Question about Epson Stylus CX7800 All-In-One InkJet Printer
Left & right streaks when printing
Looks like there's some lint or thread soaked in black ink that's dragging across the paper when I print, which is no surprise because I print on fabric alot. But now every time the carriage returns to the right or left, it leaves a big blotch, then skidmarks across the page. Has gotten gradually worse over time. How do I take the ink carriage thingy apart so I can clean the underside where the jets are? I already cleaned everything I could reach from above.
    Scholar:
  • 94 Answers
Hi, it sounds that your printer may require service to clean the printhead thourouly.
Tirzo
Posted on Jun 12, 2008
THE PRINT IS NOT CLEAR
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Good Luck!!!!
Apr 17, 2013 | Lexmark Office Equipment & Supplies
My hp officejet pro l7680 all-in-one printer started printing with black streaking lines. I switched paper today from 20 lb to 24 lb. Would that make a difference?
No that should not make a diffrence!
Try the Following Steps:
1. Get a damp paper towel.
2. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
3. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
4. Next dab the cartridge on the towel to make sure that the ink is flowing.
5. Snap the cartridges back into the printer.
Good Luck!!!!!
Sep 27, 2011 | Office Equipment & Supplies
I am printing envelopes and have black ink marks and streaks across the left hand side of the envelope (return address area).
There is dust & ink build up on the printer head. Take it apart. Wipe it off by hand with print head cleaner & lint free cloth.
Apr 05, 2011 | HP PHOTOSMART PLUS B209A All-In-One...
When printing, print is has irregular & has white streaks through letters. Have tried "Print Head Cleaning" & "Print Head Deep Cleaning" several times and now printer won't...
you can flush the printhead on running water.
and have a mixture of ammonia and water solution. Soak the printhead and leave it overnight. This will unclogged residue in the printhead.
it will work again as good as new.
Jan 18, 2011 | Canon PIXMA iP3500 Printer
My printer is running a white streak through the center of pages
Next, try this printer self-test by following the steps given below:
1. Turn the power to the printer "off."
2. Press and hold the "Paper Feed" button.
3. Press the "Power" button once while continuing to hold the "Paper Feed" button.
4. Keep holding the "Paper Feed" button until one sheet is cycled through.
5. The test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know.
Oct 01, 2009 | Lexmark Z715 InkJet Printer
I put a new ink cartrige and printer prints low coulour tone.
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.  2. Select "Clean and Fix Horizontal streaks."  Click on "Print". This will produce a printed page.
1. Please open the "Solution center" again and go to the "Maintenance" Tab.  2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.  3. Get a damp paper towel.  4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.  5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.  6. Next dab the cartridge on the towel to make sure that the ink is flowing.  7. Snap the cartridges back into the printer.  8. On your computer, select "Old Cartridge install."  9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
May 26, 2009 | Lexmark Color JetPrinter 5700 InkJet
Can't print in color
May 26, 2009 | Lexmark JetPrinter Z11 InkJet Color...
I have a HP Photosmart C5180 printer. It is not printing purple-instead what comes out is blue. I have done a print test report and it showed the Light magenta and magenta with missing bars and streaks. I...
If your color improved slightly when running the printhead option then doing more should help get better results. Sometime the printheads get really dirty/clogged and running the cleaning option more then once is needed.
If you get a slight line running across the page (from left to right) usually the indicates dust build up on the printhead or ink carriage. The dust acts as a paint brush being dragged across your paper as the carriage moves across the page during printing. You can clean the bottom of the carriage with a Q-tip or purchase some cleaning paper for your printer.
Apr 16, 2009 | HP Photosmart C3180 All-In-One InkJet...
Black smudges on printed page
Are you sure this is a Designjet 450 (large format printer) and not a Deskjet 450 (portable printer)? The following assumes you have wispy black streaking on the printed side of the paper. If the streaking is on the back side then post more details of the printer model and the issue.
In either case the most likely cause is a buildup of fibers on the underside of the printheads or carriage, causing wisps of black ink to be dragged on the paper when the carriage reverses direction. You can clean the printer as shown at the following (though the details will be somewhat different for the Designjet or Deskjet....).
Regards,
Bob Headrick, MS MVP Printing/Imaging
Sep 16, 2008 | HP DesignJet 450c InkJet Printer
Black smear of ink at end of lines
Please load the printer with at least 10 sheets of plain paper then press the start button. This will dry or clean any ink found on the rollers.
Continue to run blank pages through the printer until no more ink is found on the paper, then attempt printing. If ink stains, streaks or smudges are still present, the printer may need service.
May 23, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Epson Stylus CX7800 All-In-One InkJet Printer Logo
117 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
