . i have actually seen pros install them with the pan above the coil! and of course they flood the place. water of course goes down hill. the square donut pan used for vertical install stays in place as found. you will need to install a second emergency pan to catch any backup drips especially if you put it in an attic. you should find them at a sheet metal shop and they are basically a pan even bigger than the airhandler that catches any drip. it should be connected to a drain to the outside also and a float switch installed in case it fails to shut off the ac. better to get a no cool call than a flooded house call. try to put the second drain out over a door or window where it will be noticed before damage. good luck and remember you will have to relocate ductwork, electric drains filters refrigerant lines and if its in an attic a decked service area and a light and an outlet are required here in fla. good luckagain.
Oct 25, 2008 | Ruud Central System Air Conditioner
Ruud air handlers
Check the name plate amperage on the air handler. The air handler only has the blower motor as its main current draw. #12 wire is rated for 20 Amp service. If the amp draw by the unit supplied by the disconnect is under 15 amps it should be fine (but) once again check the name plate for ampacity rating.
May 27, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
