Question about PSB Alpha Sub Zero Subwoofer
I have no green power light on my subsonic 5i which screws do i remove to replace a fuse inside
  • 52 Answers
Make sure you the plug eorks before you do anything. Plug in a lamp or something. The fuse is inside where you plug the input.
Posted on Sep 01, 2010
Mitsubihi WD-65738 no power, no lights. Is there a fuse I can check? Maybe by the plug?
Follow the power cord inside to the power board--line fuse will be there--have fun and patience as a lot of screws to remove to get there---as seen from rear power board should be to far left side.
Dec 03, 2012 | Mitsubishi WD-65738 DLP TV
NO POWER
1 the obvious question.... have you tried a known working outlet. 2. Most likely the internal fuse has failed and must be replaced. You can access this fuse by removing 4 side panel screws, (2 on each side) and 6 rear chassis cover screws. BEFORE you start unplug the unit. Remove the 10 screws. Standing behind the unit, then lift the top cover slightly and pull toward you. the side guide tabs wil unlock and the cover will come free. Once the chassis open aviod the large capacitor as it can still ruin your day. Follow the power cord until you see the fuse block. Remove the fuse... obtain an EQUAL value replacement and install the new fuse. reinstall the cover making sure the side guide tabs interlock on the front sides of the chassis. Plug the unit in and see if you have any signs of power.... I.e light on with door open or control panel dispaly lights up. If you have visible signs of power places a coffee cup filled with water inside the microwave and see it it heats up. If it starts and then all the power goes off again you probably have a bad diode. If it works fine then your in luck.
Jan 06, 2010 | Sharp Microwave Ovens
Kenmore micrwave overheated. now won't work. is
There is a fuse inside the chassis that can be accessed by removing the 4 side screws and the 6 back screws on the chassis cover. First unplug the unit then remove the 6 screws securing the cover to the shassis. Once the screws are removed lift the rear of the cover about 10 to 15 degrees and pull to the rear. The chassis cover will then come off. NOTE: There is a large capacitor inside the chassis that will stil have a charge. Make sure to avoid it when reaching inside the unit. Follow the power cord from where it enters the chassis to the end terminals. One of them will terminate at the fuse holder. Remove the fuse, obtain a new fuse of equal value amd intall same. Plug the unit in to see if you get some from of power be it a light inside or the contral panel lighting up. If it is just the fuse and you see signs of the unit having power once again unplug the unit and re-install the chassis cover.. Make sure that the cover interlocks on the front of the chassis properly. All mating surfaces should appear flush. Re-install the 6 screws and retun the unit to service. If nothing happens please reply to this post.
Jan 05, 2010 | Kenmore Microwave Ovens
Waring Waffle Maker no heat
Remove 4 Black Phillips Screws 2 on the front near the handle that flips Use a Good fitting Screwdriver These screws have a thread locker on them. They will strip the heads out if proper care is not used when removing them.Then remove the two screws at the rear of the Iron Just rear of the cooking surface. This will remove the chrome cover on the bottom of the cooking surface exposing the wiring. The thermal fuse is located under a section of insulation under a clamp held in by another Phillips screw.Do not cut or Damage the insulation. Gently pull it back exposing the fuse. After replacing the fuse, insulation ,Clamp and screws check to be sure the iron heats and cycles on and off and the ready light works properly. If it does not cycle the new fuse will blow . Good luck
Sep 22, 2009 | Waring WMK300 Professional Belgian Waffle...
How to remove bathroom fan pull switch?it doesnt click
1 turn power off remove appropriate fuse
2 UNSCREW PROTECTIVE CAP
3 screws aqre visible they usually hold 3 wires
black green and red. if they have losts of black wound together it means they are in series with other lighyt switches. Ideally get an electrician in.
anyway unscrew the wires from their holders and attach a new swtch placing wires basck in the same congfig. RED is LIVE Black is RETURN ( Usually) and Green EARTH.
(Sometimes live and return may be blue and brown)
put cover back on replace fuse and turn power on and hope there is no "bang" because you put wires in wrong way
Jun 12, 2009 | Electrical Supplies
Replace halogen light bulb inside oven
1 To replace the oven light,
first disconnect the power
at the main fuse or circuit
breaker panel or pull the
plug.
2 Remove the top grille by
taking out the 2 screws
that hold it in place.
3 Next, remove the screw
located above the door
near the center of the
oven that secures the
light housing.
4 Replace the screw.
Connect electric
HOPE THIS HELPS :)
Feb 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Olevia 42" model # 542bl
Facing the back of television, if it occured while putting top right screw, that is because, you screw touched power module casing and the fuse inside the TV is gone. All you need to do is goto radio shack or any local store and get a replacement fuse (250v x 5 Amp) and replace it. It may cost you less than 2 bucks.
Symptoms:
TV powers off and never turns on.
May even power in that room or house may have been tripped.
Resolution:
lay the TV face down on the floor.
Remove the screwes ( may be 10 - 15 screws)
Remove rear casing of the TV. It is single casing covering entire rear face of the TV.
Fuse is visibe as soon as you remove the casing.
Replace the fuse.
Put the casing back.
Start enjoying the TV.
Prevention:
Do not use longer screwes to mount monitor brackets on TV casing.
GOOD LUCK!!!
Sep 17, 2008 | Olevia LT42HVi 42 in. LCD Television
2003 Dodge Stratus Hazard Light problem
I had the same issue with a 2002 stratus, the problem was the flasher relay. It's located inside the steering column, inside the multiswitch, and its fairly easy to replace. Two screws under the steering column to remove the top cover, then two hex screws to remove the multiswitch, then you can remove the relay which is green, mine was part# 04606478AD. You won't find this exact relay at the local auto parts store, but you can order from mopar parts online, or check the parts dept. at your local dealer. I called a local dealer, he didn't have it but was able to find one a few miles away, cost was $30.
Aug 23, 2008 | 2003 Dodge Stratus
Replacing Thermal Fuse in Sony Grand Wega KDF-E55A20
The PROPER way to replace the thermal fuse is to remove the optical block first. There are at least two recessed screws holding the block in place. BE VERY CAREFUL removing the block as it is very easy to tear/rip wires when doing so. I cannot emphasize enough NOT TO JUST THROW THE NEW THERMAL FUSE INSIDE THE CABINET!!!! The thermal fuse is a safety device mounted near the lamp to prevent overheating. Those that choose to just let the fuse "sit out in the open air" are risking greater failures and the possibility of fire.
May 27, 2008 | Sony Grand WEGA KDF55E2000 55" Projection...
PSB Alpha Sub Zero Subwoofer Logo
452 people viewed this question
Top PSB Audio Players & Recorders Experts
Andrew Taylor
Andrew Taylor
Terry Weaver
Terry Weaver
Are you a PSB Audio Player and Recorder Expert? Answer questions, earn points and help others
