Question about Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF
No hot water, little puddle below unit, age is about 18 years Can this be repaired ?
  • 20 Answers
Please for your safety and the safety of your home replace the water heater. It has definately paid for itself more than once. As a repair plumber I really like to hear about a water heater that old still being in service. Just reminds me that things are not made like they used to be. Average life for a water heater tank now is 10 to 12 years. The oldest one that I have personally taken out of a home was 32 years old.
Posted on Sep 16, 2010
Boiler does not fire up sometimes and takes around 5 minutes to fire up when it does.
If you've had it for about 18 years it may be time for a replacement or, at the very least, a boiler repair. I had mine replaced three months ago and it was 15 years old. I think that it is important to make sure that you replace important things like this about every 15 years just to ensure that everything is working properly and is up to date. How long have you had issues with it? Because if it has worked really well up until recently then all you probably need is just the repair though. Bailey Plumbing and Heating and Air Conditioning
Sep 02, 2015 | Water Water Heaters
How do I trouble shoot a residential water heater
Hi Michael:
First off you have to determine what the SYMPTOM is that you are experiencing.
Example:
- water too hot
- puddle under tank
- very little hot water.
Then you can ask the FIXYA gang for help with the problem, or
You can research it yourself.
Jul 18, 2015 | Water Water Heaters
I have a Reliance 501 HWH, 15 yrs old. Nary a problem until now. Yesterday, HW was very hot. Today, no HW. I'm thinking of replacing both elements and thermostats due to the age. Sound reasonable?
At fifteen years of age it would be less cost over time and labor to replace the whole tank. How efficient is your old one and being it runs hot all the time you could have a tank that will not last very long anyway. Mine sprung a leak at 18 years and made a big mess.
May 15, 2014 | Reliance Water Heater #6-50-DJRT 50GAL...
We are getting a brown colour in our hot water from our Vulcan freeloader (assume this is where its from anyway). Is this a fixable problem or will we need to look at a new unit? The current unit is about...
unfortunately there is no fix other than replacing the tank, it has a lot of rust buildup inside over 18 years, which is a very long time for a hot water tank today.
Aug 30, 2011 | Water Heaters
Our little gourmet dual hot/cold faucet has just started to gurgle out hot steaming water all day without use. The complete faucet is burning hot. Unit is 4 years old and used frequently.
having hot water trickle out all day will make the whole unit hot,, to the touch,, what you need to do , is turn off both the water supplys under the sink,, then remove the handle by removing the hold down screw,, after that , remove the hot water valve,, Just remove the nut that's on the outside of the fixture, what your going to find is at the end of that valve, is a washer,, made of hard rubber,, that needs replacing,, but also, inside of the fixture is a washer seat, its either brass or stainless steel,, that takes a seat tool wrench to remove that ,, but to make sure its repaired completely, both the washer and seat need to be replaced, seat tools are pretty inexpensive at Lowes , or Home depot,, and thats where you can get the parts you need also,, be sure and compare the old parts with the new, so take them with you when you go, most hardware stores that have plumbing supplies will have what you need, the seat just unscrews , but they can be a little tough,, if you decide to get a seat tool, they have straight ones and 90 degree ones ,, the straight ones you'll need a wrench to assist turning in the removal and install,
Aug 26, 2011 | Mountain Plumbing Products Little Gourmet...
Our 18 year old hot water tank has been "putting
Install a new water heater,it should have failed 10 years ago
Feb 26, 2011 | Water Heaters
I have a puddle of water under my Rheem gas water heater. I clean up the water and then it puddles up again. I can not find the source of the water leak.
Depending on age, your tank may be rusted through. Different mineralization of the water can ****** or speed up a tank failure. Most water heaters have at least a 5 year, many a 10 year warranty but none will last forever, 'glass lined' or not.
May 19, 2010 | Rheem Water Heaters
When I run the hot water on my tankless LPG water heater the water will run hot for a few minutes and then shut down even though the hot water tap is still open. This means hot and cold water cycling...
There's a little device that is like a pressure switch that starts heating when is senses water flow. This is what happens when it starts to go bad. You will need to call out a professional and have it serviced and the part repaired or more probably, replaced.
Apr 09, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF Logo
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
